How do I remove the back (right) side of a gateway e4100 tower case? The front (left) side snaps on with a release handle at the top.
  • 76 Answers
That panel only is removable, after the screws are released from inside...the top might need to be removed first too
Posted on Nov 21, 2008
Removing the case to the Gateway (AK) MFATXPNT MDP E4100
What is the problem, opening the case should be fairly straight forward
Are you going to upgrade or repair
May 29, 2015 | Gateway Computers & Internet
Replace power button gateway sx 2311
Computer unplugged from power, FOLLOW Anti-Static Precautions.
1) Remove the Side Panel.
Viewing the computer from the Front; the Right Side Panel removes. Remove screw, pull Side Panel to the rear of the computer.
http://www.newegg.com/Product/Product.aspx?Item=N82E16883113140
Click on the large main photo.
There are 9 smaller views shown. 3 across, and 3 rows.
Bottom row, click on the photo in the Middle.
Shows Rear view of computer.
Along the back edge of the Side Panel, is a finger pull handle formed out of the Side Panel. There also looks to be two screws. One above the pull handle, one down towards the bottom.
2) Remove the Front Bezel.
Click on the Middle row/middle photo.
Also look at Middle row, 3rd photo. (Photo all the way to right)
There are 3 Black tab locks, formed out of the plastic of the Front Bezel. One towards the Top, one in the Middle, and one towards the Bottom.
If memory serves these tabs are gently pulled to the outside, to release the Front Bezel. Ease the Top tab out a little, and Middle tab.
Start easing the Front Bezel away from the metal framework, of the computer case, a little. Then release the Bottom tab.
Front Bezel should swing, and then come off.
Not your Gateway model of computer case, but this Gateway model shows the plastic Tabs to release,
http://support.gateway.com/s/CASES/3501975/3501975faq6.shtml
The Power On Button is an assembly. The plastic housing of the Power On Button assembly, has a Power On switch inside.
I gently heat the plastic with a hair dryer, moving the hair dryer back, and forth at it.
Once the tabs of the plastic, of the Power On Button assembly, is softened; then I remove the Power On switch.
I have found this ATX power on switch, fits a LOT of desktop computers,
http://www.directron.com/atxswitch.html
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 19, 2012 | Computers & Internet
Remove hard drive from tower case gateway 815 gm
http://support.gateway.com/s/PC/R/4190/4190nv.shtml
Looking at the rear of the computer;
A) Two thumbscrews to loosen, then remove the Left Side Panel.
B) Two Philips head screws to remove for Right Side Panel.
(Designation of left/right Side Panels are looking from the Front, of the computer)
Pop the Front Cover off. WATCH the wires so they do NOT get disconnected from the motherboard!
Slide the right Side Panel back about an Inch, then lift out, and off.
Click on - Gateway Computer User Guide - in blue.
Now remove the 1 or 2 Philips head screws on the right side, that hold the Harddrive into the harddrive bay.
Regards,
joecoolvette
Aug 06, 2012 | Computers & Internet
How to open gateway 300c desktop
There are several casings. You'll just have to pick one that fits your computer. Before you begin anything. Turn off your computer and remove the power cable. New Midtower Case 1 Look for a release handle on the top of the new midtower case. 2 Push the release handle inward. 3 Swing the case down from the top to open it. Microtower Case 1 Lay the computer down so that the left side is face up. 2 Locate two cover release levers on the back of the case toward the middle of the left side panel. 3 Squeeze the release levers together, then lift the panel up, swinging it away from the back of the case. Old Midtower Case 1 Lay the computer on its side, so that the left side panel is face up. 2 Remove any retaining screws along the left side of the back of the case that are holding the panel in place. These screws may be removed with your fingers. 3 Locate two release levers at the top and bottom of the back side of the case, and push them away from each other. 5 Swing the panel up and away from the case to open it while holding the release levers.
Jan 01, 2011 | Gateway 300 C PC Desktop
How do you take apart the tower
Turn the computer off.
Disconnect the AC power.
Look at the "back" panel.
You might see thumb-screws that hold the side-panels in place,
or you might see Philips-head ("cross") screws.
Or, you might see plastic "locks" -- slide them 1/4 inch to "unlock" the side-panel, and lift it off.
Or, look at the side-panel -- there may be a "lever" (like a "tab" on the top of a pop-can) that can be lifted to release the side-panel.
Or, older towers had a "one-piece" cover (like an upside-down "U") that needed to be unscrewed, pushed slightly towards the back ot the case, and then vertically lifted off.
Aug 29, 2010 | Gateway GT5220 PC Desktop
Want to remove the case on my gateway model e4100
There is a clip up the top basically....
Mar 24, 2010 | Computers & Internet
How do i remove the cover of a Gateway MFATXPNT NMZ 500SE
I found this:
"Facing front of computer you need to remove the left side cover. cover release is on top of the computer in center of side panel. Press in on button and p[ull top of side cover away."
Don't know if it's useful. If not let me know and I'll keep looking.
Mar 16, 2009 | Gateway Computers & Internet
Gateway Model 0019401806 Tower - Power button fell into case
there are tabs inside the case that you depress to pull the front cover off. once pulled off you should be able to replace the switch.
hope this helped
please rate well.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 06, 2009 | Sony PCV-RS620G PC Desktop
OPEN CASE
one screw in back on top then slid case back, about 2 inches then lift from rear
Aug 02, 2008 | Gateway E-2000 Deluxe PC Desktop
Computers & Internet Logo
257 people viewed this question
Alun Cox
David Payne
David Payne
