Question about Lexmark X83 All-In-One InkJet Printer
Carrier stall On screen messasge 'carrier stall press power key' When the power key is pressed the catridges spin from side to side creating a loud noise, the plug and the mains have been disconnected and re-tried over again. When the catridges move fast from side to side the catridges come loose with impact. Please advise what should be done. Kind Regards Kenny Macdonald
  • bsandt Nov 28, 2008
    My carrier slams to left side press power button and slams again
    Please help
    Bob Sandt
dugiehowsa
  • 114 Answers
SOURCE: Carrier Jam
This article gives a few suggestions on how to resolve the issue: http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:462:0:0&framed=&docid=ENUS24402&relevance=1
Posted on Sep 27, 2006
SOURCE: Lexmark P4350 print catridge does not move.
i also have a lemark p4350 printer that wont work i find the best way is to put it in the bin and buy a different one im going for the canon or the epson ....top tip gray
Posted on Feb 05, 2008
Ajkill
  • 2035 Answers
SOURCE: lexmark x83 carrier stall
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
Use the above link to trouble shoot the problem.
Error: "Carrier Stall" ID:470
To check the cartridge carrier:
1. Unplug the printer.
2. Move the cartridges to the left by hand and then take them out.
3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
1. Remove any other devices attached to the USB/LPT port.
2. Uninstall the Lexmark printer.
3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
4. Reinstall the printer.
Posted on Mar 20, 2008
  • 1894 Answers
this may be due to some breakage of some parts inside ur machine
did u look for them?
Posted on Jun 16, 2008
  • 320 Answers
SOURCE: Carrier Stall is the error
Please do the following..
Thank you....
Posted on Jan 27, 2009
Catridges are jammed
You can keep the printer plugged in, and hold down the power button and cancel button until it releases.
Aug 17, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Lexmark x83 carrier stall
Hello there.
I have checked lexmark's website on troubleshooting this problem for you.
As per the link here we need to try the following steps to resolve the problem.
Carrier stall" Error and the Carrier Slams in the Printer ID:ENUS12078 null.gif null.gif null.gif
If the printer carrier is slamming into the side of the printer, please try the following:
  1. Disconnect the power supply from the back of the printer.
  2. Open the front cover of the printer where the cartridges are located.
  3. Look for two black bands that span from left to right (they should have one serrated side and one smooth side). Just above the black bands there is a transparent strip; this strip is called the Encoder strip.
  4. Flick this strip lightly with your finger to make sure that it is running smoothly from left to right. You may need to do this two or three times. CAUTION: Do not pull the strip!
  5. Close the front cover of the printer and reconnect the power supply.
  6. If the problem persists, you may need to contact Lexmark Technical Support.
Let us know how this goes and we can assist you futher, if the printer is damaged and is under a year old, lexmark may be able to repair or replace it for you.
Hope this helps.
Jun 16, 2008 | Lexmark X83 All-In-One InkJet Printer
Error #1200 appears on screen
Hardware Error: 1200
The All-In-One is stalled.
1. Press Power to turn off your all-in one.
2. Unplug your all-in-one fro the wall outlet.
3 Check for paper jams.
4 Plug in your all-in-one
Cartridge Error: 1200
The cartridge carrier is jammed.
1. Turn off you all-in-one
2. Unplug the all-in-one form the wall outlet.
3. Open the control panel.
4 Open the cartridge access door
5. Make sure the cartridges are snapped in place in the carrier.
6. Check for objects obstructing the carrier.
7. Plug in your all-on-one
8. Press power to turn your all-in-one back on.
Hope this resolves your issues.
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
Cartridge
Remove both the Cartridges take a Paper Towel turn the catridges direction so that u can see a Copper plate with small boxes on it....... Just wipe it twice or thrice with the Paper Towel..........Now Move the Catridge carrier which holds the Catridges manually with ur Hand from right to the Left and from Left to right for about 20 Times............. Now Insert both the catridges inside the Printer............. Turn the Printer On............ If still the same Error Message.... Clear NV RAM..... Unplug the Power Supply from the Printer.... Press and Hold the #5 button on the Printer and plug in the Power Supply....... Don Release the #5 button till the Printer turns on completely.... After releasing the #5 button........ Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM..... Now as soon as the Printer is Restarted....... Still if it doesnt work call: 1-800-LEXMARK (539-6275)
Get the Printer Replaced... Good Luck
Jan 28, 2009 | Lexmark X5470 All-In-One InkJet Printer
Thank you....
Jan 26, 2009 | Lexmark X83 All-In-One InkJet Printer
Fax and copy problem
Does the All-In-One make a loud noise and then stalls.
If it does then it should also give a message as Scanner Failure.
Take out both the cartidges from the All-In-One and unplug the power cable directly from the All-In-One and move the carriage (carriage is the on which hold the cartridge) Too and Fro unitill you feel it is moving freely, Then insert the ink cartridges and close the access door, And plug the cable directly to wall outlet without surg protector, and before connecting the power cable to the printer press and hold the # and No 6 keys, without releasing the keys insert the power cord and after you see a window which says semiful reset you can release the keys.
And in case the screen goes blank then release the keys and turn the power On, on the All-In-One.
Good Luck.
Sep 01, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Feb 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Light 1 always on, beeps when any key is pressed. No typing
I was just playing with a WW 1500 and the only way i got anything close to what you described was to stop the carrier on tab and return it so it slammed at the l. margin. Check and see if the carrier moves fairly freely from side to side with power off. If so check the circut board over and under for debris.
Hope this helps
DickyO
Feb 15, 2008 | Lexmark Wheelwriter 1500 Typewriter
Sounds like the photo sensor for the "transducer" for the cartridge assy is not working (or there is a power supply related problem....)
Look for loose connections of any cable from the small blocks on either side thin strip that goes through (behind) the the cartridge assy.It has thousands of verticle lines on it.....
They could also be dirty (Incorrect speed sensing).
(Try to clean if printer is dirty...Be careful not to blow i the cartridge assy area as the ink may fly everywhere)
DO not touch the thin strip with verticle lines .Very Delicate...
Feb 09, 2008 | Office Equipment & Supplies
Error 1200, printer carrier stall
check printer belt for missing teeth if none are missing lubricate carrier bar(big siler bar that ink cartrides trvel along) with 3in 1 oil with power off then back on to retry
Jan 06, 2008 | Dell 922 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
