Question about Rheem RTG-53PVN Indoor Natural Gas Tankless Water Heater for 1-2 Bathroom H
Rheem RTG 53 PVN with fault codes C4 or C7
My tankless water heater has been increasingly noisy over the past year (its almost 2 years old). Suddenly, it won't make hot water for very long. The control flashes fault codes of C4 then 76 (alternating) until I unplugged it, waited and then reconnected it and tried to use it again. Now it flashes C7 76 and won't produce any more hot water. What is the problem?
Thanks
Rich W
  • 6 more comments
  • Anonymous Dec 08, 2008
    Same problem after one year of use.
  • timsnegri Jan 04, 2009
    I have the same problem with a Rheem Pronto tankless heater after one year. My plumber said nothing about a water softener voiding the warranty. My error code however, is C7 followed by a flashing 13.
  • ageedan Jan 11, 2009
    We've had our unit for almost two years. The hot water kicked off and after resetting the unit several times it still won't work and has stopped producing hot water. The code C7 comes up and alternates to 76.
    I cleaned both the air take filter and water filter but did not solve my problem.
    Help!
  • Anonymous Mar 28, 2009
    C7-76 flashing codes...disconnected remote..still same issue..NO hot water...
  • Anonymous Apr 28, 2009
    I am having the same exact problem with my Rheem.. we have had ours almost 2 years and it has been noisy and giving us the error off and on for the past year.. now it is constant.. if I can get it to reset it only heats for a max of 3 minutes then it starts the errors.. I will try the solutions below..
    Thanks!
  • Anonymous Mar 14, 2014
    when i turn the hot water, the rheem will make a very loud noise with some sort of violent vibration. sometimes it faults out with a code 13 shown on the display
  • Anonymous Mar 16, 2014
    fault codes rheem loline solar hot water unit
  • Anonymous Mar 17, 2014
    C4 56 and C7 56 keeps coming up after a short time on any help
I had the same problem with my tankless waterheater (flashing c4 76 alternately). I called Rheem
tech support and they had me 1 power down the remotepanel 2 unplug the unit from the wall 3 remove the cover 4 remove the wires for the remote panel from the circuit board and pull the twisted pair that goes to the remote out from the bottom of the unit. 5 reinstall the cover 6 plug the unit back
into the wall and turn on the hot water see if it works. It did in my case and they are sending me a new remote panel. I hope it helps.........
Posted on Jan 12, 2009
    Novelist:
  • 167 Answers
First off, if you don't have a water softener supplying the tankless you have voided your warranty; it's in the fine print. The mineral deposits build up and clog the heat exchanger; that may not be the problem because you're not having water pressure issues. Furthermore, you don't need the control unit for the tankless to operate; remove the control unit and unplug / shut off the breaker for atleast 3 minutes. Turn the power back on and see if that resets the unit; this may get your hot water back until you can determine the error code. I will look up the Rinnai error codes tomorrow and get back to you on this since my experience with Rinnai products is limited.
Posted on Nov 28, 2008
Here are all of the error codesfor the tankless water heaters and their solutions
Error Code List
Code Fault Remedy
1 of 3
00 1 Hour continuous
combustion
Close all hot water taps to reset unit.
Turn off, or remove circulation pumps (unit is not designed for continuous
operation with circulation systems).
05 Imperfect Combustion
Alarm
Clean air inlet filter.
Clean combustion air fan.
Clean heat exchanger fins.
Check for adequate combustion air ventilation openings and clean if necessary.
Check vent system for partial blockage and correct as necessary.
10 Air Supply or Exhaust
Blockage
Check all vent components for proper connections.
Check that nothing is blocking the flue inlet or exhaust.
Ensure proper venting materials were used.
Ensure condensation collar was installed correctly.
Ensure heat exchanger fins, fan, and air intake are not blocked.
11 No Ignition Ensure you have gas to the appliance.
Ensure gas type and pressure is correct.
