My clock will not display the outside temp. after battery replace
Living solutions model #628123 I replaced the battery in the outside sending unit. The sending unit red light still blinks. I can't find the owners manual to know what I did wrong. I could use any help you have. Thanks Allen
  • Anonymous Apr 26, 2009
    I have the same problem with this clock. My clock projects the inside time but ot the outside time.
  • 4 Answers
Try replacing the AA batteries in the main clock/display unit - that worked for me, then you'll probably need to press the reset button next to the AA batteries, and maybe the reset button next to the AAA batteries in the remote unit - press reset on the main unit first. My remote is now registering and the red light is flashing, but I don't know how to reset to the correct time and date - it's been scanning for a while and found nothing...
Posted on Aug 27, 2009
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
Can't get outside temp on my atomic clock
If you still have the instructions read up on pairing the transmitter to the clock. You'll need to do that every time you change batteries on the outside transmitter. If you don't have those instructions , go to the clock's web page to get the manual for your model of clock.
Sep 23, 2014 | Home
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
I have no outside temp. reading on my clock.
Remove batteries from the clock and the outside temperature transmitter. Put the clock and the transmitter next to each other, then install the batteries in both units. This should fix it. If not, you have a bad tempurature sending unit, or a dead battery in the sending unit.
Jul 06, 2009 | SkyScan 86709 Atomic Wall Clock
Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in.  Unfortunately this also messed up the clock's time and date.  This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
Dec 30, 2008 | Oregon Scientific Lwb0997110113004...
Changed batteries
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Sep 07, 2008 | SkyScan 86709 Atomic Wall Clock
Temperature sensor
I have this clock and just finished getting it all working again. At first I kept messing around with the AAA batteries in the remote unit, finally realized there were AA batts in the back of the main clock/display unit. Replaced those, pressed the reset button next to the battery compartment. Pressed the reset button on the remote unit (it's under the back lid next to the AAA battery compartment). Little red light on the remote unit started flashing and remote temp showed on the main display. Then you have to wait for atomic time to reset itself or set the time and other display options manually - I kept messing around with the various buttons until I figured out how to do this (atomic time never reset) - start by holding down the smaller "AL" button on the top next to the big snooze/light button, use top two side buttons for up/down, use the AL button to go to next setting.
Aug 15, 2008 | Honeywell RC182WR Atomic Alarm Clock - Red
329 people viewed this question
 Grubhead
Grubhead
