Question about Kenmore 78673 Gas Kitchen Range
Kenmore Gas Range Oven not Working Properly
We installed the gas range according to the installation guide for LP gas. We turned the regulator around like it says when using LP gas. The problem is when the oven is turned on it shoots flames up from the bottom of the oven almost to the top. How do we adjust the flame?
  • 6 more comments
  • Brenda Griggs Dec 23, 2006
    Thanks for your help!!
    Catriver,
    That worked!!! Thanks for your help. I have to cook some things to take to my mother-in-law's house for Christmas Eve and didn't know what I was going to do!!!
    Brenda
  • PeePaw Dec 24, 2007
    I have a 7 Year old range, when it was installed the heat protection plate for the Safety Valve was not put back by the installers. Over time it destroyed the Safety Valve WB19K0031. I purchased a new one from Sears for $99.95 and then found out later I could have bought it for half that. I had the same problem as gregsb's and thanks to Catriver just before Christmas on Sunday 12/23/07 I was able to fix my problem. Now we can cook our pies and Ham. Thank You Catriver.
  • cdzgang Jan 20, 2009
    Same problem. Just installed this new stove. Followed all of the instructions to a Tee. Still, very high flame coming up sides of the oven. I adjusted the thing over the needle valve. Not sure if I should try to tighten it more. Seems pretty tight alreadt. I don't want to strip it out.
    Any ideas???
  • Anonymous Mar 14, 2014
    kenmore gas range model 74032
  • Anonymous Mar 15, 2014
    Lp conversion diagram for kenmore model74333 gas range
  • Anonymous Mar 25, 2014
    the flame is mostly orange instead of blue
  • Anonymous Mar 26, 2014
    can you feel a definite stop when turning the spud down?when adjusting a kenmore gas range from nat.gas to lpcan you feel a definite stop when turning the spud down?
    President:
  • 878 Answers
Greg, sounds like your needle valve is not seated. Remove the bottom drawer. Look back to the base of the burner where the shutter air adjustment is. Right under there is the valve which should have a 1/2 inch or 7/16 nut. (I Forgot what size). Turn this nut clockwise until the flame is adjusted to the correct size, should be a nice blue flame. The nut maybe hard to turn because you are seating the needle. Catriver..post back
Posted on Dec 23, 2006
My kenmore gas stove has a light blinking and will on come on. it will work in the sefl clean mode only
Posted on Oct 17, 2010
The oven gas valve will open and ignite the burners if it is taped.
Posted on Dec 28, 2008
Changed maxitrol regulator to lp to much pressure
If you only changed the gas regulator for use with LP (the regulator located at the connection of the gas service) then you still need to change the orifices for all burners, top and oven. Of course I assume this model can be converted for use with LP. Some models cannot. A new range that can be converted for LP typically includes the needed LP orifices. A card with the LP orifices is typically located at the gas regulator.
May 31, 2014 | Kenmore 72132 / 72134 Gas Kitchen Range
Oven is Electrically charged Or Uses LPG domestic Gas?.
GS460 is not the full model number for the range. The range needs both electrical power (120V AC) and gas. The electric power is used for the burner igniter and controlling the range thermostat.
The GS460LEK can be used with either NG or LPG. It came with the NG orifices installed at the factory; a conversion kit needs to be installed to use LPG. (The cap in the regulator also needs to be turned 180 degrees to read LP.) This should be done by a trained installer. Most Whirlpool ranges will have the conversion kit attached on the back of the range near the regulator. See the installation guide from Whirlpool for your model, try https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=m3wLp9EUOpUUfCAXtvB5kw%3D%3D&ddkey=http:OCManualsLiteratureSearchView .
The installation guide for the GS460LEKQ0 is available at https://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%208522956.pdf .
I hope this helps.
Mar 28, 2012 | Whirlpool GS460 Gas Kitchen Range
Gas range converted to LP gas huge flame in oven
was the injectors converted in both and was the regulator converted
Jan 21, 2010 | Kenmore 78530 / 78531 Gas Kitchen Range
I just bought a newer "Kenmore" Gas range. my probem is it is set up for natural gas and i use LP gas. Well it came with the LP gas conversion kit. I followed the directions carefully and the range-top...
Remember this: Crank down and flip. You must tighten down all the top and the oven valve orifices and open all the hutters and flip the nut on the regulator. crank down and flip.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 14, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Can this gas range be converted to lp gas maytag performa
moz-screenshot.pngmoz-screenshot-1.pngTurn off the gas supply.
Locate the gas valve regulator. Unscrew the top cap on the regulator,turn it over and re-install it.It should be marked NAT. LP.When correctly converted you will be able to read LP.
On the Performa all the conversion parts should just be adjustments. Remove the oven racks,remove the oven base pan,remove the oven flame spreader pan to access the safety valve. Take a 1/2 inch open end wrench and tighten the orifice on top of the gas safety valve. Tighten it until it is snug.Remove the top burners and raise the top to access the surface gas valves.Tighten the valve spuds until snug. Re-assemble all parts.Turn the gas back on and lite the burners. Turn them high and low to make sure they stay lit. If any burner is not right tighten or loosen the orifice spud for that burner only. All air shutter adjustments should be full open,
Dec 02, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
LP gas conversion oven flame to big
I did all this and the flames are still huge inside the oven...
May 27, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Convert from lp to natural gas
you need to change the gas regulator (if installed on back of oven),pilot and burner orfice your ready to go.happy new year.
Dec 05, 2007 | Magic Chef CGR3742 Gas Kitchen Range
Nat gas to propane conversion
With the gas turned OFF, you will need to find the gas regulator on the range. It will located in the back of the oven along the bottom somewhere. It's usually a square shaped valve with a nut on top of it. The gas valve orifice is located under the nut. All you need to do is remove the nut, take the orifice out, flip the orifice over and re-install to convert from one type of gas to the other. It should be marked which side is LP (propane) and which side is for Natural Gas. LP will have a smaller orifice opening than Natural. You will want to make sure the orifice size you are using is facing UP, then screw the nut back on the regulator. You will also have to do this for all the surface burners (if you haven't done so already). You will know if you have the orifice turned the wrong way because the flames will be too high, the oven will get way too hot and there will be soot everywhere. Hope this helps you.
Aug 11, 2007 | Sears 61301 Gas Kitchen Range
Flames in oven are WAY too high! Having trouble lowering them.
Did you change the orifice in the regulator? The orifice opening for LP is a different diameter than the opening for Natural Gas. If you've already attempted changing the settings from Natural to LP, you may want to double check the orifice under the regulator cap, or...you may have a regulator problem. You will need to turn the gas off prior to attempting this. The regulator will be located in the back of the oven somewhere near where the gas line connects to the stove. There is a gas orifice that needs to be turned over to change gas settings. "LP" should be present if it is set correctly. Let me know if this helps.
Jul 29, 2007 | Hotpoint RGB745 Gas Kitchen Range
Kenmore 78673 Gas Kitchen Range Logo
915 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
