Question about Sport & Outdoor - Others
My model 12 pump 12 gauge is stuck in the bolt open postion.
It's manufactured in 1948 and shot very little. When the release is activated the pump handle moves rearward about an inch, but that is as far as it goes.
    Scholar:
  • 63 Answers
Should take it to a gunsmith, but if you want to loosen it yourself, get some spray gun cleaner, or even gun oil (light) and put it inside as much as possible, keeping in mind that it may be loaded with a stuck cartridge(point in safe direction at ALL times). Loosen with the lubricant, open action up and inspect throughly. If there is a cartidge in it, discard safely, as the lube may have ruined it and an old cartridge may be unsafe. If you can get the action open, try to clean out possible corrosion with swabs and q-tips soaked in the lube. Depending on how it was stored all this time, you may have to disassemble and lube more completely. Google the name and model number to try to find diagrams or assembly help.
The best thing is to take it to an "old-timer" who is familiar with older shotguns and have them inspect it, or take it to a gun show or shop.
Treat it as Loaded until you can prove otherwise by opening the action! DO NOT ATTEMPT TO FIRE!
Posted on Dec 05, 2008
Winchester 1400 ser#L2538861
I'm sorry, but there are no published serial number year of manufacture information for the Model 1400. It was first introduced in 1964 and was offered in 12, 16 or 20 gauge with 26", 28" or 30" vent rib barrels. This Model was discontinued in 1981.
The new Model 1400 was introduced in 1989, was chambered for 12 or 20 gauge with either a 22" or 28" vent rib barrel.
The Model 1400 Ranger is a utility grade gun in 12 or 20 gauge, a 28" vent rib barrel, 24" slug barrel with rifle sights or a two barrel set. It was introduced in 1983.
The Model 1400 Quail Unlimited was introduced in 1993. It has a compact engraved receiver with a 26" vent rib barrel and checkered walnut stock.
The Model 1400 Ranger Deer Combo is a 12 gauge only with a 22" smooth barrel and a 28"vent rib with 3 win chokes.
Values for all are : excellent-$350, very good-$300, good-$250, fair-$200, poor-$125
Add 35% for the Plastic stock on the first model and 20% for 2 barrel sets.
Sorry I couldn't give you the year. The only way to get it is a factory letter from Winchester which will cost about $100.
I hope this information has helped you. If so then would you leave some good feedback for me.
Thanks,
Marty
Aug 17, 2014 | Sport & Outdoor - Others
Have a winchester 1906 pump .22lr, when the bolt is pumped back to cock the hammer, the hammer falls as the bolt is going back to battery. Now if I pull the hammer back to cock and then run the bolt the...
The cocking mechanism is not pushing the bolt back far enough to reach the purchase point of the hammer. I do not know if that model has any way to adjust the range of bolt travel, but it could likely be worn metal just barely falling short of the mark.
Can you find any noticable play in any parts between the cocking mechanism and the bolt?
Have you tried pushing the bolt itself back (inserting something in front of the bolt and push back) to see if you can make the hammer catch in that manner, to narrow the problem down to just the cocking mechanism?
You may need to have a reputable gunsmith look at it, which would also be much safer than trying to repair it yourself, as well as safer than trying to use it while in this unreliable state. If the hammer toches a round just a little too hard before locked in fully chambered position, you could blow out the extractor pin or even worse, as I'm sure you could imagine.
Oct 14, 2013 | Sport & Outdoor - Others
Wi want to know when my model 94 30-30 was made.
Winchester keeps an index of all serial numbers and manufacture dates. You can get this info off there website. You will need the model number and serial number, this will get you a year sometimes even a month if it a newer run. Good luck
Nov 26, 2011 | Sport & Outdoor - Others
Did Winchester manufacture a damascus barrel on the 1897 12 gauge
Yes, it was available as an option until 1914. They are moderately rare and not recommended for shooting with modern ammunition. you would actually be best off to consider it a wall-hanger.
Sep 04, 2011 | Sport & Outdoor - Others
What ammunition does this shotgun take? i have 12 gauge shells but it wll only hold 3. whats wrong?
Below is a chart of recommended shot size, gauge, choke and barrel length respectively : 2, 4 12, 16, 20 and Modified or Full and 24" to 32".
Mar 19, 2011 | Sport & Outdoor - Others
What year was my fox sterlingworth 12 gauge shotgun manufactured according to my serial number 103329
Go to nra.org and do a search.Or go to gunsamerica .com and get into a shotgun chat forum... hope this helps you.
Oct 19, 2009 | Sport & Outdoor - Others
I have a vintage model winchester 24 12 gauge SxS
I spent that past 20min or so runnin through the normal places I normally find Owners manuals for older guns with no luck.
The only place i was able to find one is on ebay. Gun Broker.com is also another place they are sellin them.
Here is a LINK to the ebay Auction.
Oct 18, 2009 | Sport & Outdoor - Others
12 gauge shotgun shell converted to metric (ex. 12 gauge + 20mm)
A ordinary 2 3/4 inch 12 guage shell equates to a European 70 mm. a 3 inch Magnum is a 76 mm.
Goof Luck.
Mar 20, 2009 | Omega Juicers OMEGA GUN LOCK 12 GAUGE...
Sport & Outdoor - Others Logo
106 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
