Question about Kenmore Elite 45986 Front Load Washer
Front loading washer
Drum stuck
    Problem Solver:
  • 16 Answers
Check the belt.
Posted on Nov 23, 2008
SOURCE: whirlpool duet sport washer something stuck between drum
Having the same problem when draining think there is change stuck somewher making the loud noise during the cycle how do you open up the duet sport, to check?
Posted on Aug 17, 2008
  • 1462 Answers
SOURCE: Smell in Front Loading GE Washer GCVH6260F
more likely due to using liquid detergent - change to powder
Posted on Dec 01, 2008
  • 38 Answers
SOURCE: RE: Front loader drum stuck
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Mar 14, 2009
  • 30 Answers
SOURCE: aquarius washer drum stuck
sounds as if the drum bearings have gave way was it noisey b4 this
Posted on Jun 09, 2009
  • 4090 Answers
SOURCE: Rubbing noise on front load washer drum
dont they have 4 shocks?
the drum is imbalanced i would wager
Posted on Aug 18, 2009
Washer fills water, drum is stuck
you may have a sock stuck in between the drums
rotate the drum when it becomes stiff you stop then take out the lower paddle by pulling it
you may now see the sock
Dec 01, 2013 | Indesit W 123 Front Load Washer
Washer is putting holes in clothes
Check the inside of the drum when the machine is empty by feeling the entire surface with your hand. Take care as you are looking for something that's got stuck in one of the holes in the drum and is protruding into the drum, and this can often be a wire from an underwired bra!
If you find anything it should be removed by pulling it out carefull with a pair of pliers.
Mar 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Drum stopped turning mid cycle, think something is stuck, have opened up backbut cant access drum
If there is no removeable cover on washer, then you have to remove therear half of the cabinet to gain access to the drum etc.
Jan 17, 2010 | Zanussi ZWF1430W Front Load Washer
Aquarius washer drum stuck
Jun 06, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Dec 01, 2008 | GE Energy Star WCVH6260F Front Load Washer
Object in the drum
this aint an easy fix.
Sometimes a bra wire gets through the holes and gets stuck.
the only thing you can do is split the drum housing and empty it out.
No hard to to but takes a lot of time and patience.
Sometimes when you are lucky take the pump hose off the drum housing and look in that hole. sometimes it gets stuck there
Mar 04, 2008 | GE WSXH208A Front Load Washer
Elastic eating front load washer
Check the inside drum vanes. Sometimes the vanes may crack and grab certain items.Next check the front of the drum and tub for any loose items like wires from bras or curtains sometimes these may get stuck in the drum or vane and cause this problem.Also check your soap make sure there is not alot of suds this is my number one problem with these machines.H.E. soap is best but watch liquid tide it's been sudsing alot.
Oct 03, 2007 | GE WSXH208A Front Load Washer
Drum sticking
take the heater out it will be stuck round that or wraped round the front of the drum u may be able to get @ it if not im afraid u will have to split the drum to get it out if u r not an enginer i would not attempt it good luck
Sep 15, 2006 | Tricity Bendix AW1000W Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
27 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