Bleed all air from gas lines.
Ensure gas line, meter, and regulator are sized properly.
Ensure appliance is properly grounded.
Check gas solenoid valves for open or short circuits.
Ensure igniter is operational.
Check igniter wiring harness for damage.
12 Flame Failure Ensure you have gas to the appliance.
Ensure flame rod wire is connected.
Check flame rod for carbon build-up.
Check power supply for loose connections.
Check power supply for proper voltage and voltage drops.
Disconnect remote control.
Disconnect and re-connect all wiring harnesses on unit and PC board.
Ensure proper venting material was installed.
Ensure condensation collar was installed properly.
Ensure maximum vertical vent length does not exceed allowable limits.
Ensure maximum horizontal vent length does not exceed allowable limits.
Posted on Dec 03, 2009
  • gsxrbaboy212 Dec 03, 2009
    14 Overheat Wrap Fault Ensure high fire and low fire manifold pressure are correct.
    Check gas type of unit and ensure it matches gas type being used.
    Check heat exchanger for cracks and/or separations.
    Ohm out safety circuit.
    Check for improper conversion of product.
    Check for restrictions in air flow around unit and vent terminal.
    Check for a foreign materials in combustion chamber and/or exhaust piping.
    15
    Boiling Safety Device Check for closed water heater inlet valve or restrictions in cold water inlet pipe
    (must be fully open).
    Check for clogged heat exchanger (scale buildup).
    On commercial water heater, lower setpoint temperature below 180F at high
    altitude.
    16
    Over Temperature Warning Check for clogged heat exchanger.
    21
    Malfunction of Air Intake
    Filter Switch
    Make sure air filter door is properly seated.
    Make sure front panel is properly installed.
    24
    Malfunction of Operational
    Switch
    Press max button on PCB to reset.
    Press min button on PCB to reset.
    Replace PCB
    29
    Heat Exchanger Outlet
    Temp. Too Low
    Clean heat exchanger air inlet
    31
    Water Inlet Temperature
    Sensor Fault
    Check sensor wiring for damage.
    Ohm out sensor
    Check and clean scale from sensor.
    Replace sensor.
    33
    Outgoing Water
    Temperature Sensor Fault
    Ohm out sensor
    Replace sensor.
    34
    Combustion Air
    Ohm out sensor
    Ensure fan blade is tight on motor shaft and it is in good condition.
    Replace sensor.
    35
    Improper Thermistor
    Connections
    Check that all thermistors are connected to propor connections on PCB.
    51
    Gas Inlet Solenoid Valve
    Fault
    Check gas inlet solenoid valve wiring harness for loose or damage terminals.
    Ohm out solenoid valve.
    52
    Modulating Solenoid Valve
    Fault
    Check modulating gas solenoid valve wiring harness for loose or damage
    terminals.
    61
    Combustion Fan Failure Ensure fan motor will turn freely. (Motor will operate with a small amount of
    restriction.)
    Check wiring harness to motor for damaged and/or loose connections.
    Ohm out motor winding.
    71
    Control Fault
    Replace PCB
    72
    Flame Sensing Device
    Fault
    Ensure flame rod is touching flame when unit fires.
    Check inside burner chamber for any foreign material blocking flame at flame
    rod.
    Check all wiring to flame rod for damage.
    Check flame rod for proper voltage.
    Remove flame rod and check for carbon build-up, clean with sand paper.
    Replace flame rod.
    76
    Communication Fault with
    Remote Control
    Check remote control wiring for loose or damaged connections.
    Bypass remote control cable by connecting remote control directly to remote
    control terminals on PCB. Replace cable if found to be faulty.
    Replace remote control.
    Replace PCB.
    79
    Fan Motor Current Fault Ensure fan motor will turn freely. (Motor will operate with a small amount of
    restriction.)
    Check fan motor for proper voltage.
    Replace fan motor.
    Replace PCB.
