Question about Xerox Office Equipment & Supplies
Copier beeps after scanning
When something is scanned (network scanning) into our Xerox 250, it scans the document, the "job in memory" light comes on, then the "online" light comes on. After 30 or so seconds, the printer will start beeping. 3 beeps, skip a beat, 3 beeps.
The scanned file never makes it to the destination.
We have checked permissions, accounts and passwords, configs.
Nothing has changed. Any idea what is causing this??
  • 2 more comments
  • bmartinuzzi Nov 24, 2008
    The IP of the printer, and the sever it is trying to connect to have not changed (static address).
    The scans were working, then for some reason stopped. No new software has been added to the server, and the permissions on the folder have not been changed.
    UPDATE**** I stumbled across a screen that sayed the error I was getting was "016-781".
    The IP address has not changed on the printer, or the server it is scanning to. (Static IP) The permissions on the share/folder it is scanning to have not been modified. (Keep in mind that at one point, this scanner was working.)
    We are not on Vista, to the solution does not apply.
    UPDATE** I stumbled across the error code "016-781" when trying to find a solution to this problem.
  • Anonymous May 02, 2009
    Error 016-781. I think it has something to do with your outgoing mail servers that requires authentication, because that was the only thing that changed on our server and the xerox stopped working....I do not know how to fix it yet...
  • Mike S
    Mike S May 11, 2010
    Has the IP address changed in the network.. Is your machine set to Static IP?
    Is there a firewall blocking the scan. are the ports which the scanner uses unblocked?
    Is this scvanning direct;y to the PC
    or is this go though the .
    this handy guide helps as well.
    http://www.fixya.com/support/r1173875-ne...
  • Xerox Master
  • 2,794 Answers
Is this connected to a Vista computer? There might be a few extra things that need to be turned off permanently in the computers admin settings.
Posted on Nov 22, 2008
Xerox Copycentre C20: Copier doesn't scan top 1-3 inches of page. Happens intermittently. When this happens, it moves everything else on page to the top of the copy, cutting out what should be
The document feed rollers may be dirty/worn which is causing the paper to come into the scan area late causing your document cut offs. use a clean, lint-free cloth dampened (not moist) with water and clean the document feed rollers. Confirm they are dry then, try scanning multiple pages and see if they pull through without stalling. If they do, it's time to replace those rollers.
Aug 27, 2017 | Xerox CopyCentre C20 Black and White...
Job failed because scan name is invalid
Hi Anonymous / Kenneth,
I assume you must have this problem sorted by now. ( 2012.)
Perhaps there's a firmware up grade you could look into?
Perhaps you must have to check this problem with your Xerox Concessionaire.
Good luck.
May 14, 2012 | Xerox Phaser 3635MFP/X Multifunction...
Error code 016 781
The 016-783 error message indicates that “Cause – Could not find the specified server path during file”.
The folder that the Xerox scanner job template uses to deposit the scans in had previously been deleted, so I had recreated the shared network folder. What I had neglected to do though was to recreate the sub-folders that the Xerox Job Templates use for the scans.
After recreating the subfolders that the file repository setup referenced in the job template I had no more error codes with that scanning job template.
Jul 01, 2010 | Xerox WorkCentre M-24 Color Copier
Xerox WorkCentre 7232 will not Scan to PC
Your error code usually means: Scanner can not find the specified folder/storage location
-wrong document path
May 21, 2009 | Xerox Office Equipment & Supplies
I have a Canon ir 3045 copier, when I try to send the scanned copy directly to a file, the file doesnot save to the destination network folder. When I looked at the scanner send logs i saw status as NG...
I have a Canon ir 3045 copier. I had sucessfully scanned two documents but the third scanned document (107 pages) was not emailed to me. When I click on press details, the job type reads #801. how do i retrieve the document?
Apr 24, 2009 | Office Equipment & Supplies
Xerox 4150 not scanning to network
I need more information, like is it scanning using the SMB protocol or FTP. Are you using active directory, etc. Usually, when they just quit, it is due to a Microsoft security patch, or a software firewall having been enabled. If you're sure that it is neither of the above, try browsing to the Xerox via the IP address, go to the properties tab, services, network scanning, file repository set-up, and see if the login name used for network scanning is qualified: (i.e. - domain\username) Often, in a business environment, that will help.
Mar 20, 2009 | Xerox WorkCentre 4150 Black and White...
Scanning large documents to PDF takes a long time
Try to use Compact PDF or a lower resolution.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jan 14, 2009 | Konica Minolta bizhub C250 All-In-One...
We have a Xerox M20 Copier/Scanner/Fax/Email which we have always used strictly as a copier. We need to use it as a scanner, to reduce paper in the office and access/share documents electronically. I...
To scan a document to file (Scan to File), the WorkCentre must be directly connected to the workstation using a USB or parallel connection. Scan to File is not supported over an Ethernet connection.
Sep 22, 2008 | Xerox Office Equipment & Supplies
558 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
