Question about Onkyo TX-SV727 Receiver
ONKYO TX-SV727R MR OFF button lights up. No power.
When I plug in my ONKYO TX-SV727R the MR OFF button clicks and lights up over and over again. The power will not come on.
Any ideas what the problem might be?
5 Suggested Answers
  • 16 Answers
SOURCE: Onkyo TX-SR 606 KEEPS CLICKING INSTEAD OF TURNING ON WHEN POWERED
Here are your options:
1. An electrical problem, where your receiver has a grounding problem.
2. Your speaker wire connections are actually touching each other and that's why your receiver is not turning on.
Posted on Nov 15, 2008
  • 54 Answers
SOURCE: Onkyo TX-DS575 - intermittent audio
You have a problem that was inherent with all Onkyo receivers from this period. You need to contact Onkyo because the microprocessor needs to be replaced. Last I checked, its about $80 from onkyo.
This is NOT an isolated incident as darn near every Onkyo receiver model had this problem.
Good luck...
Rob
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
  • 14 Answers
SOURCE: Onkyo TX-SR705 Muting Problem
if what Dark_Orbit said does not work try doing a master reset by ressing and holding the dvr/vcr button and stand by button simultaneously. This would erase all your assignments so you would need to reassign all your sources hooked up to your onkyo.
Posted on Mar 05, 2009
Onkyo tx-ds656 stand by power light comes on volume control knob rotates to max but display or unit wont start
Try factory reset: while holding the(CD) button on front panel,press (POWER) button.
After "Clear" is displayed the unit should be back to its factory default. :) If this dont work for you take the unit to be checked by service . :)
Jan 24, 2014 | Onkyo TX-DS656 Receiver
My Onkyo TX-SR606 won't turn on
The reference to Zone 2 means that your Onkyo receiver is set to be remotely controlled from another location. Normally, this arrangement would be initiated at the time of set up but could be done later. You may have to repeat the initial set up routine to get things back to normal
Feb 22, 2013 | Onkyo TX-SR605 Receiver
Onkyo TX-SR701 Digital audio port stopped working
you may want to try a factory reset by pressing and holding vcr1 button while pressing the power button. do this with the unit on. It will reset back to factory default. so any saved setting will be lost and you will have to set again to your settings.
Jan 03, 2010 | Onkyo TX-SR701 Receiver
Unit no longer powers up after shorting the switched plug in back of unti
you most likely fried a circuit board trace on the power supply
Dec 25, 2007 | Onkyo TX-SR500 Receiver
Onkyo tx-ds676 dead no power up
power down the amp totally to reset processor, then try again. If still no go, may have blown internal fuses- replace and try again
.... or failed thermal fuse in mains transformer. this is a workshop repair as it involves mains voltage that can kill :)
Nov 24, 2007 | Onkyo TX-DS676 Receiver
632 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
