Question about Microsoft Xbox 360 Console
Nintendo xbox power light is flashing green and yellow or orange the center light is flashing green and every time i close the disk holder it opens up again
  • 63 Answers
Have you opened the console and tried to fix something? or taken it somewhere to have it fixed?
Posted on Nov 21, 2008
My XBOX 360 will not turn on. The power bar has a green light but pressing the eject button or power button on the console will not turn it on. We have tried plugging it in to a different outlet but that...
Hi christoph52893,
If the Xbox 360 power supply light is green, this means the Xbox 360 power supply is ok and it is an issue with the console itself. You will need to contact Xbox 360 customer support to service your console. However, if you have a flashing orange or yellow light, it means that your console is fine but instead there is something wrong with your power supply. It indicates that it's not getting enough power.
Hope it helps.
Thank you for using FixYa.
Jul 05, 2011 | Microsoft Xbox 360 Console
3 red lights, will not power up, will not play disks
check the power brick orange and green are good red and yellow are bad if that dont help you might want to try a new outlet new power brick or request a repair call 1-800-4my-xbox
Dec 08, 2010 | Microsoft Xbox 360 Console
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
Cannot open the disk and cannot read the disk as well. The green light at the center of the ring always blinking
Hello
If you only get a flashing green light on the center while you turn on the console. You should get a green light going in a circle around the center light, (the 4 other lights, that can turn red as well (famous Red Ring of death))
if you don't get any red or green lights around the flashing center ring, then the console is not able to turn on / boot up properly and is in need of repairs, check the powersupply led, what color is it? it should be green when you power on and orange when not in use.
Jun 08, 2010 | Microsoft Xbox 360 Console
Xbox power light blinks and freezes xbox
That flashing green light meens there is a problem with the power to you DVD drive. the power is being interrupted. ie, when you have power the welcome screen will load and when it doesn't it will shut off. you don't have continuos power. For example if you have the power cable unpluged and then plug it in with the power on the xbox will reboot. Check the wires and the port on the motherboard if all is ok you need a new drive.
Jun 24, 2009 | Microsoft Xbox 360 Console
Wont Boot Power Light Flashing orange
onbord video maby might wann add pci card video see if u get screen ok thx nick
Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
Nintendo xbox
yo you mean like traffic lights green, yellow red or am i going bananas bananaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Jan 16, 2008 | Microsoft Xbox Console
Disk wont open or close
well i had the same problem with my xbox is i opened the faceplate and pressed the button and if that doesnt work u will have to wiggle it around a little bit if it comes out what u need to do is take some WD-40 and spray some on a cloth or something to wipe the sides of the tray and the silver part of the tray and open and close it a couple of times if it opens and closes put the faceplate back on and it should open and close now
Nov 19, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
117 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
