Question about Panasonic Microwave Ovens
Door won't remain closed and therefore won't operate. ? Problem with door locking mechanism
  • Panasonic Master
  • 9,098 Answers
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
The best place to order parts is Tritronics. You can also call them at 866-779-5835
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Nov 23, 2008
Stuck on "open/close door". How do I unstick it?
3 drops count oil or any cooking oil in door end
Jan 18, 2016 | Microwave Ovens
You must close the door hard or it will not start
The locking mechanism is not closing completely unless you slam the door because the plastic parts don't slide easily after a couple of years. We found that putting a small amount of vegetable oil on the 2 locking hooks in the door will allow the components to slide easily and close properly so the machine will function correctly.
Mar 02, 2014 | Panasonic Microwave Ovens
Door won't engage and stay closed
Possible that the lock was broken and so the door opened. You can remove the front panel and check for broken plastic or nylon pieces which can be glued using instant adhesive.
Reset the lock and switch and the door must lock in correctly
Jan 21, 2013 | Microwave Ovens
Fan Ventilation panel on my GE Profile Spacesaver doesn't operate or close now.
For help with louver operation, see the owner's manual and for further help ask here.
Sep 04, 2012 | Microwave Ovens
Error code F9 and lock on computer On Maytag gas range.model mgr587bdb.
The F9 error code refers to the door latch. The problem seems to be with the latch motor or a switch associated with the motor. If I am reading your question correctly you say that it would not unlatch and then upon resetting it unlatched but the oven won't work and you still get the error code. If so try resetting again but have someone come out to check it out or you will continue to have this problem.
The F9 indicates one of two possible problems. One you have already done and the other is the door lock mechanism. If the lock mechanism got stuck in between the lock and unlock neither switches on the lock mechanism are closed. This could be caused by a post on the lock mechanism that has failed.
I just looked up the part for the door lock and it is no longer available, with no other source for the part.
So I guess I would suggest having a technician come out and see if he can see if the lock mechanism can be fixed so the oven will work but you will no longer have the clean cycle working.
They may or may not want to do this for you, but you could use a local service company and they may be able to make it so you can use your oven.
I hope this helps (remember to rate and comment this answer).
May 12, 2011 | Microwave Ovens
Our dishwasher will not properly close and therefore it will not operate. Any ideas on how to fix this?
Open the door on the inside top of the washer there should be two screws that hold it in place to the counter one might have backed out if it is all digital and has an electric lock find the cancel or reset button
Dec 11, 2010 | Microwave Ovens
Microwave Problems
I just had this issue happen to me last week.. fortunately I was standing in my kitchen when it happened... I heard a snap and then a piece fall down the inside of either the door or the front key panel.. I'm assuming this controlled the door locking/oven turning on safety mechanism. The inside light wont go off and it won't turn on to cook.. I am trying to figure out if it's worth paying to fix or just replace the whole unit!? Anyone know if this is fixable by oneself rather than spend a bunch of money on a service technician??
Jul 28, 2010 | Sharp R-1610 Microwave Oven
Door does not stay fully closed
This could be due to a faulty door interlock but in most microwave ovens I have seen the light remains on during the cooking process.
May 18, 2017 | Microwave Ovens
Microwave Ovens Logo
61 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
