Hello, and thank you for choosing fixya
My name is Michael . I'll be helping you with your problem today.
Normally if the dryer does not work at all then you will have to check the thermal fuse it is a white plastic thermal fuse to ensure it has continuity to ensure it is good ill post a pict of it below
It is located on the blower housing and cannot be reset. The most common
cause for overheating is a vent tube clogged with lint, a birds nest or
other debris....
make sure it's good.
If it's
good and the push to start switch is also good, then that means you have
a faulty door switch or a bad timer. Check the door switch and see if
it still clicks. If it still clicks then it's good, and if not then
replace it. Otherwise you'll need to replace the timer.
