Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
Oil/gas mixture what is oil mixture for the above ,ounces and ratio
  • 163 Answers
40:1
Posted on Nov 29, 2008
What is fuel mixture on 25 cc craftsman weedwacker
This small engine needs a 40:1 ratio. Use only 2 cycle oil, not motor oil. If you are mixing one gallon of fuel use 3.2 ounces of the 2 cycle oil. This should give correct mixture so you do not get lots of smoke when you start. Take the time to measure. Note: there should be a marking somewhere on the engine about the mixture.
Sep 21, 2014 | Craftsman Convertible 25cc Curved Shaft...
What is the gas / oil ratio mixture for husqvarna 455 rancher model ?
50:1 that's 2.6 ounces of 2-stroke oil (preferably with fuel stabilizer) to one gallon of gas. I recommend using 89 octane gasoline for all small engines. It has little or no ethanol in it, as opposed to the 10% typical in 87 or 86 octane fuel. This will prevent a lot of fuel issues, especially if you are not using the tool daily or at least weekly.
Aug 02, 2014 | Husqvarna "965030298 - 455 Rancher, 20""""...
What is the ratio of gas to oil for a 35cc engine
Mix 3.2 ounces of Poulan 2-cycle air cooled engine oil to one gallon of fresh unleaded gasoline to obtain the recommended 40:1 fuel to oil ratio.
Over a period of time oil will separate from gasoline. To properly insure oil and gas mixture, I recommend thoroughly shaking your oil and gas mixture before refueling your unit.
If the saw is to be stored for longer than 30 days - drain the fuel tank, re-tighten the gas cap, and start the unit and let it run until it stops.
Jun 09, 2014 | Poulan Predator 35cc P3516pr Chainsaw...
My machine overload,what do i do.the cilinder gets oil and the sparkplug is wet
Marthadelafu:
Remove the spark plug and clean it with rubbing alcohol and let it dry or blow dry it. Look at the carburetor. You will see two small screws next to each other. Those are the fuel/air mixture screws. one controls fuel, the other controls air. First check the air filter to see if it is clogged with dirt and debris... if it is, wash it in a soap and hot water solution and let it dry. After it dries out, reinstall it. Then turn the air/fuel mixture screws in GENTLY all the way. Turn them out one and a quarter turns. Check your fuel/oil mixture to see if you have the correct ratio of oil to fuel (most machines run on a 40/1 ratio... 40 parts gas to 1 part oil in other words, 40 ounces of gas to 1 ounce of oil. If your fuel/air mixture screws are one and a quarter turns out, the fuel/oil mixture is correct and the air filter is clean, the motor should start. You will need to adjust the fuel/air mixture screws a little to get the saw running to your satisfaction.
Jan 18, 2013 | Poulan Garden
How much oil do I use per 1gallon of gas for a Husqvarna 223L weed eater?
for a 40/1 mixture use 3 ounces of oil ( 2 stroke) to a gallon of gas for a 50/1 ( which is what I recommend ) its 2.5 ounces to each gallon of gas, if you find that the machine is smoking a little too much,, back up on the oil just a hair,, but I don't think you'll need to
Aug 25, 2011 | Husqvarna 28cc Gas Line Trimmer
Whats the oil to gas mixture ratio for a Homelite 42 cc chainsaw?
Use 2.6 ounces of oil per gallon of gas to give you a 50 to 1 ratio of fuel to oil.
Jun 16, 2011 | Homelite Garden
Oil mixture wild thing
The oil mixture is 50-1 or 2.8 ounces per gallon of gas...
heatman101
Sep 30, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the fuel to oil mixture ratio for my gas featherlight weedeater?
That oil/fuel mixture would be 50-1 or 2.8 ounces per gallon...
heatman101
Sep 08, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
What oil mixture do i use
The ratio is 40:1....that is 3.2 ounces 2 stroke oil (I recommend synthetic) to 1 gallon of gas or....1.6 ounces to half a gallon....A little more oil is okay...it will help rectify any "lean" running condition....Not enough oil is not acceptable under any circumstances.
Jul 13, 2010 | Craftsman 25cc Gas Line Trimmer
What is oil to gas ratio? What type of oil what type of gas/
A mixture of 40:1 would give good performance and protection with minimal smoke issues.
3.2 ounces of oil added to 1 gallon of gas would equal a 40:1 ratio.
Don't use outboard motor oil. Water cooled engines on those.Use a 2-Cycle oil specific to AIR COOLED engines.
Hope this hepls!
Sep 26, 2009 | Poulan Featherlite Gas Blower, with Low...
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
429 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
