Question about Amana PTH153B50AJ Heat Pump Air Conditioner
Replace room thermistor error code
Our Amana PTH153B50AJ Heat Pump code light is blinking indicating that the room thermistor needs to be replaced. I cannot find our users manual. How / where do I replace it? Are the parts available at most parts retailers?
Thank you,
  • jarober44 Nov 22, 2008
    our Amana PTH153B50AJ Heat Pump code light is blinking indicating that the room thermistor needs to be replaced. Where is the thermistor in the unit? Are there any tricks / concerns in replacing it? Are the parts available at most parts retailers?
    Genius:
  • 1,550 Answers
Try the parts from partstore.com .
Regarding the manual you can get from ebay or ciao.
Posted on Nov 22, 2008
    Top Expert:
  • Amana Master
  • 81,294 Answers
The thermistor is and electronic sensor and part of the thermostat, it is the solid state device that sends a very low voltage signal that the system converts into room temperature, thermistors are very accurate devices and much better than the old Bi-Metal type of sensor, you may just have a connection problem, or the thermistor may be defective, testing by a qualified tech is required on site to fund the final repair solution, but I suspect the cost to repair will be fairly modest.
  • Marvin
    Marvin Nov 22, 2008
    Disconnecting the unit power will reset the code, but as soon as the system goes through prove out the problem will flash a code again, winter is coming do you want a temperature control issue right now?
  • Marvin
    Marvin Nov 23, 2008
    Any full service parts store like Sears and others can get the parts, they will come with instructions in most cases, also check on line, they are usually cheaper and have great tech telephone support for installing the part.
    Brigadier General:
  • 3,614 Answers
First try to unplug the unit from the power outlet for an hour. this will reset the unit.
What does E61 service call on my frigidaire affinity mean???
read the whole manual no code e61 ?
READING ERROR CODES
1. Rotate cycle selector knob to the 3 O'clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O'clock position. The four indicator lights of Drying, Cool Down, Wrinkle Rid
(Press Saver), and Clean Lint Filter will flash the number of times for the first digit of the code and the START indicator
light will flash the number of times for the second digit. Take separate counts of each indicator light, then repeat to
confirm in order to be accurate in identifying the proper error code. The code is obtained by counting the number of times
the lights flash. Example E24: The four indicator lights would flash twice indicating the 2 and the START indicator light
will flash four times indicating the 4. The four indicator lights and the START indicator light start flashing at the same
time. The control will pause for 2 seconds, then repeat the code.
NOTE: A letter appearing in the code stands for a number higher than nine. A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. The four indicator lights would blink four
times and the START indicator light would blink ten times. Troubleshoot the problem by using the chart below.
To move on to the next code, press the OPTIONS button.
To clear code, press the Select button. Code will be cleared when mode is exited.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
Error Code Label Description Solution
E10 General EEPROM
Fault
Problem with communication
between EEPROM and the
microprocessor.
Clear code, exit mode and start dryer. If problem persists, replace electronic
control.
E11 Checksum Error Problem with communications or
memory did not check, one has
become corrupted.
control.
E12 Non fatal R/W
error
Problem reading or writing to the
memory or input/output.
control.
E24 Control NTC Short
Circuit
Control thermistor or its wiring is
shorted.
Remove wires from control thermistor. Measure resistance of thermistor. If
reading is not 50 K (± 10%), replace thermistor. If reading is within 50 K (±
10%), check wiring between thermistor and electronic control. If good,
replace electronic control.
E25 Control NTC Open
Circuit
open.
E4A Program Timeout
Fault
The drying time has exceeded
program time for that cycle.
Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes.
Position cycle selector to NORMAL, temperature selector to HIGH HEAT
and touch START. Check for anything that would extend dry times such as:
no heat, restricted vent, blower fan blade broken or loose, dryer installed in
closet with solid door, or bad connection in moisture sensor bar circuit or
dirty bars. If dryer operates normally but code returns, replace electronic
control.
