Question about HP Pavilion m7480n (882780389410) PC Desktop
Sound driver Recently our desktop went down because of a power surge. We lost most of the information unfortunately. We have been able to restore a lot of the programs except the sound drivers. We cannot seem to locate the recovery cd. Any advice how to get the sound going again? When I try to access the device manager through safe mode, it will not bring up the safe mode screen at all. I have tried many times. Thank you
  • changethewor Nov 22, 2008
    Hi, thank you for your help. I tried what you stated, I downloaded the driver for the media center but it didn't install. It gave me a message of not being able to continue. I made sure I had the right OS and all. There was one driver for BIOS, should I try that? I am just learning these things, thank you.
  • 903 Answers
  • Debs
    Debs Nov 22, 2008
    I don't recommend updating the bios unless you are comfortable doing so.
    Can you check that your sound card is being recognised by windows. Go to control panel>system>hardware>device manager and check to see if you sound card is there, if it is and has a yellow exclamation mark next to it then it is being recognised but has problems.
    Right click it and go to properties, make sure that it is enabled, if it is then go to update driver, and see if this helps
Hi there I have a Samsung model SRL551DP upside down fridge. Recently our whole block had a power outage. When power restored fridge did not resume. Refrigerator door panel blinks the letter d only?
modern fridges do not like power surges as it burns the electronics
call in a technician to check it out and put a surge protection in the power supply cord
Apr 18, 2016 | Samsung Refrigerators
My radio stopped working after a power surge tripped the breaker for the outlet it was plugged into.
I have had several different makes of clock radios and all said that it was battery back up for power failure
none worked and all settings had to be redone
power surges do not trip breakers as they are in effect a fuse to prevent damage to the wiring in a dead short situation or when a unit fails
even surge protectors will still pass power after a surge but will no longer protect against another surge
Sep 04, 2015 | Emerson CKS3528 SmartSet Desktop Clock...
Control button locked. when I turn ooff PC the sleep light will not turn off.
Typically, the computer is defaulted to stay turned off after an electrical outage. To start the computer from scratch again, hold the power button in for several seconds. If it powers off, wait a minute, then hold the button in again to start it. When the screen comes up that says it didn't shut down properly, choose Safe Mode without networking. It will look like it is hanging on several files, normal, let it go. The screen & icons will be large because it is in default VGA mode. Once it stops loading, go to the Start Button & choose Restart. Things will return to your chosen default settings and most things will work again providing you have an EMI/RFI Surge Protector power strip that everything was plugged into. I have had several fail after a power surge, they are supposed to. Some have insurance should you have electrical damage after a power surge that got beyond the strip. Ultimately, $15-$50 is cheaper than your PC &/or monitors damaged by not having one, they are designed to be the Sacrificial Lamb & be the cheap breaking point.
As an added note, people confuse Sleep Mode with Hibernate Mode. Sleep mode means anything you are working on gets suspended into your available memory while it goes into Power Saving mode. On a power loss, all will be lost, save regularly if you use this mode.
Hibernate uses a space on your hard drive to write the information. Power loss, nothing is lost and on waking up or powering back on, your data will still be where you left off, usually intact. To restore from either mode without electrical loss, hit the ESC key. Exceptions will occur if you use Hibernate mode but only have a power strip for your multiple plugs. A power surge can still damage your computer because it wasn't blocked by the EMI/RFI power strip.
How do you know which one you have ? If you only have an On/Off power switch, you have an unprotected power strip. If you have a button on the side of that switch, known as a Reset Switch, you have a protecting one. Even if the Reset Button doesn't restore the power strip, it gave it's blife to protect your computer equipment. Cheap insurance.
Good luck.
DellTech.
Sep 01, 2012 | Dell Computers & Internet
My area recently had a power failure. Oddly, during the power failure I could still see a light coming from the Canon MG5220 printer. After power was restored, it was sometime later when I noticed that...
Unfortunately, it sounds like when the power was restored, the printer experienced a surge. If this was not plugged into a surge protector, then it's possible the switch was fried at the point of power restoration. It is important that with units such as printers, monitors, towers (computer), tv's, vcr/dvd players, almost any type of electrical appliance be plugged into a surge protector. However, even if this was true in this case - when a power shortage (outage) is experienced, it is necessary to unplug everything so that when the power is restored, nothing that is plugged in will be affected; as your printer was.
Now, you can have this fixed - either take it to a local computer repair shop; that might be able to fix it, or contact the manufacturer and inquire about sending the unit in for repair - regardless of warranty or not. If it is still under warranty, they may honor it. I am not positive they will for an accidental damage such as this, but it's worth calling them.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert, Phone Support, Live Chat @ Fixya.com
Jun 25, 2011 | Canon Pixma MG5220 InkJet Printer
My power went out in my house and when the power was restored my computer would not turn on...there is a blue flashing light in the back of the computer.
The blue flashing light is probably on your power supply. I suspect that the power supply was subjected to a voltage surge during your power outage. It may have damaged your power supply (or possibly other components in your computer)
Try unplugging the power supply from the wall socket and leave it unplugged for at least 5 minutes. Then plug it in and see if your computer will turn on. If it will not, you require the assistance of a PC technician to test your power supply and computer.
You should connect a surge protector or UPS (Uninteruptable Power Supply) to your computer to prevent this from happening again.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Dec 31, 2010 | HP Computers & Internet
Power surge emptied d drive/disc all data gone.computer will not shut down on it's own.
it is advisable that you repair or re-install your operating system. This will restore all system files that may have been lost or damaged by the surge.
Nov 29, 2009 | Computers & Internet
Hp desktop won't turn on
It sounds like you may have lost your power supply due to a surge in the line when the power came back on.
Here's link to some power supplies, I would also invest in a surge protector power strip, to prevent this from happening in the future.
Make sure you get a power supply with the same or higher wattage then the one in your PC, they are fairly easy to replace four screws on the back of the PC and unplug the connections to the PC components inside.
I hope this helps,
Thanks for using FixYa,
Eric.
Jan 20, 2009 | HP Hewlett Packard Pavilion A6200N PC...
Dell 5100 won't start... Power button blinks yellow.
hi disconnect pc and try to charge ups without anything connected
Dec 04, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
No Power to my TV after power outage
A lot of times its simply a fuse that goes out. Either way someone is going to have to open it up and inspect the fuses first. It 's a fairly inexpensive service call.
Hopefully the fuse took the hit from the storm.
Jun 04, 2008 | Televison & Video
Msg-blinks no display
Hi Dan, Yes it is a very nice system, but like any device it is sensitive to electrical storms and power fluctuations. A surge or sag (AC power going up or down), can cause the sensitive digital chips to get damaged, and from my experience if you have tried resetting the unit, and your msg lites continue to flicker and the LCD is blank, it has some serious damage and needs repair or replacement.
Aug 25, 2007 | Siemens Gigaset 2420 Cordless Phone
HP Pavilion m7480n (882780389410) PC Desktop Logo
155 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
