Question about Edirol UA-25 External Sound System
Problem Edirol ua-25 on Mac OS X Leopard
I have a problem when i run my Edirol ua-25 on my Mac: When I playback my music on iTunes i can't hear any music, just an static noise and distortion. I have downloaded the ultimate drivers version from Edirol Official Web page but the problem persits. Please, i need really help!!!. What can i do? i can see some people with the same problem, maybe some of these people could resolve it. i guess you can help me. thanx a lot!!!
  • 55 Answers
SOURCE: Edirol UA-101
This could be a software/driver conflict from something you recently installed 4 weeks ago. I would see if there's an updated version of the driver to fix the issue. If not, retrace your steps and see if you possibly installed anything that could be causing the conflict.
Posted on Aug 23, 2006
make sure, if you are using windows you have the right sound card settings (control panel->audio and sound devices or however) as mentioned in the manual. Also, using sonar LE make sure to have correct settings (options->audio settings). i had trouble with playback too but now everything's working fine. in my sonar settings i use the ASIO driver mode, and mark 'share with other programs'. make sure the right sound card is selected too (options->audio->drivers) and then it sould appear in the advanced window (as for the playback and the record timing master). other possible solutions might be in the options-> midi devices window, though i doubt that. I hope this can be helpfull. Good luck! btw, any solutions on how to NOT get the registration window on the startup?
Posted on Sep 22, 2007
  • 1067 Answers
SOURCE: Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
Posted on Jan 23, 2008
  • 3422 Answers
SOURCE: Synthogy Ivory italian Grand won't play with Edirol UA-4FX sound card
You will need to download the drivers for it.
Posted on Sep 04, 2008
SOURCE: Edirol UA-25 not working on Mac OS X
I had the same problem. When I installed the Edirol software it prompted to 'reboot' and when it restarted all the lights on the Edirol came on.
Why don't you try it like that.
Hook up the Edirol Install the software Reboot
Best of luck Victoria
Posted on Jan 01, 2009
When i playback in WDM mode, i hear ckrackles and pops, when i playback in the other mode the ckrackles and pops are gon, but the input and output goes to none. how do i get rid of the ckrackles and pops...
1. check your user manual for clicks/pops.
this could be due to devices connected to the Edirol UA-25 or a television or microwave.
2. this also could be due to the setting in Windows Energy saving settings.
that is the Windows "sleep mode" and power saving mode.
3. this could also be due to the USB cable.
4. you may need an external filter device for the process you are using.
5. read your manual on Troubleshooting Noise ( clicks and pops).
Jun 14, 2011 | Edirol UA-25 External Sound System
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Nov 19, 2008 | Edirol UA-4FX External Sound System
No sound being picked up by Edirol
I discoverd the the digital in button had been pressed in. This was the mic was not picking up any sound.
Jul 09, 2008 | Edirol UA-25 External Sound System
Jan 23, 2008 | Edirol UA-25 External Sound System
Playback recordings
Problem with cable? Change in sample rate? Have you changed software/drivers? Could do with more info.
Jan 17, 2008 | Edirol UA-25 External Sound System
UA101 and Blue Screen of Death
try this to make sure that the driver was installed correctly.:
Note: Do not use the “Add New Hardware” Wizard in the control panel. Follow the steps below to install your driver correctly.
1. Plug in the USB cable and power on the device – the New Hardware Wizard will start up (wait for it to start).
2. If Windows asks to connect to Windows Update, click on “No, not this time” and click on “Next.”
3. Select “Install from a list or specified location” and click “Next.”
4. Select “Include this location in the search” and Browse to the folder containing your driver (either on your CD or the folder you downloaded). Click “Next.”
5. Click “Continue Anyway” when the Windows Logo testing screen appears.
6. Click “Finish” when the Completing the Found New Hardware Wizard screen appears.
At this point, you may need to reboot your computer. After restarting, you should check to make sure the driver was successfully installed. Go to Control Panel / Sounds and Audio Devices and make sure your device is listed under “Sound Playback” and “Sound Recording” for audio devices and “”MIDI Music Playback” for MIDI devices. You should also check in the Device Manager to make sure your MIDI or Audio device is listed under “Sound, video and game controllers” with no problems (such as the yellow exclamation point).
If everything is successful to this point, Windows has installed the device correctly and is making it available to any software you need to run. If you can not see your device in your software, you should first try re-profiling the device (different software programs do this differently). If this does not work, you may need to uninstall and reinstall the software. If you still do not see your device, you may need to contact your software vendor for more help.
- Mac OS X -
1. Make sure the Roland/Edirol device and any non-essential USB devices are disconnected.
2. Run the *.pkg installer from the CD-ROM or downloaded driver and follow the onscreen installation instructions. When finished, reboot fully.
3. Plug in the Roland/Edirol device. Ports should now be available in software (you can verify driver availability in Applications > Utilities > Audio/MIDI Setup > MIDI Devices).
- Mac OS 9.X -
Users must first decide if they want to run OMS or FreeMIDI, which can be downloaded from the World Wide Web. OMS is recommended. See the OMS or FreeMIDI documentation for installation and activation details.
Double-click the Edirol installer and follow the onscreen installation instructions.
Note: If you continue to have problems, you may wish to consider upgrading to OS X, as its Core Audio and Core MIDI features make this operating system an excellent base for music applications.
Product: UA-25 UA-101 FA-66 FA-101 UA-4FX UA-1EX
Pop/click/dropout is often a buffer size problem. Be sure to check your Buffer Size setting. You'll find it in the Edirol Icon in System Preferences or in the Control Panel of a Windows machine. Increase your buffer size until the problem goes away.
There are also several settings you will want to make in order for audio applications on a Windows XP computer run optimally.
One of the more detailed websites to walk through these settings is
Dec 23, 2007 | Edirol HI-SPEED USB (USB 2.0) Audio...
Recording sound
What operating system/ computer are you using>?
Oct 17, 2007 | Edirol UA-25 External Sound System
Mic problems: playback works great through interface, microphone isn't being detected
Check in contraol Panel under sounds and audio devices that you are using the Edirol and not an on board sound. It sounds like although the cards installed its not selected as the audio device to record from. You will also have to tel Adobce audition to select the Edirol as you audio card of choice as it to can be changed to select input from other sound devices.
Mar 31, 2007 | Edirol UA-25 External Sound System
Edirol UA-25 External Sound System Logo
257 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
