Question about Monster Power PowerCenter HT 1000 (MC109091) UPS System
My MONSTER POWER AVS 2000 hums in high pitch noise when I plug the power cord into the wall. What should I do?The 15A CIRCUIT BREAKER in the back is not responsive? Help!!! Confused,Jenny64
2 Suggested Answers
fwadley
  • 482 Answers
SOURCE: Monster Power HT UPS 1000
there is a fuse in it, check it to see if it is bad.
Posted on Dec 25, 2007
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
A NEED A POWER CORD FOR THIS UNIT
Electrical Characteristics (60 Hertz)
Volts Rated: 115
Cooling Amps: 12.0
Cooling Watts: 1,343
Heating Amps: N/A
Heating Watts: N/A
Circuit Rating - Breaker or TD Fuse: 125V - 15A
Plug Face(NEMA#): 5-15P
This unit is 115vac and 15amps draw.
Find a heavy cord. ACE or Home Depoet
May 01, 2014 | Friedrich QuietMaster KS15L10...
Lexmark x2670 won't start up. There is no power and there very quite high pitched hum sound
Hello. First i would check the outlet that its plugged into. If plugged into a wall outlet, check to see if the circuit is tripped. Might have to reset the circuit. Next try a different power outlet. Unplug the power cable from the back of the printer and plug back in. If still not working, try a different comparable power cable. If that don't work either, check to see if the printer is under warranty with Lexmark and call the customer support line and see if they can place service on it. Hope that helps
Mar 20, 2014 | Lexmark Z1300 InkJet Photo Printer
My avs 2000 makes a load hum
One of the 'cons' of the AVS 2000 is that it makes an audible 'hum' when switched on that can be heard during quieter moments. This shouldn't be overly loud though - If it is, I'd take the unit back for replacement / repair.
Jan 17, 2014 | Monster Pro AVS 2000 Automatic Voltage...
Two speakers hum noise
Very doubtful that hum issue is ground potential difference from multiple power outlets as power cord is not grounding type (it is transformer isolated). I do agree that it is good practice to connect all audio equipment to common power strip though, especially with pro sound. Check the audio cords connecting your speakers to the coumputer sound card: 1) Make sure they are connected to the correct jacks and plugged in all the way, 2) wipe the connectors off with a clean paper towel wetted with a smidge of WD-40, 3) replace cords if all else fails. I have also seen solder joints fail on the power supply capacitors (due to vibration) causing hum -- but leave this repair to an electronics technician due to dangerous voltages.
Sep 25, 2010 | Altec Lansing AVS 500 Computer Speakers
I was using my Monster Power PowerCenter PC 800 power surge protector. My tv was running off it, Xbox360, and I had an iron plugged in too. All of the sudden it shut everything off and had a high pitch...
You have to open it up. Check for busted fuse, or a burnt
part. Your Power Center PC800 just experienced an overload. It could have blown an internal fuse at the least
and a burnt out part at its worst.
Nov 14, 2009 | Computers & Internet
High Pitch Noise in 2000 Jeep Grand Cherokee limited
Check your power steering fluid level, and system for leaks. May be a bad p/s pump as well. Hope this helps
Nov 29, 2008 | 2000 Jeep Grand Cherokee
Hum on tv
Your problem is very simply. You have a bad ground. You need to purchase a plug adapter. The AC cord you plug into the wall. Must change from a 3 prong to a 2 prong. You can get this at the 99 cents store.
Best regards
CircuitCity
Nov 20, 2006 | Samsung LE32R41BD 32 in. HD-Ready LCD...
High-pitched noise
Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
Jun 13, 2006 | Smeg FAB28
Monster Power PowerCenter HT 1000 (MC109091) UPS System Logo
600 people viewed this question
Top Monster Power Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Monster Power Computer and Internet Expert? Answer questions, earn points and help others
