Question about Proview PL926WBi 19" LCD Monitor
White screen When ever I turn on my pc my screen stays white. I turn off pc turn on again still no monitor only white screen. Does this 5 or 6 times before it comes on the right way
  • 3 more comments
  • Anonymous Dec 11, 2007
    My Proview 900 W began failing to start after bootup. The screen stayed black, and the blue power LED would flash on/off. I implemented the solution as given by Delphiuser. There was clear evidence of dielectric leaking out the tops of a few caps, as if they had gotten too hot. Replaced all six 470uF caps, and it's up and running. Thanks Delphiuser for saving me lots of $$$. Much appreciated.
  • Anonymous Mar 22, 2008
    I was using my computer the other day and I noticed that the monitor was flickering a little bit.at first, I blamed it on the constant construction that is going on in out apartment complex, but then all of the sudden the screen went black but the power light remained on and lit up. I pressed the button to turn it off and then on again. the screen came up and then started to flicker and after around 4 seconds, went black again. I tried this several times and even un plugged both wires and plugged it back in to my computer and then on another. still the same thing is happening. I reinstalled the driver that I thought I needed and nothing worked. Normally I am the guy that sends in rebates and buys insurance or saves the actual box in which the product came, in case I would ever have a problem. The one time I need those things, I don't have them. Is there anything that I can do to get a new monitor out of this without the box and warranty? Or is there a way for a mechanically inclined person such as me to maybe pop the cover off and tweak a wire to get it working again. please : )
  • rhett2k Dec 08, 2008
    When ever I turn on my pc my screen fades to white and remains that way.
    I turn off pc turn on again still no monitor only white screen. Does this multiple times before it activates properly for use.
  • loveladyelk Dec 19, 2008
    These instructions to repair are great, but my monitor has no screws on the side ( like the 6 you speak of ). How do I get the case off? It has the 4 on the bottom, and the top pops loose, but the sides will not release. Any suggestions????
  • nationof3 Feb 18, 2009
    I have the black screen with the power light on but I have no bulging capacitors. I have the PL926wsi which I believe is just a different color. Also I have five 47uf25 instead of six and four 220uf25v. Would other thing cause this problem instead of the caps.
    Problem Solver:
  • 11 Answers
I had problem with a Proview 19? monitor: Product number: #PL926Wbi Model Number: 900W The monitor was manufactured in January of 2006. After I had owned and been using the monitor for 1 year and two weeks, it started having problems whenever it was first turned it on from a ?cold start?. The monitor would just turn white when first turned on sometimes it had grey vertical lines. After letting it worm up for an increasing length of time, either rebooting, or changing screen resolution would make it behave correctly. (I was using it as a secondary monitor connected to a lap-top computer). Eventually, the monitor would no longer reset, and I set it aside and put a new monitor on. This weekend, I decided I needed to fix it. To perform this repair you will need to know how to use a soldering iron, screwdriver, and purchase Capacitors to replace the ones going bad in the power board for this monitor. Here are the steps to repair this if you have the same problem. 1. Remove the four Phillips screws on the bottom of the bezel. 2. Flex the Bezel out away from the flat panel and slide ?up? to release the catches on the Bezel, 3. Remove the six screws on the sides of the LCD. 4. Lean LCD away from the electronics inside and disconnect screen cable and four backlight cables (2 bundles of two, and a big flat connecter) that are connected to the metal box directly behind the screen. The box is the electronics cage. 5. Remove the screws from the top of the electronics cage, and peel back metallic tape sealing it. 6. Remove top of electronics cage. 7. Remove the screws holding down the power board. (The board on top with the Black plug sticking out of the monitor bottom for the power cable.) 8. Unscrew the grounding strap. 9. Buy six 470uf electrolytic capacitors 9The ones in the unit were 25v Radio Shack had 35v for $1.69 each) Remove bad capacitors, replace with new capacitors (the black half of the circle is where the stripe goes.) 10. Reassemble in reverse of disassembly. On my monitor this restored functionality (It has been running for 1 day), so for about ten dollars and an hour or so of time, I got the monitor back to where it appears to work like new. Your mileage may vary; good luck, and good night.
Posted on Oct 01, 2007
  • charliene Dec 14, 2010
    In my case it was 4 capacitors 680mf. Replaced them with 6 x 470mf. The problem is gone.
