Motorola RAZR V3 Cellular Phone
Problem for Motorola RAZR V3
Drop Razr and inside display screen is white
By Pinkrazr on Dec 22, 2006
I dropped my razr and i can't get the inside diplay screen, it's white ever since i dropped it. The phone itself work fine, and the ouside screen is okay. Can someone tell me how to fix it.
Thanks! :-)
Solution #1
posted on Jan 10, 2007
Somewhat Helpful)
repairguy
Rank: Guru
Rating: 91%, 243 votes
there is 1 or 2 flex cables in the phone on the flip part. ( display board) you an check & make sure those are properly seated. open the flip you will find 1 small round piece of rubber in each corner underneath is a torx 5 or 6 screw. remove those. then very gently using a flat screwdriver. pry appart the phone. u must start at the hinges. on both. sides. with the screws out, only 4 clips hold the cover on.
hope this helps.
Was this helpful?
Yes
No
Solution #2
posted on Feb 18, 2007
Not Rated)
rioscrx
Rank: Apprentice
Rating: 0%, 0 votes
hello, this guy doesnt know what hes talking about ive been fixing razr for some time now and selling them on ebay, so this is a really easy fix hes right you have a promble with the flex cabe the main one to the screen, what you need to do is remove the battery+Cover and and the two screws that hold the back part of the phone which were the main brain is, once that is open you will see the main flex cable that heads up to the main screen, that is the one you want to look at if you look under what that sits on its the shiny part, this is kinda hard to discribe, but all you have to do is bend that peice that it sits on up so that it get a concetoin. hope you understand, if you want i can send you picture step by step. email me at rioschris@hotmail.com
Was this helpful?
Yes
No
Popular Solutions for Motorola RAZR V3 Cellular
Questions and Unsolved Problems for Motorola RAZR V3 Cellular
Do you recommend Motorola RAZR V3?
Answer
Answer
keys don't work. On and off works. Receives calls. Can make calls with Bluetooth.
Answer
Wallpaper and icons are upside down on phone..,
Answer
why do i have no display on any of my windows
Answer
how do i set auto signature on my at&t razr v3 BZ60
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Motorola RAZR V3 Cellular...:
Top Cellular Phone Experts
Rank: Guru Guru
Solutions: 917
Experience: Having problems myself and learning from my mistakes . Plus looking up information on the web.
Ask Me
Find more Cellular Phone Experts
Top Cell Phone Repair
CPR
(800) 818-8800
We offer hight quality OEM such as travel charges,...
CPR
(918) 955-1100
The Cellular Phone Repair Center opened in March...
cellularphonerepaircenter
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
