Question about Panasonic Car Audio & Video
Rd905 only upper half of display working - Panasonic Car Audio & Video
Panasonic viera
Try replacing your video cable, if that doesn't work, try using a different input on the T.V. If that doesn't fix it, you may be out of luck with out an extended warranty.
Dec 06, 2013 | Panasonic TH-50PX75U Plasma HDTV
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
The lower over is not working.It has displayed a "code" that looks like a half of a "H". The upper burners work
Which half of the "H" is missing upper, lower, left, or right ? Do you want to attempt the repair yourself ? If not, then it does not matter what the code means-----you still need to call an expert. You can try something on your own: unplug the electric cord, wait 2 minutes and replug. This sometimes resets the electronics and the code fault will then disappear and possibly the oven will work. If the code still shows, or the oven will not work , you need the expert. Good luck, Macgivor
Oct 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Monitor is showing bottob half display and upper half is blackout
Hate to say it, but time for a new monitor... will cost you WAY more to fix than to pop-by a garage sale and grab a new monitor.
(It's not even worth a repair-persons time to do it...)
Aug 31, 2009 | Philips 105S51 15" CRT Monitor
Lower half blank
1 (the lower one) of the 2 backlights is broken and needs replacing. If your warranty has expired it's quite expensive to get it replaced and you would be better of buying a new one.
Aug 24, 2009 | HP vs19 19" LCD Monitor
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 | Watches
Half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Sep 15, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Car Audio & Video Logo
50 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
