Sony Cyber-Shot DSC-F717 Digital Camera
Problem for Sony Cyber-Shot DSC-F717 Digital Camera
Camera is on but LCD screen and viewfinder are both black
By counselor on Dec 22, 2006
video camera: when turn on in recording mode there is no picture in LCD screen or the viewfinder - it is just black. The camera will record but can only hear the audio, no video. The video is fine to watch previously recorded video, the problem is in the recording mode. Help
Same Problem
Oct 19, 2008
-   me too have the same problem for my S400. I have tried to reset the camera by holding the menu button for over 5 sec while it is turn on. It does not work. -   Guest
Apr 01, 2008
-   Worked great for over a year and then one day turned it on and got black screen. Won't show review of any pics already on it and won't take new pics. Also, power won't turn off, have to remove batteries to get it to turn off. Both new problems that occured at the same time.
Bummer!-   smarfin
Jan 16, 2008
-   the screen is black and when i take a picture it is so black you can't really see a thing. How do i fix this?-   maya8
Dec 31, 2007
-   well my camera is a panasonic lumix and
whene ever i try to tkae pictures or record it just records
blcak and takes black pictures.
what do i do?-   Guest
Nov 20, 2007
-   Camera Turns on. Old pictures can be seen on the LCD screen.
But cannot take any new pictures the screen is blank.
Can you suggest how to fix this issue
-   mohsinu1
Best Solution
posted on Aug 07, 2007
Helpful)
AceGoodBloke
Rank: Apprentice
Rating: 88%, 54 votes
Quite often, the ribbon cables lose their connection and need to be re-seated. If you're brave enough and have the dexterity and enthusiasm for such things, pull it apart, noting which screws go where and disconnect and reconnect the ribbon cables from the lens unit. It's worked for me in the past.
Was this helpful?
Yes
No
Solution #2
posted on Feb 18, 2008
Helpful)
Alohamj
Rank: Apprentice
Rating: 91%, 4 votes
1. Press display (DISP.) button to turn the display on Do this when your camera is on and in shooting mode. This should fix the problem. I had to try it a couple of times before it worked.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Dec 22, 2006
Helpful)
toothy
Rank: Guide
Rating: 88%, 87 votes
You either have a bad CCD or aperture. Look down into the lens when the camera is on, is there a small opening at the bottom? If theres a small open circle at the bottom, your CCD is bad not the aperture. Its very possible your camera is covered under a huge CCD recall but I cant figure out this site so Im not sure what your model is. If its F717, Sony will fix it free.
www.darntoothysam.com
Was this helpful?
Yes
No
Solution #4
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Solution #5
posted on Jan 19, 2008
Not Rated)
blwidow
Rank: Apprentice
Rating: 0%, 0 votes
If your battery is fully charged -put camera on video recording mode. Record with voice. When played back and the voice can be heard but the LCD screen remains black or distorted the CCD is bad. Sony will replace for free up to Sept. 08. You can place a service repair order at http://esupport.sony.com/perl/select-system.pl?PRODTYPE=38,33,7,37,25,39,53
Was this helpful?
Yes
No
Solution #6
posted on Nov 19, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thank you to all that posted. I ended up calling the manufacturer, can't remember offhand who it was and they shipped me a brand new camera. The customer service person told me this was a common problem with these digital cameras.
Solution #7
posted on Nov 17, 2007
Not Rated)
Kono
Rank: Apprentice
Rating: 0%, 0 votes
In the past I went through every option on the menu screen and no luck. Today I pressed the DISP button in the lower left area and now its fine. Wierd! Hopefully it won't go out tomorrow.
Was this helpful?
Yes
No
Solution #8
posted on Nov 16, 2007
Not Rated)
t00nz
Rank: Guru  Sony Cameras & Camcorders  Expert
Rating: 91%, 1998 votes
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Comments:
Was this helpful?
Yes
No
Popular Solutions for Sony Cyber-Shot DSC-F717
Questions and Unsolved Problems for Sony Cyber-Shot DSC-F717
Do you recommend Sony Cyber-Shot DSC-F717 Digital Camera?
Answer
Answer
Sony Cyber-shot DSC-F717 Digital Camera. The screen is smudged horizontally and there is a green... (More)
Answer
Sony DSC-F717 will not operate in battery mode (replaced the battery). Works ok when power cord is... (More)
Answer
my camera isn't taking any pictures even though it's on, and the lens is off. I'm pointing at... (More)
Answer
I would like to restore all the setting to original factory setting when I bought it. I followed the... (More)
Answer
external flash will not override internal flash - the subject ends up with very harsh over-lighting.... (More)
7 Other Users Have The Same Problem - Continued
Comment by eXciter, posted on Nov 11, 2007
I have the same problem , getting black screen while camera is on , can record video , but only voice is available not image. Can view previously shooted pictures .Please help ...
Comment by Kono, posted on Nov 10, 2007
When I turn on the camera I can view my pictures on the screen, however if I go to take a picutre the screen is black. If I take a video the screen is fine. Can you help?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Cyber-Shot DSC-F717...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
