Computer will not boot.
Down loaded either a windows or security update and shutdown computer to apply the updates as requested. On start up got Blue Dell logo with loading bar panel on black background, then went to screen with following messages:
RAID Volumes:
ID Name Level Strip Size Status Bootable
0 ARRAY RAID0(stripe) 128KB 298.0GB Failed No
Physical Disks:
Port Drive Modal Serial# Size Type/Status(Vol ID)
0 ST3160023AS SMT0DAF6 149.0GB Member Disk (0)
2 ST3160023AS SMT0DC0A 149.0GB Non_RAID Disk
Striking the F1 Key results in message: No boot device available
Was able to go to the Boot Device Menu and run Drive Diagnostics:
Drive 0: Pass
Drive 1: No device
Drive 2: Fail. Return Code : 7
Drive 3: No device
Drive 4: Philips DVD+/-RW DVD8631-Diagnostics not supported
Drive 5: No Device
After several re-boot attempts received screen message:
Alert! Previous attemps at booting this system have failed at check point [Ithur].
Thanks for any advice or assistance!
  • karunasigma Jan 03, 2009
    I have same issue- but i do not have RAID.
    After few times reboot, i went onto F12 to boot menu, i seleected to do hard disk verification and i got below error
    Drive 0: Fail Return Code : 7
    Drive 1: Philips DVD+/-RW DVD8631-Diagnostics not supported
    Drive 2: No Device
    Is the hard disk dead ? Or is it a software driver issue ?
  • 998 Answers
Form the info you provided, you have a RAID (Redundant Array of Independent Disks) disk array. RAID 0 (striped disks) distributes data across several disks in a way that gives improved speed and full capacity, but all data on all disks will be lost if any one disk fails. Apparently Diagnostics has determined that “Drive 2” is defective. You will have to replace the defective hard drive and reload the Windows operating system.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 21, 2008
SOURCE:
When opening any pdf file internet explorer gets stop working and browser restart. Reader.exe faulty module
Check for any updates and optional updates in control panel.
Run Windows Update in Windows 7
Using Windows Update in Windows 7 keeps your laptop and desktop computer safer.
Microsoft periodically releases updates and security fixes.
By loading these updates, you are keeping your Windows computer safe from viruses, spyware and malware.
With Windows Update, you have the ability to download updates and choose when to install, automatically have updates applied, check for updates only and/or never check for updates.
Click "Start," "All Program" "Windows Update."
Alternatively, you can click the "Start" orb and type Windows Update in the instant search box.
Windows Update appears in the list for you to choose.
Click "Check for updates;" it is located on the left hand-side of the open window.
Windows 7 begins checking for updates.
They are categorized as important and optional.
Click the "Important Update" link and choose all that apply.
Once you are finished choosing your important updates, click "OK."
Click the "Optional Update" link and choose all that apply.
Click "Install updates."
Windows 7 downloads your updates and installs them.
A reboot of your computer is required once the update process is complete.
You might also try this for IE 7 not sure about IE 9
Fix Adobe Acrobat or Reader 9 Crash on Internet Explorer 7 Problem
Adobe Acrobat and Adobe Reader 9 enable the computer to view PDF files.
These applications also install an add on, or plug in a small software that adds extra features to a programto Internet Explorer 7, enabling IE7 to load PDF files from within the browser.
If conflicting add-ons are installed to the browser, or if the Adobe Acrobat or Adobe Reader software is not properly installed, however, IE7 will crash whenever it attempts to load a PDF.
Open Internet Explorer.
Hold down "Alt" to show all of the toolbars.
Click "Tools" from the menu bar.
Click "Internet Options."
Go to the "Advanced" tab.
Click "Reset" to revert the Internet Explorer 7 settings to default.
Click "OK."
Restart Internet Explorer after resetting the browser.
Return to the "Tools" menu and click "Manage Add-ons."
Wait for all of the add-ons to load in the right pane, then look through the list to find the add-ons labeled "BHO" or "Browser Helper."
