Question about Microsoft Xbox 360 Console
Xbox 360 starts up randomly, tray opens and closes spontenaously
My xbox 360 starts up sponteanously. When it's on the the dvd tray opens and closes continously. What can cause this problem?
  • 3 more comments
  • markthissen Nov 21, 2008
    I didn't open it. strange isn't it? There's actually no problem with reading the disk. It just reads the disk and launches the game if it has the chance(i mean when the tray didn't go open and close in the meantime)
  • markthissen Nov 22, 2008
    wow thanks! , for putting all this effort to my question.
    As fot the spontaneous switching ON (only On, no spontaneous off switching), it seems that Xbox360 in general can be powered on also by pushing the tray eject button. That's why i think the problem concentrates on something that has to do with the tray, maybe as you say, that something is blocking the rail. I saw another problem very much like my problem on this forum. The given solution for that problem was to open up the Xbox 360 and get to open the dvd drive, in the spindle where the game rest in the middle of your spindle you will normally find two magnets. They might have come off. He suggest to superglue them again and the problem should be fixed.
    What do you suggest, should i try this?
  • Anonymous Dec 18, 2008
    same problem it sux and im out of warranty
    I have the same problem
  • Eddie Edmondson Dec 31, 2008
    I have this exact same problem and I also have another xbox 360 so I swapped the DVD Drives and that still hasn't fixed it. It's not the DVD drive that's the problem it's something else. Any Help?!?
I have the same Problem my X box came on spontaniously and the DVD tray opens and closes non stop till I get the RROD code. it will play games and DVDs only if it stays closed long enough to start then it opens up and starts the cycle all over. I opned up the DVD drive and can't see any thing blocking any thing I even used a Q tip to pit a little oil on the screw meckanisim that opens the drive and blue it out with compressed air. and it did not fix the problem I am going to have to buy a new drive my Drive is a Philips drive.
Posted on Oct 20, 2009
  • 63 Answers
Have you opened the Xbox and tried to fix something?
Posted on Nov 21, 2008
  • Collin Haugen Nov 21, 2008
    Have you tried getting some compressed air and blowing out the DVD drive? Maybe something is blocking the rails or the gears and its forcing itself to open/close. As for the spontaneous ON/OFF, I have no clue. I'm a technician at Play-N-Trade in Spring, Texas, and I'm asking around at our other stores if they have seen the problem. Sit tight and I'll try and help out your situation.
  • Collin Haugen Nov 22, 2008
    Only if your Xbox is out of warranty would I suggest that. I would try that and then post your results when your finished.
360 tray opens and closes by itself
broken faceplate or broken dvd tray. Call MS support.
Mar 20, 2010 | Microsoft Xbox 360 Console
When we put disc in tray keeps popping out and saying close tray.
There is a magnet inside the DVD drive that has dislodged and is now stuck to the top of the drive, causing the tray to keep popping out.
To fix this yourself, you're going to need to open your xbox, open the DVD drive, and glue that little magnet back in its place.
Follow this guide to do it.
Dec 14, 2009 | Microsoft Xbox 360 Console
Tray won't open flashes centre green. Opened
The center of your Xbox 360 has malfunctioned due to overheating which has caused the tray to have various problems. The solution? Simple! Replace the hard drive or send it in to Microsoft!
Nov 26, 2009 | Microsoft Xbox 360 Console
Not playing game just say open tray
Hi, this is a pretty common problem for the xbox 360's. It is caused from the laser either becoming dirty or the laser is starting to burn out. The first thing I would try to do is open the disc tray and then unplug your 360. Then try taking some canned air or an air compressor and blow it into the DVD drive to clean off any debris from the laser. Plug it back in and try to load a disc. If you still get the open tray error, then your laser is starting to burn out and is in need of replacement. The xbox 360 uses the laser to determine whether the tray is open or closed, unlike the PS2 or PS3 which relies on switch. So, if it becomes dirty or burned out it can't read if the tray is open or closed.
Sep 02, 2009 | Microsoft Xbox 360 Console
Open tray
Hi, this is caused because your laser is either dirty or starting to fail. Take your 360 and turn it on, then open the tray. As soon as the tray is open, unplug your 360. Now with the tray open use a can of compressed air or an air compressor and blow out the DVD drive .And see if it is because your laser is dirty. Take your 360 and plug it back in and try putting a disc in it. If it still gives you the "open tray" error, then your laser is not reading the disc and needs to be replaced.
Aug 21, 2009 | Microsoft Xbox 360 Console
My xbox 360 sounds ill
Strangely enough inside any of those game boxes is a simple DVD reader driver like for a PC.
It can be replaced.
First I would try cleaning it with a spray air electronic cleaner or any sort of DVD reader cleaner.
Dust will accumulate in them even with the little door that covers it when closed.
If that's not the case, the sensor can also be cleaned with alcohol and a q-tip if you take off the case or the motor may be going bad ont he DVD drive itself.
Start with the basics.
Jul 23, 2009 | Microsoft Xbox 360 Console
Put cd in then it says open tray wont play cd
Hi. this open tray code is caused by a failed limit switch that is responsible for sending a signal to the optical assembly, confirming that the tray is totally closed and ready to read the disk. this switch is part of the drive and, it is recommended to replace the DVD-ROM drive in this case.
Jun 03, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
1,996 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
