Question about Brother MFC 9600 All-In-One Laser Printer
My Brother MFC 9600 has ADF feed problems!
My ADF is not feeding as it should. I always have to stand by and help the paperstock start feeding. Where can I purchase that little rubber feeder attachment that is supposed to grab the paper to feed in the machine. otherwise I am pleased with the operation of the printer and would hate to change it.
Try just cleaning the roller and the small glass rectangle with isopropryl alcohol. Worked for me. Good luck.
Posted on Feb 08, 2009
MFC 8820D ADF Will Not Feed Document
The ADF in my Brother MFC 8820D will not feed a page through
Feb 23, 2013 | Brother MFC 8820D All-In-One Laser Printer
Brother MFC-8860DN All-In-One Laser Printer showing document jam error
Doc jam error usually means a jam in the adf (auto doc feed) when feeding a fax or doc to copy.
The most common reason brother mfc,s of this configuration have doc feed issues is believe it or not the hinge that operates the lid/adf, specifically the left side one (looking from the front). Inside the hinge there are two springs exerting tremendous force on the hinge (that enables the lid to stay up by itself) however this force eventually slowly breaks the fulcrum point of the hinge which leads to the lid not closing properly which means a sensor under the lid does not activate properly resulting in the adf stopping and resulting in the machine registering a jam. the difference between the sensor activating or not can be as little as a millimeter and is not often disernable. the hinge needs replacing by a techo.
the other reason could be you just have dirty adf feed rollers, clean them with a cotton rag dipped in metho, open the adf lid and give the rollers a scrub. the rollers should have 'tread' on them similar to a tyre, if not they are worn and need replacing.
One other possibility is there may be a paper fragment left over from a jam removal still caught in the paper path and activating a sensor activator that tells the machine paper is coming or going. most commonly in the section where the paper is looping on its return journey back out of the adf, open the adf lid, have a look with a torch and see how you go.
Regards, Andrew.
Dec 04, 2010 | Brother MFC-8860DN All-In-One Laser...
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 9600 won't pull paper from tray
There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Jan 07, 2009 | Brother MFC 9600 All-In-One Laser Printer
I can fax and copy on the glass with the Brother MFC 8440 but not through the ADF. Any suggestions?
This is usually cause by a broken left hinge on the adf. Lift the lid and look near the back at the hinge. If you need the part email me for pricing jtuminaro@officetechservice.com
Dec 10, 2008 | Brother MFC 8440 All-In-One Laser Printer
Brother mfc-8460 ADF no longer working
Go to where you bought it, see if the same model is available, buy it, switch boxes and return for your refund. I've learned with brother printers once they go bad, dont monkey with them, replace them.
Aug 12, 2008 | Brother MFC-8660DN 5-in-1 Laser...
MFC 440CN fax machine
Is this through the ADF (top feeder) or from the paper tray? Either one can have some build-up on the paper feed rollers and would have to be cleaned.
Jan 08, 2008 | Brother MultiFunction Center MFC-440CN...
Brother MFC 9600 All-In-One Laser Printer Logo
108 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