    Error Code List
    Code Fault Remedy
    3 of 3
    80,81
    Gas Cut-off Failure Ohm out all solenoid valves.
    Check voltage of all flame rods.
    Replace gas control valve.
    82
    Gas type data failure Program PCB for proper gas type.
    99
    Blocked Flue Fault Clean any blockage in heat exchanger, combustion fan, inlet filter, and exhaust
    flue.
    No
    code
    Nothing happens when
    water is flowing through
    unit.
    Make sure unit is connected to proper power supply and circuit breakers are on.
    Make sure power supply inlet fuses are not blown.
    Clean inlet water supply filter.
    Ensure you have at least the minimum flow rate required to fire unit.
    Check for pipe dope inside water flow control turbine.
    On new installations ensure hot and cold water lines are not crossed.
    Check for bleed over. (Close cold water supply valve to water heater. Open hot
    water taps at fixtures. If water flows steady from hot water taps, there is a bleed
    over in the system.)
I get code c7 76 if i unplug unit and plug unit back it works for few minutes and same problem 76 c7 error
Posted on Sep 12, 2010
More important than the c4 is the error code of 76. It is that the remote is not talking to the heater. I directly connected my remote to the heater and the problem went away.
Posted on Feb 20, 2009
  • mariaperez Mar 08, 2011
    How did you accomplish that. I can't find anything on how to do that.
Error code c4 76 how do we fix this
Posted on Jul 24, 2010
I have a C3 82 code. Any ideas??? Brand new just installed an hour ago!!!!!!!!!!!! This is the 2nd one. I will never reccomend this to anyone. THESE ****!!!!!!!!!!!!!!!!!
Posted on Aug 21, 2009
I have a paloma ph6dp water heater that hasn't
You have an old tankless computer and it won't work?
What would you do if you had old laptop computer that didn't work?
Copy following links for possible resources including required yearly maintenance so tankless computers can last 4-6 years before needing replacement:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Sep 07, 2013 | Water Heaters
There is power to the system but when you turn water on elements do not come one and heat water. all phases have 238 volts to them. why will system not turn on and heat water
Do you have 3-phase water heater? Is this balanced or unbalanced 3-phase unit. Add comment and describe product in detail, including brand since i have some service resources for both types.
Or do you have ordinary residential split-phase 240Volt Bosch tankless computer that heats water, and has 2 or 3 separate elements, and a separate circuit breaker supplying power to each element? And testing across both hot leads coming from each breaker yields 238Volt?
Copy following link for Bosch tankless manuals, with brief troubleshoot section that does not provide detailed service procedures for repairing tankless computer:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html#manual
If this is new water heater, then call installer. If you installed yourself, then remove tankless and return to seller for refund.
Tankless computers require certain amount of water flow to activate computer sensors. Turn on Hot tap and listen to pipe to hear if water if flowing through hot pipe. Check for crossover:
http://waterheatertimer.org/Crossover.html
Clean water filter usually located just above where cold water connects to unit.
Delime tankless ... and use water softener. Tankless cannot be exposed to more than 11 grains hardness in water, or parts will fail within 2-3 years. Simply deliming tankless heat exchanger each year will not maintain full efficiency... although for typical family of 4, tankless comper water heater costs $100 more to operate than tank-type heater according to manufacturer's promo literature and independent studies.
Call local technician who specializes in fixing tankless computers. For plumbing problems call local plumber. These are two different things.
If tankless computer is older, then cut losses, and buy tank-type electric water heater at Lowes for $285 and make quick changeover and have hot water same day. Sell old tankless on ebay and cheat next guy, or sell at scrapyard for $3 per 100.
Gene
h
Aug 05, 2013 | Bosch PowerStar AE125 AE125 Whole House...
2 yr old ecco sense UMC 117 unit flashes 38 beeps and wont give hot water
1) Copy following link for Rheem tankless troubleshoot, including ecosense.
2) Probably needs new circuit board.
