Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
NEED HELP WITH AUTO CONFIGURATION
I can`t auto configuration through the OSD main menu. I dont know any other way to auto configuration, so I need help..
    President:
  • 2,992 Answers
You can download a copy of the manual from hp by going here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
and picking the "monitor user's guide" link.
The auto configuration is just a choice from the main menu. If your monitor OSD is locked so you can't select anything (you get a message when you press any button), you can follow the manual procedure to unlock it. But unless there is some electronic problem with the monitor, you should not be having trouble with autoconfiguration.
Posted on Dec 02, 2008
How do i get auto configuration off my screen
Try uncheck Auto configuration when you right click on desktop and choose screen resolution menu.
Nov 25, 2015 | Gateway FPD1530 15" Flat Panel LCD Monitor
How to delete console port and telnet passwords through BootROM?
1. Connect a PC to the device with a serial cable and log in to the device through the console port.
2. Restart the device. When the message "Press Ctrl+B to break auto startup ..." is displayed, press Ctrl+B and enter the password to display the BootROM main menu.
3. Select choice 4 to enter the Startup Select menu.
4. Select choice 1 to view the system configuration.
In V200R001C01SPC300 and later versions, you can use the following method to view the configuration file. In Huawei V200R001C01SPC300, the menu choice is Startup Information. In Startup Information and later versions, the menu choice is Display Startup.
Startup Select
1. Display Startup
2. Set Boot File
3. Set Config File
4. Startupfile Check Manage
0. return
Enter your choice (0-4):1
************** Current Stratup info ****************
Valid Flag State : Vaild
Boot File Name : sd1:/software.cc
Config File Name : sd1:/vrpcfg.cfg
Licence File Name :
Patch State : Deactivate
Patch File Name :
Voice File Name :
In V200R001C01SPC200 and earlier versions, the configuration file cannot be viewed. The system often uses the file vrpcfg.zip or iascfg.zip.
5. Rename the configuration file.
6. Restart RouterA.
7. Stop Auto-Config.
8. Change the renamed configuration file to executable file. Select one file format.
9. Restore the configuration.
Aug 19, 2015 | Computers & Internet
My Acer LCD Monitor shows the , auto Configuration menu and is on a black screen.
How did the auto configuration came about? Try pressing the buttons before powering up. Maybe some of it are stuck.
Feb 21, 2015 | Acer AL1916W 19" LCD Monitor
My auto configuration menu on the monitor keeps popping up and cannot get it to stop what can I do?
auto configuration menu stays on monitor screen constantly while trying to use pc for normaluse.
May 20, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
Projector randomly turns off after 10 minutes or so
Go to the OSD menu and select the configuration menu scroll down and select the auto power off selection( in most cases it is preset to power off after ten minutes of inactivity) turn the auto power selection off and there you go!!!!!!!!!!!!!
Mar 11, 2010 | ViewSonic Cine1000 Multimedia Projector
There are buttons on the front of the monitor. Why
The first button is the E-power button for the Auto preset function.With it you can select presets like text, standard, graphics etc. depending on your use.
When you select any button the options are displayed at the bottom of the window. These tell you what button to press to select the next option.
For example press --menu-- > -- > -- menu , to adjust the horizontal and vertical position.
To turn off the monitor you must press and hold the --circle with the line -- button for a couple of seconds.
Jan 27, 2009 | Acer X193W LCD Monitor
Screen looks like hour glass.
press the auto button on the OSD"On Screen Display" .
if that doesn't fix the problem, then you have to select menu from the OSD and select geometry from the main menu and select horizontal of vertical adjust. or you can press auto.
Dec 11, 2008 | E-Machines eMachines Monitor E15T4
"Processing Auto Configuration" keeps showing up on my screen.
It solved by fixing 1024X786 pixel solution.if it not possible by fixing it..
Then look over the VGA driver is correctly support or not
if not then you have to update the VGA (Display) by drivers
By
Murugeshkumar.k
Dec 24, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
107 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
