My MONSTER POWER AVS 2000 hums in high pitch noise when I plug into into the wall outlet.the 15A circuit breaker is non-responsive. Help!!Sad & Confused,Jenny64
  • 641 Answers
SOURCE: High-pitched noise
Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
Posted on Jun 13, 2006
SOURCE: lcd television trips circuit breaker
I would check 2 things. If the TV trips another breaker in the house of the same rating, you probably have a short in your TV and will need to have it serviced.(You didn't drop it did you? :-) ) The short may also occur by too much stress on the power cord where it enters the TV, common to need to cram the cord into small spaces when wall mounting. If the TV only trips that particular breaker, I would try replacing the breaker. Replacing the breaker costs very little and will only take you a few minutes. You can buy a replacement breaker at most hardware stores. Just make sure to disconnect the main supply first! Also, make sure the breaker is rated correctly, using a higher amperage breaker will increase your chances of starting a fire.
Posted on May 06, 2008
SOURCE: Dishwasher not responding to "power"
Check the door switch. THis will kill all power to machine.
Posted on Jul 05, 2008
technician88
SOURCE: High pitch sound
hi Buddah! heres the solution for the high pitch sound on to your Panasonic TV,,just check if there are some SHORTED RECTIFIER DIODE on the power supply section,
Posted on Oct 25, 2008
  • 81 Answers
SOURCE: Keeps tripping circuit breaker everytime on plug the power cord in
2 common, possible problems. 1 - there is a "short" in the plug - easy fix - replace either the cord or plug - not expensive. 2 - bad control board - not so easy, not so cheap. Is it brand new, used? Also, it could be a bad "internal breaker" - not easy!
Posted on May 07, 2009
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
My AVS2000 does not seem to be giving me the correct voltage which should be 120. The adjustments range from -.5 to -2.5 and my power center is showing a voltage between 113-115.
Hello, I seem to be having the same problem with my signature version, it's funny, I have the non signature version and it gives me a steady 127 volts, but the signature fluctuates from 119 volts to 116 volts. Have you had any luck figuring out what it may be?
Jan 13, 2015 | Monster Power Avs 2000
Lexmark x2670 won't start up. There is no power and there very quite high pitched hum sound
Hello. First i would check the outlet that its plugged into. If plugged into a wall outlet, check to see if the circuit is tripped. Might have to reset the circuit. Next try a different power outlet. Unplug the power cable from the back of the printer and plug back in. If still not working, try a different comparable power cable. If that don't work either, check to see if the printer is under warranty with Lexmark and call the customer support line and see if they can place service on it. Hope that helps
Mar 20, 2014 | Lexmark Z1300 InkJet Photo Printer
My avs 2000 makes a load hum
One of the 'cons' of the AVS 2000 is that it makes an audible 'hum' when switched on that can be heard during quieter moments. This shouldn't be overly loud though - If it is, I'd take the unit back for replacement / repair.
Jan 17, 2014 | Monster Pro AVS 2000 Automatic Voltage...
Humming/bussing
In most case power-outlets do not have problems,so the problem maybe with the surge protector it's self.Please try it maybe at friends house and see
Jan 09, 2014 | Monster Powercenter Hts 950
Mcd 1311st blowing circuit breaker
Generally microwaves should be on their own breaker. Hard wired ones are required to be by code.
If yours has a plug - make sure the plug is original with the unit, not added later or spliced onto hard-wired power leads.
Plug into and outlet rated 15A as the only thing on a 15A branch circuit and try again. If it still trips, try a 20A line and circuit. If it trips that, trash the microwave and buy a new one. Nothing is meant to be repaired inside.
Nov 03, 2017 | Microwave Ovens
I was using my Monster Power PowerCenter PC 800 power surge protector. My tv was running off it, Xbox360, and I had an iron plugged in too. All of the sudden it shut everything off and had a high pitch...
You have to open it up. Check for busted fuse, or a burnt
part. Your Power Center PC800 just experienced an overload. It could have blown an internal fuse at the least
and a burnt out part at its worst.
Nov 14, 2009 | Computers & Internet
If lights are on for a few hours the breaker interupts the power. Happens on all four bedrooms
If you have one try another breaker, if that does not help you probably have wire heating up and arking or a bad ground most likely in a wall outlet as that is the place most often that the wires can get jammed together and either ground out on one another or be loose and not making adequate contact. In most cases the lights in a room are powered off a wall outlet
Nov 10, 2009 | Siemens 12 Q115u 15a Circuit Breaker, Qp
Ceiling fan
Sorry for the delay in response. Electrically, there should be no potential hazard since there would be no more "juice" running through the circuitry.
Nov 14, 2008 | Dryers
My ceiling fan - Casa Viejo
153 people viewed this question
 Grubhead
Grubhead
