Question about Pentax *ist DL Digital Camera
Flash won't work
I have a Pentax IST DL 2. I've put fresh, high-capacity batteries in it. However, when I pop the flash up, it doesn't work - and the battery meter suddenly says the batteries are empty. It's always previously worked with these batteries. Any advice? Thanks Greg
Try in custom menu I think. Switch shutter release whilst charging firmware switch whilst flash charging a couple of times. Had sinilar thing with ist DS after firmware update.
Posted on Dec 20, 2007
Pentax ist d - fresh batteries, no display, nothing. Where to start troubleshooting?
Measure batteries to make sure they are 'fresh' I have run into many bad 'new' batteries. And if they are the same brand people sometimes put the old ones back in by mistake.
Other than that without a lot more information there are just far too many things that could cause this problem - from impact to water damage to circuit failure.
Oct 23, 2013 | Pentax *ist DL Digital Camera
Built in flash fails to work
Simple. You have a busted Xenon bulb for the internal flash. Replace it, your problem should be fixed...
Jun 08, 2010 | Pentax *ist DL Digital Camera
Flash not discharging
its seems to me that the alignment of your flash setting in its cubicle has been disturbed, possibly by the camera being pressed in your bag. if you cant get it to operate normally, I suggest that you get it done professionally by Pentax.
The reason I am saying this, is cause firstly Pentax is good and branded camera. The settings and all teh mechanism's of this camera are very delicate and you will only damage something within it by forcing your flash out everytime you want to use it.
May 11, 2008 | Pentax *ist DL Digital Camera
Pentax ist Dl
Sorry no solutions, but...I am having the exact same problem!
Feb 28, 2008 | Pentax *ist DL Digital Camera
Compatible Flash Units
pentax istDL does not support TTL flash metering unlike most of the other pentax DSLRs. You need a flash that is P-TTL. How annoying hey? I was pretty bummed, but it made me learn to shoot fully manual...
i think that there is only one P-TTL flash on the market at present. (AF540 or something)
good luck...
Oct 16, 2007 | Pentax *ist DL Digital Camera
Flash on ist DL
Looks like its true... Another major disadvantage. Removing TTL means removing one more hardware piece - TTL sensor. Pentax removed almost every nice feature, which needs some aditional or more expensive hardware: no TTL flash, less AF points, pentamirror... Seems like I bought Ds right in time.
Sep 08, 2005 | Pentax *ist DL Digital Camera
Can *ist DL do High-Speed/Wireless Flash?
According to the manual (page 153), the DL DOES support P-TTL flash, with the built-in or external flash, but only supports high-speed flash with an external flash. What I'm wondering is, what is high-speed sync flash useful for? The only thing I can think of is fill-flash outdoors.
*istD pop-up flash problem
Not sure if you try fresh Alkaline battery. Try it if you havn't already. Fully charged batteries, how do you know it fully charged? The "charger said so"? Your batteries or charger might give you a fault peak reading. Try fresh battery or AC adepter and go from there.
Sep 08, 2005 | Pentax *ist D Digital Camera
On Camera Flash Problem and Lens Question
According to Pentax, the pop up flash does greatly reduce battery life. So, if you want them to last longer, use an external flash. The built-in flash is too low powered an too prone to produce red eyes to be of much use anyway. Any lens that goes from 28-300 is going to be much less sharp than one with a shorter zoom range, even if the lens designer uses such heroic measures as aspherical elements and LD glass. Consider the Tokina AT-X 24-200mm f/3.5-5.6 lens as a very good alternative to the Tamron.
Pentax *ist DL Digital Camera Logo
184 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
