Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
TV picture goes in and out
Timer light goes on and off. TV picture goes on and off on our Sony KV32XBR96 set, which is about 10 years old. Set played beautifully until a week ago. I did all available amateur things; turned off set, disconnected from power, waited five minutes, reconnected and turned on.
Timer light still goes on and off. Repair man said it was a circuit board malfunction that needed $30 worth of parts and $250 worth of labor.
  • 298 Answers
SOURCE: set makes poping sound, but does not turn on, red standy light flashes
Horizontal output transformer may be arcing internally
hasnt eaten through or hith voltage anode arcing to crt
well
Posted on Nov 26, 2007
SOURCE: Sony Trinitron Vega KV-34HS420
MUZ,
Any luck with your TV yet?
Posted on May 21, 2008
ladywinn
  • 5138 Answers
SOURCE: sony kp51ws510
How much do you know about electronics and can you solder? There is 1 sure way to find out if high voltage splitter is bad disconnected the Flyback transfomer from it /If set comes on and stays on splitter is bad.Make sure you place high votage lead from flyback where it cannot shock you.or short out anything near chassis.Also check little round blue capacitor behind Hori output they go bad 1200pf 2kvolts. This set i think has 2 STK392-??? big black ics if one of them is shorted set will not come on.Its up to you on fix or throw away
Posted on Sep 04, 2008
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
  • 2920 Answers
SOURCE: I have a sony rear projection 52 in tv i need help with...
you can do it yourself if you can orer the part..its about 120.00 i think for the powerboard and then th time it takes you to put it in. if a repairman does it hes charging you at least 75.00 an hour for labor.
Posted on Feb 09, 2009
No picture have sound timer light blinks .when you turn TV on lamp light come on. Goes off. Tv have sound for 10 min TV cut off type 62" Mitsubishi dlp
How old is your TV set ? if you have not replaced the lamp in 2-3 years that is most likely the problem and need to replace that part.
This lamps now run from $40.00 - $90.00 depending on quality.
Jul 30, 2013 | Televison & Video
Don't have the model number with me at this time. The set is approximately 10 years old and is I beleive about a 25" or 27" set. The on timer light in the front of the set began blinking...
If the set is blinking there is an issue in the main board, either it is a power supply or vertical deflection problem, you also have to consider the set is 10 years old and the average life span of a tv ranges between 5 to 10 years. If the set is repaired the chances of a breakdown are extremely high because the other parts are 10 years old.
Jan 31, 2011 | JVC Televison & Video
Stand by timer light on the front of thr TV is blinking, how do I shut it off?
Sony TV's use auto Kine bias a very old term meaning Kinescope or Picture Tube.
When your picture tube is up to full output (approx 30 seconds) the set will click and perform as normal.
If not the tube you see the picture on is not up and running in any one or all colors (RGB) or something else has not started.
Service or replacement of a 10 year old set may be what's next.
Sep 23, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Rear proj TV picture keeps blinking out
comon sony problem Sony has and Ik circuit tha is suppose to not allow video in there is an uneven emission from the crts what you have on both sets the tube are getting so weak causing the circuit to kick in and out in other word you need crts inboth set and they are not avail new you can have them rebuild but the set will never look good again time to retire them
Dec 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
No picture coming on
Six blink shutdown is a common problem with this televion one of two switch mode ps ic have failed. The repair may cost somwhere around 150.00 to 200.00 to fix from a technician. If you want the specifics, i can provide them.
Nov 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
SONY WEGA KV-32XL90E
Hiii...
what chassis your tv set ?
Thank's
[Vrya]
Jan 23, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
TV SCREEN GOES BLANK
It's not because of a sleep timer or any other settings. I have a similar problem with my SONY Bravia and it started after only 7 months. Sony has sent technicians to my place, had the TV at their place etc but they say the problem doesn't appear at their service center so they can't fix it. (They've just updated the software (3 times) but that has not helped at all.) I say it's ******** and I will report them to the consumer organisation. They also said they had never heard of this problem before, and that is very interesting since I found about 100 webpages where the problem is reported...:-( Never buying a Sony again!!!!
Nov 14, 2007 | Televison & Video
No Picture-No Sound Timer light flashes.
The sequence of flashes from the timer light may hold the clue as to what is wrong. For instance if it blinks 5 times then 3 before repeating the cycle, it usually means that IC 702 on the CRT drive board is bad. I have had to replace that semiconductor many times in the past. For this exact symptom, removing the connector Cn706 From the CRT Drive Board allows the set to start up. I am very skeptical of the quality of picture tubes in these sets, so if this is the problem, it may occur again. When replacing this IC, there could be damage to a resistor and capacitor R533 and C541 on the main Printed Circuit Board also. If your timer light is not flashing that code, the problem is elsewhere. If the set is over 6 years old, it may be worthwhile replacing it.
Jan 20, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
49 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
