Question about ASUS Eee PC 900 Notebook
Keypad? I would be typing or using the keypad, and all of a sudden, the internet window either zooms in (120%+) or would go below 20% and doesnt stay at a window zoom of 100%!! How do I make it stop?
  • Anonymous Jan 16, 2009
    I have the same problem if anyone knows how to fix.
My keypad is broke i think, i have to hold each key down for about 5seconds whats up?
Posted on Sep 14, 2009
My tt keys get stuck should i buy a lkey pad?
Posted on Feb 27, 2009
  • helene_47 Feb 27, 2009
    i have checked every thing i thought by buying a lager key pad the problem would go away?
  • 903 Answers
Check that your Fn key is not stuck, enabling other functions. Or that the fmode key (if you have one), is turned off when you are not using it.
Posted on Nov 21, 2008
How do i get the internet explorer message that appears from time to time off the screen of motorola mc3190 without having to shut it down
The key combination you looking for to close any window or message in a Windows environment is ALT+F4, depending on the type of keypad the Motorola MC3190G are using.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
48-Key Keypad
The ALT functions are indicated in blue on the keypad, so in order to use these, you have to activate the ALT Functions first by pressing the BLUE BUTTON (FUNC) (Right side below ENTER button) and then press the CTRL BUTTON (left side below BKSP button).
After the key combination is pressed, the ALT icon appears on the taskbar on WinCE devices or the ALT icon appears at the bottom of the screen on Windows Mobile 6.5 devices.
Now you can press the "D" button to use F4, this will close any window or message that is currently in view.
38-key Keypad
Press the blue FUNC BUTTON (Right side below RIGHT ARROW button), and then press CTRL button (Middle below UP ARROW button), now you can press the F4 button.
28-Key Keypad
Press the blue FUNC button (Bottom right next to Power button), and then press the CTRL button (Top right side below RIGHT ARROW button), now you can press number 4 to use F4.
Hope this helps, good luck.
Jul 02, 2014 | Zebra Symbol MC3190G Handheld Mobile...
Keypad stayed locked
Dear Friend,
May be is time to upgrade that keypad...or maybe the wire below not properly connected...
Good Luck
Dec 04, 2011 | Acer TravelMate 290 Notebook
When i try to turn on my slvr the keypad will light up for a few seconds then turn off...I tried taking out the battery and replacing it wit a brand new 1 without any luck. I also tried just pluging it...
Hi, problem can be solved.
What causes the keypad will light up for a few seconds then turns off, is because the keypad has a separate function from the phone. (it has a removable keypad). And the keypad inside the cell phone is getting Bad and it needs to be replaced.
You can know how to disassemble the cell phone through the link below:
http://www.formymobile.co.uk/l7disassembly.php
When you replace the keypad,phone will be ok again.
Thanks for using fixya...
Feb 14, 2011 | Motorola Mobility SLVR L7 Cellular Phone
Nokia N81 am replacing housing ...how do I remove front slide
Tools required: Torx 6 screwdriver
  • Using a plastic shim, such as a guitar plectrum or credit card, lift the top keypad away from the phone.
  • You should now have the top keypad removed, like below.
  • Run your fingernail, or plastic shim, to unclip the bottom keypad surround. You can then remove the keypad.
  • You should now have the keypad removed, like below. Now remove the four screws you can see.
  • Use your plastic shim to lift the display window away from the rest of the phone. It is held in place by a light adhesive so will require some force.
  • The display window should now be removed.
  • Carefully lift the edge of the top keypad part. This is held down with adhesive. Once you have a corner lifted up, peel this part back carefully.
If you want the complete disassembly guide with screenshots please follow this link:
http://www.formymobile.co.uk/n81disassembly.php
Hope it helped.
Nov 26, 2009 | Nokia N81
How to Connect The Ps3 Wireless Keypad To A Pc On Windows 7? I know how to put the keypad in pariing mode ( holde left sholder then turn on keypad ) but when the pc detects it and asks for security code,...
You have to press return after typing in the code. It won't show up when you type, but when you have typed it all in hit the return key or enter key on the bluetooth keyboard and it will accept it.
Oct 03, 2009 | Sony Playstation 3 Wireless Keypad/Mouse
Samsung SGH D900I- cannot turnoff keypad sound
The steps are outlined in the article below:
D900 FAQ – How do I disable or mute the keypad tone on my SGH-D900? admin March 6, 2009 --> Note: In order to disable the keypad tone, the Dialing Display Font Type must first be set to “Normal”
To change the dialing display font type follow the steps below:
  1. From the standby screen, press the left soft key for Menu
  2. Select Settings (9)
  3. Select Display Settings (3)
  4. Select Dialing Display (6)
  5. Select Font Type (1)
  6. Highlight either Normal or Theme, using the navigation keys
  7. Press the left soft key to Save the Dialing Display Font Type setting
To turn off the keypad tone follow the steps below:
  3. Select Sound Settings (4)
  4. Select Keypad Tone (2)
  5. Highlight Off, using the up navigation key
  6. Press the left soft key to Save the Keypad Tone setting
Aug 29, 2009 | Samsung SGH-D900 Cellular Phone
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Aug 05, 2009 | UTStarcom Blitz Cell Phone
Keypad won't stay in keypad mode.
Go to settings and check your keyboard settings
Jan 17, 2018 | Kensington Pocket KeyPad Calculator...
My keypad all of the sudden stoped working besides a few keys
Sounds like the keypad is worn out google for repair shops in your area, here in ATL I can have the entire housing keypad and all replace for around $20
Jan 09, 2009 | Motorola Mobility RAZR V3
Keypad number
Try changing your numeric keypad. Use a normal foldable type keyboard instead.
Oct 02, 2007 | Targus USB Ultra Mini Keypad Keyboard...
ASUS Eee PC 900 Notebook Logo
773 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