E5B Heater Fault (no
heating)
Temperature reading of control
thermistor has not changed in a
certain amount of time.
and touch START. Measure voltage across terminals on relay RL2 (heater
relay) on electronic control. If meter reads 240V on electric models and
120V on gas models, replace electronic control. If meter reads zero, remove
power from dryer. Disconnect wire going to NO terminal on the relay RL2.
Reconnect power and measure voltage drop between terminal COM on
relay RL2 and neutral. If meter reads zero, wire between incoming line and
relay RL2 is open. If meter reads 120V, check the rest of the heater circuit.
E68 Key (button) Struck
Fault
One of the keys (buttons) is stuck
closed (active).
Enter function test mode and perform key (button) test to determine which
button is at fault. Carefully free the and perform the test again. If button is
free but the key struck code still exists, replace electronic control.
E8C Too many trips in a
period of time.
The safety (high limit) thermostat
has tripped too many times within
a certain period of program time.
Check for blocked lint filter, blocked exhaust, air leaks around air duct,
broken blower fan blades, worn or loose drum seals, dryer installed in closet
with solid doors or door seal not correctly seated.
EAF Watch Dog Reset Microcontroller has been reset by
internal Watchdog timer.
Jun 14, 2014 | Frigidaire Electric Dryer
What does E6 error code mean
here is basic error codes for your dryer (and how to get them out)
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
Jun 04, 2014 | Frigidaire Dryers
WHY DOES MY DRYER KEEP SHUTTING OFF WITH BLINKING LIGHTS
sure is heres how to get the fault codes
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
May 09, 2014 | Frigidaire Dryers
Frigidaire affinity dryer yes code
heres how to get them :
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
May 06, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Pth153b50aj
Change motor to check do a amp draw find out how many amps motor is drawing this may tell you that motor is going
Oct 25, 2013 | Amana PTH153B50AJ Heat Pump Air...
I have a Amana unit Model# PGA60C1152F that has a blinking light on the control board it blinks 4 times. That heat will come on then go off but the blower nevers comes on.
look on the inside of the door that you took off and there should be a diagram and on that there will flash code that will tell you what 4 flashes means.i think it is a flame rollout or high limit.
Nov 16, 2012 | Amana Heating & Cooling
My Amana heat pump model PTH153B50AJ does not cool properly. The compressor comes on and the fan works.
This sounds like a freon problem your system probably has a leak in the system somewhere. Amana has tons of problems with there equipment. They make there coils paper thin and they split especially on a heatpump. Amana used to be a good brand and then got bought out by goodman manufacturing and have turned there product into ****. How old is this unit?
Jun 14, 2011 | Amana PTH153B50AJ Heat Pump Air...
I have an Amana PTH153B50AK - The heat is blowing cold. Can you tell me which part needs to be replaced?
If the room air blower only puts out what feels like cold air and continues to run all the time it is an indication that the unit has a fault code stored in its CPU or central processing unit (better known as the circuit board). If the unit has a small viewing port either on the front panel or just behind the front panel, you can look into it and see a blinking LED light. Count the blinks and record. Sometimes there may be short and long blinks such 1 short and three long blinks. This could be an error code 13 or 31 depending upon the manufacturer. On the reverse side of the front panel, there should be a wiring diagram that also has a diagnostic chart that will tell you how to read the codes and where to start looking for issues based on the error code you recorded.
hope this helps, please rate my answer.
Jan 30, 2011 | Amana Heating & Cooling
I have a fujitsu AOTR30LCT, when turned on the green timer light and the red power light blink 3 times. Only the fan works and does not cool.
Error c0de-3.Return air thermistor short circuit.
This sensor when it's defective, will not command for compressor for working.
Replace it.(Room air sensor). Helpful?
Jan 24, 2011 | Fujitsu Heating & Cooling
No heat
1.check heatar of unit.
2.wireing of heater.
heater not workink.
thermostate also check
Feb 21, 2008 | Amana PTH153B50AJ Heat Pump Air...
Amana PTH153B50AJ Heat Pump Air Conditioner Logo
215 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