3) Product manual usually give list of required yearly maintenance.
Perform the maintenance, just like changing oil on car, and then service technician is familiar with your water heater and can count on your money each year around Christmas.
4) For independence, reliability, cost, and convenience, don't buy tankless water heater, or any other expensive/complicated water heater that requires yearly maintenance, and generally cannot be repaired by homeowner.
Jan 04, 2013 | Rheem Tankless Water Heater Main Remote...
Product is four years old
Yes.
Delime tankless each year.
Copy following link:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#de-lime
Tankless cannot be exposed to more than 11 grains hardness in water.
Nov 09, 2012 | Rheem Tankless Hot Water Heater...
Noritz NR98-DVC tankless water heater won't give hot water thru a single valve fixture. Gives us all the hot water we want on a double handled fixture. Any suggestions on what to do?
Replace single-handled faucet cartridge, and see if hot flows to that faucet again.
Exposing tankless to hard water causes reduced efficiency within a few months, and can cause Total failure of parts within two years.
Do not expose tankless to more than 11 grains hard water.
Here is research pdf conducted by water softener industry comparing tankless andf tank-type:
http://waterheatertimer.org/pdf/Battelle_Final_Report.pdf
To solve problem long-long term, install tank-type gas water heater from local box store for $350.
Oct 12, 2012 | Noritz NR98-DVC-NG 100W Freeze Tankless...
Hi I have a bosch instananeous hot water heater 16H, it is about four years old. Since quite early in its life the hot water flow has become less and less. now when i turn the hot on full it takes...
1) You might have a simple liming problem, requiring deliming by qualified service technician.
If you want to do-it-yourself, Utube search: de-lime tankless water heater
2) Usually the warranty requires yearly, and periodic maintenance like a new car:
Maintenance protocol requires yearly de-liming.
Tankless cannot be exposed to water exceeding 11 grains hardness, and require softener and filter.
3) Look up your manual on following link and read entire thing to shake off promotion-driven-perception that tankless solve all water heater worries:
http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/tabid/354/Default.aspx
4) The promise of 'longer-life than tank heater' is not supported by actual product warranty.
Check your manual for warranty.
5) Since all costs are energy, tankless can fall short of energy-saving claims.
Feb 24, 2011 | Bosch Water Heaters
The heater is only kicking on low as the wate demand goes up the temperature of the water drops because the heater is not kicking up like it used to. The heater is a little over a year old.
See image larger
-Tankless water heaters are susceptible to lime build-up if not de-limed each year.
-Hard water will clog pressure-sensor and cause failure within 2 years if filter and softener are not working.
-Water flow and water pressure sensors inside tankless are succeptible to hard water deposits.
-Low water pressure from clogged pipes to municipal water problems to water well pressure valve can affect tankless burner
-Low-flow shower heads may not engage burner.
-With tankless-gas water heaters, sensors inside combustion area detect when incoming air flow is not adequate ... inspect inflow
-Your manual probably has a troubleshoot section.
-The manufacturer will refer you to installer.
-If you self-installed unit, that will void warranty to my understanding.
-There are water heater forums 1 2 3 4
-There are plumbers who will each have a different opinion
-There are Fixya experts who get paid to tell you the above.
-And there are local plumbers who are authorized dealers of the brand of tankless who get paid to fix them
Oct 07, 2010 | Rheem Tankless Hot Water Heater...
Rheem tankless rtg 74pvn - heater hot water shuts
This is something you will have to contact rheem about due to the fact you don't have a fault code
Jul 13, 2010 | Rheem Tankless Hot Water Heater...
No Hot water...why Bosch tankless water heater, 2 years old
I dunno ... did you turn it on?
What kind of result do you expect from this kind of question???
Oct 09, 2009 | Bosch PowerStar AE115 Tankless Water...
Rheem RTG-53PVN Indoor Natural Gas Tankless Water Heater for 1-2 Bathroom H Logo
7,499 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
