Question about Logitech Harmony 890 LCD Remote Control
Our harmony has stopped working the equipment.
OUR HARMONY 890 SUDDENLY WILL NOT TURN ON OR OFF ANY OF OUR EQUIPMENT.  IT IS CHARGED.  NOTHING HAS BEEN MOVED
  • Anonymous Dec 26, 2008
    Same thing here. One day it just stopped working the AV equipt.
The signal from my remote seems to be weak . Works only when upclose to system
Posted on Jun 04, 2009
  • 23 Answers
Try downloading the program again.
Posted on Apr 24, 2009
Display on 890 remote is faintly lit. I have a new battery and cradle, have updated remote (firm/soft)....nothing. Remote does work, but you can't see display, so you are enabling the 'force'...
Not worth repairing, contact harmony and they will give you a coupon for 50% off a new remote. The 900 replaced the 890, although I prefer the 890 the screen is a lot better on the 900.
Oct 30, 2011 | Logitech Harmony 890 LCD Remote Control
I have a harmony 890. it turns all the equipment on/off properly except the TV (a Vizio). this works intermittently. suggestions?
Hi. Try learning the power commands for your Vizio TV from the original remote. The power commands that the Harmony remote is using may not be correct. The following tutorial by Logitech will assist you with this.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9605
Regards,
D
Aug 26, 2011 | Logitech Harmony 890 LCD Remote Control
Remote stopped working so we bought a new battery and it turned on for awhile, now it's totally dead. Could the contacts on the base be worn out so it doesn't charge?
This seems to be a common problem with the 890. In fact, Logitech have an entire page dedicated to charging problems with the 890:
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/9169/kw/charging
This page contains a troubleshooting guide and if you are still unable to solve the problem, it lists the information you need for contacting Logitech support. Sorry, but there is too much information to paste it all here.
Hope this helps.
Regards,
BElectric
Nov 19, 2010 | Logitech Harmony 890 LCD Remote Control
The remote just stopped charging
Please click on the link below for a troubleshooting guide for charging problems with the 890 remote:
Sorry, there is too much information to paste it all here!
Hope this helps.
Please rate this solution if you find it helpful. Thanks!
Nov 03, 2010 | Logitech Harmony 890 Universal Remote
My 890 is no longer working correctly. It won't
I had a similar issue and only needed to "re-configue" the remote... Basically, just try plugging it back into a USB cord ( connected to your computer) and go to the original programming home page and click the "Update button." It will re-program your remote as if it was new.. Over time your Harmony may lose or forget the frequency of your various components. This happened to me. Also, make sure the remote has a full charge while you're programming it. Give it a try !
Feb 07, 2010 | Logitech Harmony 890 LCD Remote Control
My Harmony 890 turns everything on and off, but when I am in PVR it just suddenly stopped letting me use any of the buttons (ie, menu, guide, channel, volumn). what do I do
I would hook the harmony back up to your computer and the update the remote. If that does not fix the problem then I would down load the firmware and then update your remote. If you still have problems I would check your check your buttons in the program. You can do this by logging onto your Harmony account, select the Activities tab and press on the “customize buttons” under the activity you are trying to fix. Scroll down to the menu exit info buttons and see if there assigned to the correct device and correct command. If none of this works I would see if the menu button works in another activity like Watch TV or Watch DVD.. If the menu button does not work in another activity then the remote may be broke. If it does work then I would try the original remote with your DVR and see if that works. If that works then I would manually teach the harmony remote. Harmony calls this “Learn command” It’s a button in the lower right corner while in the “customize button” tab.. If none of this works then pull out your 45 and put a hole in it.
Hope this helps
Nov 28, 2009 | Logitech Harmony 890 LCD Remote Control
Harmony 890 just went dead. Nothing. Nada. Not
I have an 890 also. I've found that the remote doesn't always charge when it the charger. I have to put a rubber band around it and make sure it shows that the the battery symbol on the display is showing that it charging. Or the battery isn't taking a charge anymore and I'd try to replace it. Doesn't really hold a charge very long either.
Oct 27, 2009 | Logitech Harmony 890 LCD Remote Control
My Harmony 890 is blinking and won't do anything!!
try doing a firmware upgrade after booting your remote in safe mode
Jun 03, 2009 | Logitech Harmony 890 LCD Remote Control
Changes 2 channels at a time
I can help you with your Logitech Harmony 890 remote control.
The Logitech Harmony 890 remote control is programmed through the
Harmony Windows Setup Software.
I recommend resetting it up with your components to get rid of the two channel problem.
Once installed, you will simply run the program and select the devices you would like to control from menus. This program finds the right codes for you and loads them into your remote control.
You can get a copy of the Harmony 890 Manual by clicking here.
I hope that helps.
_____________________________________________
Harmony 890 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Harmony MAC Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Nov 25, 2008 | Logitech Harmony 890 LCD Remote Control
Logitech Harmony 890 LCD Remote Control Logo
429 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
