Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Picture cycles off and on
After turning on sony grand wega lcd projection tv, it turns off then on, then off, then on, etc. It began a couple weeks ago and would cycle a few times. The next time it was turned on it might be OK. Then it would cycle a few more times. Until today it would eventually turn on and stay on. Now it just cycles off and on every three to five minutes. I No lights are on except for the red stand-by light when the picture is off. (it does the same with other inputs.)
  • 4 more comments
  • iwo1125 Dec 07, 2008
    hi. My Sony WEGA projector tv does the same, but now it doesn't stay on too long, it stays on for only like 2-3 min and it is turning off ...and then on and off again .. :( does anyone know what that may be???
  • krugergs Dec 14, 2008
    I have exactly the same problem: pictures on, then to standby (picture off). Cycles back and forth. Standby light flashes when the pictures is off. Seems the period of time between cycles is getting shorter. Couldn't find anything in the manual that addressed this issue.
  • bacjac21 Dec 25, 2008
    we are baffled as well...same problem, please help!
  • jqreagan Dec 27, 2008
    Thanks. I took a chance and replaced the lamp a couple days ago with Sony brand and that seemed to do the trick.
    jim
  • Anonymous Jan 29, 2009
    turns off and on, i looked at the buld it really looks ok,but it is doing it more frequent now turning off blinking 34 times each time then turning back on. is the lamp??
  • Sam Hofer Apr 02, 2009
    I have the same problem as reported, no lights flash when it turns off, but when it turns back on you hear a buzzing sound. My question is the TV is only like 2 years old. Why is the bulb bad already?
I replaced a burned out xl-2000u bulb with an after-market Philips bulb on my Sony KF60XBR800. After a fews weeks, I started experiencing intermittent black-outs with the "stand by" red light appearing. After a couple weeks it became intolerable. I then purchased an OEM Sony lamp and the problem has been gone for months. I read somewhere that the Sony circuitry monitors either resistance or watts and shuts the thing down for board protection. It was said that it is so sensitive it can can use only the Sony bulb. I'm a believer. If the bulb is going bad, i wouldn't doubt the protection circuit can kick in.
,,,,Pat
Posted on Dec 26, 2008
I replace a burned out xl 2000 on my sony 60xbr800, the lamp indicator light is not blinking,the tv turn on for about 1 minute then turn off and now is the stand by light that is blinking, what could be wrong ,the power supply or the ballast,and how can i tell.thanks
Posted on Mar 05, 2009
Replaced the bulb as well and it work liked a charm!
Posted on Jan 19, 2009
I had the Sony service tech in and he replaced the bulb and adjusted the picture.
No more cycling on and off. No more red shadows on the right and no more ghost images on the left.
Problem solved The lamp was $200.
Posted on Dec 27, 2008
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
Picture will come on and then go off after a couple minutes
This usually means the Lamp is failing. Replacing the Lamp usually fixes it. I would only use a Sony Replacement.
You can order one from Sony at 1800-222-SONY or you may be able to pick one up from a local Sony Retailer.
Skyassoc
Nov 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
When I turn my Sony Grand Wega Kf-50XBR800 on,
This is symptom of weak lamp in TV, please replace lamp in TV and I would suggest to buy Sony original lamp for TV safety.
Lamp replacement procedure is written in user manual in details, click Sony Support if you want to download user manual copy.
Thanks.
Oct 18, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
My sony grand wega lcd tv does not have a picture when turned on. the power/standbylight flashes constantly but the lamp does not come on
How old is this TV? Did you replaced its lamp?
Symptom shows TV needs new lamp as existing lamp is weak and unable to provide back light.
Thanks.
Sep 12, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
SONY GRAND WEGA TURNS PICTURE DISPLAY ON AND OFF
bulb is dirty remove and clean if it persists replace bulb.
Jul 05, 2009 | Sony Televison & Video
LCD TV Problem
Replace Lamp in TV and lamp replacement procedure would be written in Instruction Manual of TV.
Always buy Sony Original Lamp for smooth picture result and avoid aftermarket/ cheap lamps.
Let me know exact model number of TV if you need more help.
Apr 22, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Sony grand wega model kdf60wf655 cycles on and off.
My kdf55wf655 did this for about a week until I put in a new Lamp. Working fine since then. Got it through Amazon from www.vanns.com.
Dec 15, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Tv turns off
Its the lamp that needs replacing. It will run for a couple of seconds and then it would dim or turn off.
May 27, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
419 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