    Thank you
Wow. I'm surprised by how many people have had this problem. My Proview 22" goes white and the blue led blinks when it flickers from white to black and stays white. It would take several reboots to actually get the screen to work... and how long it will stay working is unpredictable. I've contacted Proview support via email and I'm waiting for a reply. I see that people have done the repairs as mentioned with success and I'll be doing the same soon! I"ll post the outcome when I get around to do it.
If you're wondering, mine:
product no: PL926Wbi
Model no: 900W
Manufactured: January, 2006
Posted on Nov 25, 2007
  • cuong-nutz Dec 02, 2007
    I replaced the capacitors in Delphiuser's write-up and it has fixed the screen problem!
    I think they're bad because of the bulge at the top of the capacitors:
    [IMGhttp://i2.photobucket.com/albums/y5/cuon...[/IMG]
    The new blue capacitors:
I had this same problem the day after a severe storm. When I opened the monitor I noticed that all six of the 470uF caps were bulging @ the top and two had black ooze seeping out of the top.
I followed the instructions by Delphiuser and they worked perfectly. Also, the tips by macSPT were extremely helpful, especially the one about numbering the back light cables! If you follow these instructions, you can't mess up.
I'd like to add that you will also need a small pair of diagonal cutters to trim off the cap leads after you solder them into place. In addition, when you go to Radio Shack, get the radial lead caps, not the end lead ones. The Radio Shack part # is 272-1030 and they were $1.29ea.
This was an easy fix to make and saved me a lot of money.
Posted on Feb 26, 2009
Just wanted to add- I just ordered these on ebay, auction #120369102130. I got twelve for 5.35 delivered. I hope this solves my problem and this imfo helps someone. Thanks
Posted on Jan 30, 2009
I've got a Phillips X19 Monitor basically the same as the Proview screen 900W. I've just tried this fix and its not working for me. The problem i'm having is when you turn the screen on, it comes on for about 5 secs, resizes and has a orangy taint to the screen then goes black. The power light stays blue. I've replaced all six capacitors, the only difference I noticed from the guide to mine was there were four 680uf capacitors rather than all six being the same. I replaced them with 470uf. The capacitors I removed looked ok, no bulging or burnt looking.
Any ideas?
Thanks,
Dan
Posted on Oct 13, 2008
Thank you this was so easy to do, my proview rocks once again
Posted on Jul 19, 2008
  • michael7262 Jul 19, 2008
    thanks for the help my monitor is up and going it was easy to fix. i followed your instrutions to the tee.
Same here, 19", white screen. I did it the hard way though, first I assumed it was the mobo, so I got a new one with a processor, hard drive and memory. Then I hooked it up to see the same problem; white screen. So I ran out and bought a new monitor, but not a proview.
$600 later the problem is fixed.
Now I will fix the proview and give it to the girlfriend.
Sometimes I hate the way I do things.
Posted on May 27, 2008
Mine just stared doing this too. If back of your pc is close by I just unplug and replug the monitor back in to the video card port. Seems to fix it for now.
Posted on Apr 25, 2008
They should replace this monitor. KNOW one should have to do this. I am having the same problem and it should be recalled and I would not recommend this product to anyone or purchase this brand again.
Sad when it is only 5 mo's old.
Posted on Mar 12, 2008
Same problem - After dealing with the white screen issue for a few months my Proview PL926Wbi finally stopped turning on altogether. I went and replaced the capacitors (they were swollen and obviuosly bad) however, no luck. I'd imagine if the monitor would turn they might fix the white screen issue, but as of right now, the light doesn't even come on when I try to power it on. Any ideas?
Posted on Mar 10, 2008
JUST FIXED MINE.. Replaced 3 dead Capacitors!!! Thanks i never knew to check this .. Opened It up and saw the 3 dead Capacitors.. Went to Radio Shack picked up a soldering iron kit.. for 8 bucks and bought 5 Capacitors for a total of 16 bucks!!! 16 bucks.. who would have known.. SO CHEAP TO FIX IT YOURSELD .. I NEVER SOLDERED in my life.. AND IT WORKED FOR ME!!
Posted on Dec 28, 2007
Thank you so much for this information, it helped me solve my problem. When the monitor came out of sleep, it would only show a white screen with vertical scrolling lines. I took the monitor apart, and sure enough 4 of the 6 capacitors had blown. I replaced them with the ones from Radio Shack, and everything is working well.
