Question about Toshiba Satellite A215-S7422 Notebook
When I boot up the screen is all colors and lines
I shut down my computer one night and the next morning when I booted up, the screen was all bright colors and lines and kept scrolling up and down. Then it went into a fade and came back all gray with lines in the back. I had no way to shut it down or off because the screen was just all lines and colors. When I shut the laptop the orange light was still showing like my computer was in sleep mode. I tried several times to turn it on and the screen showed the same. A few hours went by and I tried it again and it turned on like there had never been a problem. It worked with out any problems. I logged off and when I went to log on again this morning, same screen problems. It goes away after an hour or so and works fine. What do you think may be the problem? I've never dropped this machine or anything. I just closed it down one night and the next morning experienced this problem. Thank you for your help.
  • 162 Answers
It sounds to me like your cable is loose to the lcd or the video card is not properly 100 percent seeded into the mother board. Prolly the cable in one way or the other, perhaps bad cable.
Posted on Nov 22, 2008
My Model #PSAA8U-OLK02K had some water damage. After letting it sit for 24 + hours, it booted right up. After shutting it down for the night, I tried to boot up the next morning and it got to the Win
could be moisture can affect a laptop in stages keyboard then motherboard might want open it and tent it(edges on table) and then lightly run a warm hair dryer over ports, keyboard etc you might get lucky
May 17, 2012 | Toshiba Satellite A105-S4094 Notebook
Hi, i have a Sony vaio and it was working fine until I shut it down overnight, the next morning I tried to turn it on which started out fine but as soon as the windows emblem started loading, it didn't...
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
May 01, 2011 | Sony Computers & Internet
This computer has Windows XP freshly loaded with all Service Packs. Occasionally the boot up process stops at the Dragon flash screen. Then I shut off the computer, wait a few hours. Then it may boot up...
If your CMOS battery is not retaining your system setting you will see this problem...One way to know if this your problem is to go into setup and check the system time, also stopping at the Flash screen
it could be waiting for user input...You could try changing your setting from stop on error to not stop
on error
Feb 08, 2011 | Soyo KT600 Dragon Plus Motherboard
Computer turns on and boots up , however, the screen is dark
Try going into the control panel and select power options see if there is way to adjust the display brightness or try holding down the "Fn" key and use F7 to increase the brightness
Feb 07, 2010 | Toshiba Satellite A75-S229 Notebook
Laptop wont boot on, it starts but turns off again
I'm guessing ou have windows XP?
if so you hae a corrupted regisry and need to boot from your Windows CD and at he first et of questions choose Eneter to intall windows, then F8 to continue and then it should tell yo another Windows insatallation has been found and ask if you wish to perform an automatic repair.
Give it a try and enjoy :)
Jan 22, 2010 | HP Compaq Presario CQ50-210US Notebook
Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
May 19, 2008 | HP Compaq Presario V2000 Notebook
Toshiba Satellite shuts down and won't boot up again.
Have you installed any new hardware or loaded any new software lately? If not you might have some corrupt files. Reboot the laptop in safe mode. Just hit F8 a few times. It should give you a menu. Arrow to safe mode and hit enter. After it finishes booting to safe mode, do a system restore. Click Start>click Start>Accessories>System Tools>System Restore. Choose a date before a couple of days before you noticed anything happening. Restore will take a few minutes. When it's restored and booted, I want you to do one more thing. Click on start>run>type in cmd and hit ok. This will take you to your command prompt. Type chkdsk /f It will tell you it can't run it right now do wan't to run it the next time you start up? say yes. Close the window. Restart the computer and the check disk program will run and fix your errors.
If this has fixed your problem please rate it as fixed. If nit, just add a comment add I'll be happy to help you out more. Thanks.
Apr 10, 2008 | HP Pavilion dv6000z Notebook
Display has bars and lines when it reboots
BACK UP COMPUTER RUN RESTORE DISK THAT CAME WITH SYSTEM TO RELOAD VIDEO DRIVERS AND RETRY
Jan 23, 2008 | Toshiba Qosmio G15 Notebook
Toshiba Satellite A215-S7422 Notebook Logo
246 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
