Question about Dell E176FP 17" LCD Monitor
ON/OFF button on my Dell Monitor E176FPb is stuck
I do not know how to open the monitor. The on/off button does not work. It is "dead" (does not go in or out). I know that the button is supposed to contact a "thing" and that is what is wrong. If I could open the case I could solve the problem myself. There are two "ridges" around the monitor that look like either one could be pryed open, but I do not know IF or WHICH one to attempt. My warranty has expired so opening it to repair is not a problem. I do not want to waste money to buy another when I can fix the problem! Thank you for your help. Tom
  • Tom Nov 21, 2008
    I figured it out without destroying the monitor. There are tiny slots around the outside of the monitor that will allow a kitchen butterknife to twist the plastic....then get another butterknife and twist one slot adjacent to it and continue until apart. Cheap but effective.
    Champion:
  • 293 Answers
Hey...Tom,
To open this monitor, it's from the front edges of a bezel. Laid it down screen face up and placed a piece of soft cloth on top of the screen to protect from smudged. Then with 2 hands using all 8 fingers lifted the edges of the bezel from the screen slowly with some force to it. Do the same on the other sides until it came loosed. If you happens to got some smudged on the screen just damped a soft cloth or paper towel with tap water and cleaned it. Have fun!
Posted on Nov 22, 2008
E176 manual service
This information might be available at an electronics repair shop.
Mar 30, 2014 | Dell E176FP 17" LCD Monitor
No power
Have tried checking the power cables or changing it? How about the power source also? If yes? There might be problem on the built in power supply of the monitor.
Jan 06, 2014 | Dell E176FPB 17" TFT LCD Flat Panel...
Black out
In most cases, the problem is caused by faulty filter capacitors in the power supply. You can open the back and replace the capacitors that look bulged and leaky or replace all the electrolytics in the power supply board. If it continues to turn off like that, the tubes are at the end of their service life.
If you have no desire to buy a new monitor at that point, the tubes are able to be replaced, but for overall simplicity- just order the replacements aet up for your specific monitor from Dell. Make sure they have the boots, the plastic attachments and connector for "drop in" use. If the tubes require connectors to be soldered on, it gets tedious and is not worth it from a standpoint of shop time..
Feb 12, 2012 | Dell E176FPB 17" TFT LCD Flat Panel...
E176FPb Monitor stays on for 3to 4 seconds then cuts out.Press on button screen reappears then cuts out again after several seconds
It may have bad caps, transistors, fuse. See failed DELL monitors here to get some idea on what to look for:
http://s807.photobucket.com/albums/yy352/budm/DELL/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Replacement board: http://www.lcdrepair.us
http://www.lcdrepair.us/E172fpbvideo.html
Jun 30, 2011 | Dell Computers & Internet
Main Menu Keeps Popping up
The only suggestion I could make would be to consider opening the monitor up and inspecting the control panel for a stuck button or damaged control. While this is feasible, the real question is whether it is cost effective if repairable. The ever decreasing cost of equipment is making monitor replacement very affordable, even if it is filling our landfills with junk.
Apr 12, 2010 | Dell E173FP 17" LCD Monitor
Monitor turns off after a few seconds. Have to
my_secret_mb, Stop pressing the ON/OFF switch! It's broke!!! The unit's internal power supply will need some work done on it. Unit will need to be evaluated first!! This is a common problem for ALL LCD monitors. If unit out of warranty period, then you will need to do some intense speed reading of my higher page number responses in my fixya profile to understand the problem your cold-cathode-fluorescent-lamp back-lit lcd monitor has and the options that you have. You will also need to base your decision on the age and total number of "ON" hours unit has seen during it's lifetime. Do not dispair or feel sad about what has happened to your monitor. A low side guess would be 50 units/day fail world-wide. Your unit may have failed filter capacitors or possible failed solder joint on printed circuit board. (thermally intermittant) I hope this helps you. 12fixlouie north of "Windy City" USA
Apr 02, 2010 | Dell E176FPB 17" TFT LCD Flat Panel...
Stuck power button on Dell Monitor
Guru Kenny G, There are thousands to choose from in the DigiKey catalog, both through-hole and surface mount types. You should be able to measure the dimensions and order one that will work. Also try
Jameco and Newark Electronics. 12fixlouie
Mar 22, 2010 | Computers & Internet
The brightness control window keeps opening on the
The Up or Down button on your Flat Panel monitor is stuck. Please contact Dell Tech Support to have the monitor replaced if this is still within warranty
Jun 13, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Cannot raise vertical height after pushing button on back of monitor (button stuck in)
With the monitor in the lowest position, push down slightly on the monitor and push the button in. While holding the button in you should be able to raise the monitor with your other hand. This worked on the one I have.
May 01, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
Dell E176FP 17" LCD Monitor Logo
320 people viewed this question
Alun Cox