A couple things I did differently which may help someone else.
1. I numbered each back light cable with a sharpie, and then numbered the corresponding connector on top of the "electrical cage" plate.
2. I put a small amount of hot glue around the area where the back light cables meet the 2 pin "white" male connector. This connection seemed very fragile and the hot glue gives it a little more support.
Tools I used:
1. Philips head screw driver
2. Soldering Iron
3. Solder Wick Rosin which absorbs solder
4. Standard solder
5. New pencil with full eraser
6. A small flat head screw driver
7. Electro static wrist strap
Tips:
1. If you have never soldered before (I had not), practice on an old circuit board from a broken electronic. Also search the web for soldering tips.
You should practice both removing solder and applying new solder.
2. Remember to label all your screws so you don't forget where they go.
3. When removing the electronics cage plate, there are 3 gold screws which go in the corners, and 6 silver screws that go around the cage.
4. When disconnecting the back light cables, it may be easier to use the small flat head screw driver to get some leverage against the electrical cage covering plate.
5. When reconnecting the power cable from the LCD to the electrical cage, I used the eraser on the pencil to push it down on the ends without damaging it.
6. Make sure all your cables are well seated before you close up the monitor or you will have issues and have to take the whole thing apart again.
7. MOST IMPORTANT, take your time... Take it slow and be gentle with all the cables.
8. If you are worried about possible damaging the circuit boards with static electricity, make sure to use an anti static wrist strap.
Once again, thanks to all who did this before me for the great info!
K.C
Posted on Dec 10, 2007
Delphiuser and Guest (Oct.26, 2007),
Thank you for the fix. Someone gave me a PL926Wbi LCD yesterday since it was broken and didn't turn on. The blue power LED just blinks when you plug it in, and the screen remained black. I looked up possible common problems of this model and found this page.
Got the capacitors today and repaired the power supply board, and the screen is now working PERFECTLY. I had to also replace the 25V 220uF capacitor next the the group of 25V 470uF ones, since that one was also bulging/swollen.
The manufacture date on my LCD is Febuary 2006, and the person who gave it to me had it sitting around for a while after it stopped working. Seems like these screens are made to last exactly one year and no more, especially since the problem with crappy capacitors has been known for at least two years now.
Posted on Nov 15, 2007
Thank you for the fix. Someone said gave me a PL926Wbi LCD yesterday since it didn't turn on. The blue power LED just blinks when you plug it in, and the screen remained black. I looked up possible common problems of this model and found this page. Got the capacitors today and replaced them, and the screen is now working PERFECTLY. I had to also replace the 25V 220uF capacitor next the the group of 25V 470uF ones, since that one was also bulging/swollen. The manufacture date on my LCD is Febuary 2006, and the person who gave it to me had it sitting around for a while after it stopped working. Seems like these screens are made to last exactly one year and no more, especially since the problem with crappy capacitors has been known for at least two years now.
I have the same problem with my 17 proview, I dont reboot the comp, try turning the moniter on and off a few times. Looks like i'll be heading to radio shack or best buy.
Posted on Nov 07, 2007
THANKS so much to Delphiuser ! Replacing the 6 caps has worked on my Proview LCD. How nice to have it fire-up like before. No more whitescreen-warmup nonsense.
Follow his instructions closely. Only thing I would add in is:
step 2 - your flexing out only the center section over the button area at bottom of screen(buttons stay on bezel). The edges don't release until the whole bezel slides up a bit.
step 4 - your removing the wires from the metal box - leave wires connected to LCD. (like he said).
And just to save you time - you need the radial lead caps, not the axial lead. Both wire from one end. Radio shack sells both.
Part number 272-1030, were in stock at local store.
Thanks Again Delphiuser - you saved me buying another monitor.
Posted on Oct 26, 2007
Ahh too bad, just ran into the same white scr problem with mine. It too is taking longer and longer to "warm up" . Can't afford a new one now so the Cap replace will happen if it does quit warming up. Up until now (about 2.5 years) it's been my favorite monitor ever. After the widescreen, I can never go back.
Wonder if Delphiuser's monitor is still working after the "fix".
Oh - no need to do a full reboot if the monitor is warmed up. I just do a <alt><F4> in the blind and then hit enter. On freshly booted XP system that should cause it to enter "standby" mode and in a few seconds appear to shutdown - screen goes black/blank. Then press any key (shift) and it will wake up much faster that reboot. If it's ready(warmed up) your gold.
