Question about Frigidaire FGQ332ES Gas Dryer
Does a Kenmore Elite H3 dryer have a pilot Light???
I just got a second hand Kenmore Elite Dryer H3 from a friend who moved into a place that doesn't have a hook up for gas, it's pretty new and I was wondering if it had a pilot light?
  • khalidsamaan Feb 21, 2010
    My dryer is not blowing hot air
  • 370 Answers
No. They are electronic ignition. just plug it in and hook it to gas and should heat up.
Posted on Nov 21, 2008
Does the kenmore elite dryer have a pilot light
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 23, 2011 | Kenmore Elite Oasis ST 7806 Dryer
Where do you light the pilot light on a Kenmore Elite gas dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 19, 2010 | Kenmore Dryers
Circuit breaker tripped, i reset it and the dryer read PF, cleared that...but now the dryer just beeps when youy hit any button like start. The dryer is a kenmore h3 gas dryer
try resetting the breakers again as they may have tripped again as sometimes they only move a bit and they look like they are ok but they are not.I would also unplug the dryer for thirty seconds to reset it and start again.
Oct 06, 2010 | Kenmore 82822 Electric Dryer
How do i light the pilot of my dryer
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Is there a pilot light I need to light once I hook up the gas?
Good day,
No. There is a silicon carbide igniter that replaces the old pilot light.
Standing pilot lights were eliminated about 30 years ago.
Dec 10, 2009 | Kenmore Elite HE4 Electric Dryer
Do I need to secure the tubs inside Kenmore Elite Washer & Dryer?
Not the dryer but you do for the washer ... there is bolts that go in the back to hold the tub ... the bolts came with the washer went it was new... you may be able to get a set from sears...
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite gas dryer the gas will
Just replace the two solinoid coils on top of the gas valve,unplug the dryer always! Two phillips head screws hold the half bracket over the coils. The larger three wire coil may have a silver sleeve in it, you need to reuse that. Just replace the set and reassemble it, your done.
Aug 30, 2009 | Kenmore Elite 45986 Front Load Washer
How do I light the ignite pilot light
Most new dryers don't actually have pilot lights. They use an electric heater that turns red hot, and ignites the gas at the right time. If your trying to light the pilot light (which probably doesn't exist) because the gas isnt being ignited,,, its possible that the electric igniter needs to be replaced.
Mar 13, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer isn't working
I had success.  I found the manual....unplugged the dryer, and rotated the inside drum several times to check for any coins or small objects.  I did not find anyything, but if something small was lodged it is not hampering the dryer.  I plugged it back in and it worked right away...
lizzardhips
Oct 26, 2008 | Kenmore Elite HE4 Electric Dryer
How to light the pilot light on a Kenmore gas dryer.
no pilot light has glow bar ignition ..ck to see if bar glows when start button is pressed should be small plastic cap on bottom of dryer front remove it to ckd for glow and burner operation
Aug 29, 2008 | Kenmore 75962 Gas Dryer
Frigidaire FGQ332ES Gas Dryer Logo
593 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