Click each add-on with "BHO" or "Browser Helper" in the name, then click "Disable." Restart IE when finished.
Download the Adobe Acrobat or Adobe Reader 9 software from the Adobe website, if you do not already have the setup program on your computer or on disc.
Click "Start."
Click "Control Panel."
Click "Programs," then click "Programs and Features."
Scroll to "Adobe Acrobat" or "Adobe Reader 9."
Right-click the program. Select "Uninstall" from the context menu.
Follow the onscreen directions to remove the software from the computer, then restart the PC.
Log back in to Windows and click "Start."
Click "Computer."
Navigate to the folder where the Adobe setup file is saved or insert the Adobe Acrobat CD.
If the file is saved on the computer, double-click the file to launch the installer.
Follow the onscreen prompts to reinstall the plug-in to Internet Explorer 7.
Restart the PC when the installation is complete.
Open Internet Explorer 7 after booting to Windows.
Open a PDF file from within the browser to test the browser.
http://kb2.adobe.com/cps/331/331025.html
Dec 10, 2013 | Computers & Internet
My acer 1 netbook wont start back up after trying to do updates
format your drive in which windows is loaded and then load windows a different drive (D or E or F etc) it will work and after re instalation windows disable windows update from control panel (control panel then system and security then windows update then turn automatic update on or off then select never check for update) and apply
Jun 18, 2012 | Acer Aspire Computers & Internet
Black screen right after dell logo
start tapping f8 after you boot the machine, when given the boot menu, try to load safe mode, and see if it loads. if it does, then you need to do a system restore back to before you got the black screen. more than likely windows loaded an updated driver that disagrees with your system. try that and let me know what happens :)
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 25, 2012 | Dell Studio One 19 PC Desktop
Failure configuring windows updates Reverting changes do not turn off your computer....I am stuck here...What do i do? windows 7 ultimate 64
If you still waiting, follow the direction below to restore you PC to the point before the updates were installed
Shutdown your PC -
  • Try to shutdown the PC via the shutdown button in windows start menu , if you unable to shutdown using this button you can still shutdown the PC via the power button on the Tower/PC case by hold it for 10 secs.
Load safe mode
  • When the PC is loading click the F8 just after the motherboard system check are run (also know as POST)
Restore Windows
Watch Video Below
Oct 25, 2010 | Microsoft Windows Vista Ultimate Edition
Hello, I've got a problem with error code 401 when panda internet security 2009 (license up 3 pc's) is traying load update from internet, my license is active until 01.2011,thenks
The error code 401 is due to a conflict in virtualization system. Here's how to fix this: Click on the Windows logo at the bottom left (Start), write APPDATA in the text box and click Enter. On the window that will open go to the Local > Virtualstore > Program Files. Delete the folder called either Panda Software or Panda Security. Open the anti-virus. Enter your update details again and update your security solution.
Aug 15, 2010 | Panda Internet Security 2009 - 3 User for...
Dell inspiron 1525 laptop shutdown problem
The Laptop is not responding to the Software request sent to the BIOS or one is not getting there.
Best Solution is to make sure all of your Microsoft Updates are performed. Not just the Critical ones... but all that apply. You may see several hardware driver updates.
This will help the Software and Hardware to communicate with each other...
Jan 01, 2010 | Dell Inspiron 1525 Laptop Flamingo Pink
After loading Window service pack 3 update, comes up blue screen
press f8 and go to safe mode and delete service pack 3. sp3 is known for problems
Sep 23, 2008 | Dell Dimension™ B110 PC Desktop
My computer keeps restarting itself
  1. Start laptop
  2. When the laptops Logo page closes, start to press F8
  3. You should get a Windows Start screen
  4. If you get a Windows Logo page (the kind you normally get when Windows loads, then reset it and start again.
  5. On the Windows Start page select "Last known good configuration" and press enter twice
Hope that solves it for you =)
Apr 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
583 people viewed this question
Alun Cox
