Question about Sharp Viewcam VL-AH151U Camcorder
Cannot remove DV tape from Sharp E32 Viewcam Model VL-E32U
Unit has been plugged into 110 volts with adapter and battery has been charged.
  • 1 more comment
  • valsena Nov 21, 2008
    The unit has been turn on many times, the screen comes on but tape cannot be ejected!
    Unit turns on and screen instructions are to eject the tape, after opening tape housing there is a little button at the top that reads eject. Upon pressin this button nothing happens. Screen is still asking that the tape be ejected.
    After trying the above solutions the tape will still not eject. In the Teran solution the tape had to be pushed down but that means that the lid must be removed. Also there is a small whirling sound when the eject button is pushed
  • Sharp Master
  • 4,806 Answers
The Teran solution is correct, the camera is stuck on a function and thats reason it won't eject and you can hear the "whiring sound" the plastic that covers the tape has to be removed so you can can get a flat headed micro screwdriver in between the tape lid and the record/play head in the middle and push the head back up gently, this should release the catch and eject the tape, be gentle with this because you can either snap the tape, damage the recorder or both
hope this helps
Posted on Nov 21, 2008
  • 147 Answers
You will need a service tech to check it out and remove the wond tape hope this helps ya thanks
  • 1,879 Answers
To get the jammed tape out, opening the delicate camera is required if you have electronics background. Otherwise, it is better to have it serviced by a qualified technician.
  • Sharp Master
  • 19,396 Answers
When this happen usually the cassette is stuck inside because the tape is wirled around the traction wheel and the internal mechanics.
To fix this without risking to damage the camcorder, the unit must be taken apart by a technician and the tape removed.
See the phone number listed on the user manual, it is sharp service support phone number, contact them, book a repair , and solve the problem.
  • 76 Answers
Sounds like the tape is caught inside...that will require a service person to open it up, and unwind the tape from whatever is holding it closed.
  • 10,515 Answers
Check to see that you have Win98 SECOND EDITION. If not, get it. If I remember correctly, it's got the DV cam support. You can find the SE on microsoft.com. They'll have to send you a CD.
  • taran_2005
    taran_2005 Nov 21, 2008
    The camera has been high maintainance, but I have been able to fix all of the problems. For the eject problem, you need regular head screwdriver to wind the minidv tape off of the bad spot (the beginning of the tape in my case)and a pen or sharp object to push down the button in the center of the tape that allows the spool to move. If you are having pixellation problems, or even if you aren't, visit radio shack and pick up video cleaning alchohol and swabs for the heads. This has made a world of difference in my camera.
  • taran_2005
    I hope ur query must be resolved as i myself fixed it many tymes :)
    Any quetsions,
    **************************24/7available***********************
    Do rate this post :)
    Fixya.
    THnx.
    Sergeant:
    Champion:
  • 347 Answers
Hello valsena,
What is your problem? Isnt your camcorder turining on?
  • Santiago Vallejo
    Santiago Vallejo Nov 21, 2008
    Hello valsena,
    Your tape is most likely stucked inside.
    You will have  to either open up your camera by unscrewing the screws or taking it to a local repair shop were they will unscrew it and take the tape outside.
I have a Sharp VL-E760 viewcam LCD that records on 8mm tape. The battery no longer charges and I have a tape inside that wont come ojt because it needs the battery. Is the problem the charger itself
The problem is most likely the battery itself when you have finished using your kit and wish to put it away never put it away with a half or fully charged battery as it will not last always run it down and never leave a tape in either.
John www.jvsvisual.com
Apr 18, 2013 | Sharp Video Cameras
I need the adaptor so I can power my Sharp VL-E32U Viewcam from a wall outlet. What can I do?
Go to Radio shack they have some universial adaptors for most products they have helped me in the past with my sony.
Mar 25, 2012 | Video Cameras
I need an AC adapter to plug in my viewcam, what is the correct size
Cameras requests similar AC power supply either 110 volts or 220 volts. The cables connection area should only fit into the camera port provided allowing the power outlet area to s do the rest. Refer to the cameras user manuals to attain the specific cables. Also, consulting with the electronic sales persons usually with the camera detauils to acquire the appropiaet power cables. Once at the retails area, refer to the cameras battery compartment since similar details are provided on the power requriement either cells or AC cables.
Feb 06, 2011 | Sharp Viewcam VL-AH151U Camcorder
Replacement charger for Sharp Viewcam VL-Z3
As long as you can obtain a charger that is rated the same as the one for your camera it will not be a problem unless the original charger is a microprocessor controlled charger that has the ability to control and change the charging current as the battery charges.
A camera shop can check this out for you.
If it just a simple AC or DC charger, then you can simply use the connector from your original charger and join it either by soldering or with a screw terminal block(which you wrap in Insulating tape once fitted).
The main thing you need to be CERTAIN of is as to whether the original charger is an AC or a DC type.
This will be clearly indicated on the label on the charger.
Oct 25, 2009 | Sharp VL-Z5 Mini DV Digital Camcorder
Drivers for Sharp Viewcam VL-Z3E
please send to me driver for Mini dv sharp viewcam VL-Z1
Apr 19, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
I get the DEW indication and cam shuts off
try to dry up your camera using electric hair blower drier, dew is present inside your camera, but dont overheat the unit, place your hand between drier and cam to make sure you are not overheating it. if the trouble is still there, the sensor is defective and you need pro fix.
Sep 28, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp Camcorder VL-NZ100E battery doesn't seem to charge
2.7 volts is too low. Usually camcorders use battery at least 6 volts. Problems with rechargeables especially NiCds and NiMH, a cell will be shorted. for 6 volts pack, there are 5 cells in series (5 pcs x 1.2 volts with load , 1.35 no load). If you are measuring only 2.7 volts, it is highly possible that 3 cells are dead. As for the charger, if the same charger is used to power the camcorder and you said the the camcorder operates using the adaptor, this means that the charger is OK. You can ZAP the battery back to life but I will not recommend. It can be dangerous. If you can buy the battery, I suggest you do it since the old battery, even when zapped, will not provide enough juice anymore.
May 22, 2007 | Sharp Viewcam VL-NZ100U Mini DV Digital...
The "DEW" indicator is illuminated on my Viewcam, what do I do to turn it off?
This means there is moisture inside the Viewcam. Try taking the tape out, leaving the cassette compartment open for 2 hours to allow any condensation to evaporate. If the DEW indicator is still illuminated call a Sharp authorized servicer.
Sep 07, 2005 | Sharp Viewcam VL-A10U Camcorder
Sharp Viewcam VL-AH151U Camcorder Logo
724 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
