Question about HP Compaq Presario V2000 Notebook
Screen dulls when plugged in
When i put the power point into my laptop the screen goes very dull is there any advice you could give me to bring back the screen brightness thankyou
  • Anonymous Mar 31, 2014
    only when plugged in
  • 76 Answers
Well...dull screens are usually due to either low power or a bad video card..check the power supply to be sure its charging the battery
Posted on Nov 21, 2008
Usually when i plug in the charger to computer the screens gets brighter, it no longer does that, my screen is very dull and not bright how can fix?
you can change that in power settings right click on the battery bottom right of the screen hit change power settings u will get options u want to change power settings look at the options you want to make it stay brite all the time right now you have it set to be brite only when plug is in change the option when its unplugged to brite also
Aug 10, 2012 | Acer Aspire 7741z
Ce32ld33 tv sanyo turns on stays on for couple hours then turns off and stays off until an hour or 2 then switches on .i try to switch it on after about 20 mins but the little blue standby light goes...
There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance. The best way to check for loose connections is to tap lightly when the set is powered on, if there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, and use a good soldering iron to solder all suspected points. Sometimes the fault occurs when the set warms up; if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault. It can also be related to WEAK ELECTROLYTIC capacitors as the value can reduce in time.
Oct 04, 2011 | Sanyo Televison & Video
My boss LG laptop screen bcame dullness plz tell me how to resolve this problem
Check whether the screen becomes dull when it comes to Windows.. (i mean if we turn on the laptop, screen should be normal and it becomes dull when it enters windows) in this case check for Battery settings (power adjustments).. if you find it is totally displaying dull, monitor should be replaced
Jun 17, 2010 | Acer Aspire One PC Notebook
My neices travelmate 2200 screen seems to be rather dull ,even with power unit plugged in and switched on
They are all like this. You can try disabling the dimming function in the bios but it won't help. The screen is simply dull.
Oct 14, 2009 | Acer Travelmate 2200 Notebook
I have a question about working on a 67' Barracuda. I need to know how to bring the shine back in a dull shot on the car??? I used rubbing compound and I wet sanded it and but put clear coat on it and it...
Likely the original paint on the car is just oxidized too deep. At this point, your best (and likely only) option is to re-paint it. I know that's not what you want to hear, but that's the facts, jack.
Good luck with it...always liked that car.
Jul 17, 2009 | 1997 Plymouth Neon
Dull picture on laptop but cursor is still bright
The screen brightness is automatically adjusted by your laptop's Power Management configuration in the Control Panel. Depending on your laptop's brand you might not only have the Windows power management, but also a proprietary power management application within the control panel or in your Start Menu programs usually listed under your computer's brand name. For example a program folder called "Toshiba" under Programs for a Toshiba laptop. Anyway, I would start there. Usually you can set up the screen brightness according to whether or your computer is plugged in or working on battery. Good luck! :)
May 22, 2009 | Toshiba Satellite A105-S4004 Notebook
Dull screen
along the bottom row of keys there should be one lable function, along the top row (usually the F- keys) there will be one that looks like a star and another one that looks like a black star, hold the function key down, click on the whiter star and the screen should get brighter.
Dec 09, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Screen goes dull at times
The dulling picture really sounds like a lamp failing. You would need the sony lamp xl-2100u
The ghost image may be easier to fix, sometimes as lcds age you will get a slight shift in a color. deep in the sony menu there is a parameter (menu-setup-imageshift) that will give you 3 levels of correction, this may solve this issue.
Dec 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Dull screen lighting
There may be a bios setting to adjust the screen brightness or a utility installed in Windows - What brand and model laptop is it???
Jan 12, 2008 | Computers & Internet
HP Compaq Presario V2000 Notebook Logo
83 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
