Question about Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Adjusting/waiting to scan
My printer's memory light/in use is on and the screen says Adusting/waiting to scan and I press start and nothing happens. I have unplugged and opened every flap on the machine and nothing happens. It has adequate paper. Any suggestions?
SOURCE: Scanner
are you pressing ok on the printer? all of your scanning should be done via the MP460 navigator. check your applications under the Canon Utlitiy and click on the MP460 Navigator button. scanning needs to be done via that - not the actual printer. refer to the dialogue box when you are on the MP460 navigator. lower left area has a Save bar, when you click on it tow options: save to PC or save as PDF.
Posted on Sep 25, 2007
  • 263 Answers
SOURCE: My printer won't scan
if there is a message the one seds no connection that is because you are conected to the computer with the serial cable or usb cable but the settings on your computer is for the oposite this means you have to go to start ,printers ,where you can see the name of your printer do a right click with the mouse and click properties go to ports and look for the check mark on the port name on the left square box there is LPT, COM, USB port check on the one your printer is using and that all your computer will be have comunication with your printer
Posted on Dec 29, 2007
  • 4 Answers
SOURCE: scanner setting on canon pixma mp450 will not work.
Download drivers for PC or Mac from the official Canon website:
http://software.canon-europe.com/products/0010249.asp
Good luck! :)
Posted on Aug 15, 2008
leroyal
  • 2120 Answers
SOURCE: Canon fax/scan/copy Model F 146502
It is probably a switch actuator stuck down somewhere.
Posted on Oct 11, 2008
komguy
  • 2306 Answers
SOURCE: my canon mp240 printer will not scan
It won't scan unless it's connected to a computer, and has the scan software running. Will it copy a document on the glass?
Posted on Aug 03, 2009
Canon MP340 won't scan
The printer "black ink low" message has nothing to do with scanning. You don't have to disable the ink monitoring or do anything else with printer - to scan!
The printer is" waiting" for you to CLOSE a "Paper port 11" dialog box on your PC screen. If the dialog box is not open, check the task bar (bottom of screen) for anything with "MX340" in title, click on it then close it.
good luck
Lumir
www.inkbank.com.au
Mar 09, 2014 | Canon PIXMA MP240 All-In-One InkJet...
Canon 2030i scanned document in memory - Need to clear
you follow this step :
- press button ADDITIONAL FUNCTION
- press button number 2 and 8 (press simultaneously with two fingers)
- press button ADDITIONAL FUNCTION again.
service mode will come out on the screen
- press FUNCTION on the screen
- press CLEAR
- press R CON
- press OK (bottom right side of the screen)
- swicth OFF the copier
- wait for 3 or 5 second
- swicth ON the copier
GOOD LUCK
if you need more, you can email me
Feb 22, 2013 | Canon ImageRunner 2030I Black and White...
Wand Scanner - panscn08 buttons do nothing
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan
Once you press the SCAN button and the Green LED stays lit its time to roll the scanner down your document to be scanned. When finished press the Scan button again to STOP the scan. If successful your Document count in the display will move from 000 to 001. That is the only indication that you now have a successful scan.
Next Press and hold the SCAN button until the display goes blank.
Now you can remove the memory card (by pushing in and it will release). Place this memory card into a memory card reader on your computer to transfer and view your scanned documents. Rinse and repeat.
BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at:
http://www.qvc.com/footers/E167092_quick-start-guide.pdf
Good Luck!
May 04, 2012 | PANDIGITAL PANSCN Office Equipment &...
When I turn the machine on I get an error message on the screen. It says Error code 5010. Nothing works from there. Can you tell me what this means and how I can solve this problem?
Error [5010] may appear after the printer is powered on or when attempting to make a copy or scan. This can happen if an IC on main board of the printer is either malfunctioning or has corrupt data in it.
To confirm if this is due to corrupt data, try clearing the memory by resetting it.
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the <ON/OFF> button again. (or plug back in)
3. Wait until the device has completed its cycling process before submitting another job request.
Then see if you still get same error.
Apr 10, 2011 | Canon PIXMA MP460 All-In-One InkJet...
HB Officejet 6500 scan button not working
Follow these steps to perform a partial reset of your product.
  1. Unplug the power cord from the product, and wait 20 seconds.
  2. Press and hold # and 3 while plugging in the power cord to the product.
  3. Release the buttons after the product starts up. The product will now be reset to factory defaults.
Aug 13, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Hp1350 wont scan press scan button on/resume light blinks buzzing for a few seconds and nothing else.
Did you try print any document just to make sure that printer is connected properly to the computer. If it is printing than try to scan from computer , i mean there must be a icon in your computer "Hp Director", open that and click on scan document. if that doesnt work, than click on start, got to run and than type "stimon.exe" than hit enter from keyboard. Nothing will happen , just screen will flash for a second, than try to scan. if it doesnt work than you have to unistall and reinstall the software
Aug 07, 2009 | HP Office Equipment & Supplies
How to start a scan? when i press the scan button,the power light flashes green,but nothing happeneds?
If u find this kind of prob then u have scan the required stuff by using ur scanner software if u r using hp then go for controlpanel click on scanner and camera devices and follow the on screen instructions to scan the required one hope this will solve ur prob.
Jul 07, 2009 | HP Ruggedized DC Car Adapter for HP...
Lexmark xx6690 will not scan?
Follow these steps and let me know what happens, please.
Don
2 From the printer control panel, press .
Scan to appears on the display. You can send the scanned image to a computer, flash drive, memory card, or
to a computer over a network.
If you choose to send the scanned image to the computer:
a Press .
b Wait until the printer has finished downloading the scan applications list.
c Press the arrow buttons until the application that you want appears, and then press .
d Use the arrow buttons to select the quality and original image size, and then press each time you make
a selection.
e Press .
Scanning
Jul 04, 2009 | Lexmark X4650 InkJet Printer
Kodak easy chare 5100 scanner
kodak is the worse i have the same problems just wait till you need new ink
Aug 25, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Hp 3380 scanner issue
I SUGGEST DELEATING SCANNER FROM YOUR SYSTEM AND RELOADING THE SCANNER DRIVER FROM THE INSTALL DISC THAT CAME WITH YOUR SCANNER
Feb 02, 2008 | HP LaserJet 3380 All-In-One Printer
596 people viewed this question
old marine
old marine