Posted on Oct 20, 2007
Same problem - you have to reboot the pc though. 5 or 6 times maybe will work - maybe 10 times.. finally when the pc is off and just as you start the pc - you see the 'no-signal' box on the monitor and it will come on.. then its fine. sounds like a common problem - monitor is about 1 year old. anyone?
Posted on Sep 26, 2007
Just hope it keeps coming on. Mine did the same thing and I would let it "warm up" until it decided one day to not "warm up" any more. My suggestion is to have another monitor solution ready so when this one bites the dust, and it will, you won't be sitting without a monitor. Fortunatly I had an old CRT laying around (bulky but reliable) and got me back up and going. By the way, I wouldn't recommend another monitor of this brand, it was my first and it WILL BE my last.
Posted on Aug 04, 2007
I have the same problem with mine, can't fix it, but I know if you let it stay on while you wait until it warms up, then turn it off and back on it is fine.
Posted on Feb 19, 2007
Laptop screen blank all white
Either your LCD Video Cable is not plugged in snuggly or the monitor is slowly going bad. The fact that you can see the images on an external monitors says your Video Graphics Card is working fine. You'll need to disassemble the laptop to get to the cables. Get a quote from your local computer shops, then try the guys at: http://www.generalsystemsconsulting.com Most times they will fix it and ship it back by Fedex or UPS cheaper than any quote you obtained including the shipping.
Mar 15, 2012 | Compaq Presario CQ56-115DX Laptop
I have a samsung syncmaster 943NW which goes on for about 5 seconds and then just goes black. When restarting the screen it does the same again, goes on for about 5 seconds and then black. Is there...
I had the same problem with this monitor (Samsung 943nw)
When turned on it would only stay on for less then a full second.
When shining a light on the screen I could see what was on it, so it was just the backlight that was shutting down.
After I turned down the brightness of the monitor, the next time I powered on the screen the backlight stayed lit and it was back to normal.
Dec 11, 2010 | Samsung 943NW Monitor
I reformated my computer and had it on hibernate and went to sleep.I woke up and now the screen on my desktop pc just flashes about every 3-4 seconds.the screen stays black the flashes with white streaks...
Hi there
i read your report. OK go to your power options and turn off your hibernate and restart your computer.allot of times after you have reformatted your hard driver. the hibernation doesn't work correctly. Try this tip and let me know how it goes. Thank you for writing to fix ya.
Best Regards Richard
Dec 03, 2009 | HP Pavilion F1703 17" LCD Monitor
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Monitror keeps cycling through on-off
Found one of these in the dumpster at my shop today. Had the "stays on for 3 sec then turns off" issue. Problem is the bad batch of electrolytic caps of a few years ago. 2 on the power supply board were visibly swelled up (470u/16V and a 1000u/16V). Replaced them both - it's fixed. Cost 50 cents.
Feb 16, 2008 | Envision EN-7220 17" Flat Panel LCD...
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Monitor goes to white at cpu shutdown
The problem is in the "soft switch" technology: On some of Sylvania's newer monitors they have incorporated what is called "soft switch" technology. This allows your ATX power supplied computer to turn your monitor on and off using it?s software controls. Therefore, your monitor?s light will always stay on blinking even when your computer is off. The monitor in normal operation consumes about 80W of power; in the "OFF" state it will be reduced below 8W. The "OFF" mode of the monitor can be controlled by the PC input signal or by pushing the soft-power button to disable the PC signal control for manually turning off the monitor screen. Thus, when the monitor is in soft-power "OFF" mode it still consumes a very small amount of power. For the purpose of making it noticeable to the user that the monitor is in soft-power "OFF" mode, we designed the power indicator to provide for a slow blinking signal (every 2 seconds). If you need to totally turn off the power, then the power cord would have to be unplugged. The same is true of the PC itself, but the PC does not provide for notification while in "OFF" mode. Your monitor looks like it may be in need of repair, contact info: PTI Technologies Inc. 7372 Doig Dr. Garden Grove, Ca 92841 Phone: 714-799-3899 Fax: 714-379-6290 Hours: Mon - Fri 8:00am to 6:00pm PST
Nov 19, 2005 | Sylvania L181 18.1" Flat Panel LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
1,331 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Frank Russell
Frank Russell
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
