Question about PANDIGITAL (DPF802) Digital Picture Frame
Picture playback on the pandigitial 8'' 1GB frame - PAN8056W02T
My fram has about 5,000 pictures loaded on it. When try to chnage the sequencing of the files via windows explore the files seem to get resequnced based on file name but when I disconnect the frame from the computer and turn it on it seems that the frame starts the slide show wit the picture that was added first. Then everytime the frame is turned off the slide show starts over wit the first picture loaded. The shuffle feature takes about 30 seconds to switch from picture to picture so I do not want to use that feature. I also seem yto get this message code displayed at the bottom left of the screen (which I do not think was there before) A08_05_06_PD_CPT08.
Any suggestions as to how to fix the picture sequence and to save the place the frame left off each time the fram is turned on?
Thanks-
  • 6 Answers
SOURCE: SEQUENCING PICTURES IN BUILT-IN MEMORY
The DPF-80 has now way to sequence pics. The only way for them to play in an order is add them one at a time to the frame via the computer. The files can not be batch sent, such as sending a whole folder at one time. Windows will dictate the order in which they are transfered if you do it that way. Transfer one pic at a time. Tedious, but it works
Posted on Dec 11, 2008
SOURCE: I have a Samsung Digital
I have a different model samsung but try going to Settings >> Options >> Autofit Portrait Photo and turn that feature off.
Posted on Jan 03, 2009
bjamieson083
  • 15 Answers
SOURCE: Digital Picture Frame Shows Black Bars
The nature of 16:9 basically means that you will be losing photo information in normally framed 4x5/5x7 photos. There is no way to fix this because the frame size of 16:9 is wider than 4x5/5x7. The options the frame offers are the only options to make your photos fit. Either crop, or distort.
The best solution is to keep this in mind when taking photos from now on and assume you will be cropping the top and bottom of the image.
As for the photos you have already taken, the only viable tactic to take is to reframe them for 16:9 yourself. You can download a free photo editing application like "GIMP" to do this. Create a new project that is 800x450 pixels. This will give you a 16:9 canvas. Next drag your existing photos into this canvas and move it around and resize it until you find a suitable framing for your picture.
Unfortunately it seems that as 16:9 solidifies itself as the new screen standard people are finding that shooting photos framed for 4:3 or in portrait dimensions are not translating well to this new standard. You may even want to consider returning this frame and looking for a 4:3 aspect ratio frame if cropping/resizing is not acceptable for you. Good luck!
SOURCE: unable to load more than ~50MB into df780 digital picture frame
I had the same problem on a 128 mb memory. I figured out that it can only load a certain # of objects/files. So I started from scratch, and I created a new folder in the pandigital and copied all the files/photos/mp3's into that 1 folder. Thus 1 object. I was able to fill the entire capacity after that. I can't believe I actually helped solve one! I hope it works for you...
Posted on Jan 10, 2009
  • 13433 Answers
SOURCE: I tried to install pictures from my computer to
Hey,
the frame should show up in computer or "my computer" in start menu or on the desktop.
It will be named as "Removable storage device" inside The computer folder.
Double clicking on it will get to its contents, and you can copy pictures in there. Let me know what you see in there.
Posted on Nov 29, 2010
Where can i get a ownermanual for my pandigital 8 inch digital photo fram
visit www.driverguide.com , sing in , search, download and install all driver that you want, just put in searcher your model and searchit
Aug 06, 2010 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
My didgital frame will not turn on. ADS-18H-4 0918G
My didgital fram will not turn on. ADS-18H-4 0918G switching adapter does have a slowly pulsing green light. But will not turn on the picture frame. Where can I get a replacement or how do i get it to work
Mar 22, 2010 | SmartParts SP15MW (092566981886) Digital...
Do not know how to transsfer pic fromcomputer to the Kodak pic frame
On one side of the frame there should be memory card slots and a usb slot.
two ways to do it, take the memory card from the camera and put it in the frame.
Or down load the camera to tyour computer and then with a usb cable upload the picture fram with the pictures you want
Or from your computer load a memory card and then stick it in the frame
Feb 20, 2010 | Kodak EasyShare SV811 (8858946) Digital...
How to repair a digital picture frame
My photo frame comes on but the blue light on the side flashes when it stops it says Please wait on the frame and doesn't come of that :(
Anybody know how to fix it??
Thanks
Jul 25, 2009 | Westinghouse DPF-1021 Digital Picture...
Transfer pictures
Dear remove the write protection on your disk to eliminate this message, you computer or fram memory is write protected. check the properties of those and remove if they are write protected. this is resolve your issue.
Good luck in correcting your problem.
Best regard
May 27, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Where to get power supply?
http://www.shopping.com/xPC-GeCube-Pandigital-8-Inch-Digital-Photo-Frame-with-2-Interchangeable-Frames
Mar 09, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
I lost instructions to my Optimus 7" Digital Photo Fram
You can change out your pictures by having an XD or SD Memory cards if you have a card reader for your computer plug in the memory card put the photos on to it that u want on ur pic frame and plug it in to the xd/sd card slot on the left hand side of the photo frame and there u go. If you want ur pics off the internal memory u can transfer them from the frame to the card via the options button or menu button that is.
Nov 30, 2008 | PANDIGITAL 7-Inch Digital Photo Frame with...
7 inch digital picture frame
Where do I go to have my picture fram serviced???? It has worked fine. Then it shut off and will not turn on again. I pulled the power cord and left it off for a couple of days and then plugged it back in. That had worked before and now does not.
Jul 15, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Print a movie fram
Hi , try to freeze a good frame before you print a picture , you may open to adobe for editing picture there are many option to make picture good and beautiful.
Jan 14, 2008 | Olympus Camedia C-50 Zoom Digital Camera
PANDIGITAL (DPF802) Digital Picture Frame Logo
347 people viewed this question
Top PANDIGITAL Photography Experts
LP
Bill Eager
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
