Question about Toshiba 57H83 57" Rear Projection HDTV
Toshiba 43 inch projection set
I have a 2003 Toshiba Projection TV. Last weekend while watching the set the screen went into vertical lines and after 1 or 2 minutes went blank. If I left the set off for 1 or 2 hours the picture will come on for 5 minutes then repeat above problem. Any ideas on a fix. Thanks
  • richard konzelmann Dec 23, 2006
    Thanks for the quick response! A local repairman wanted to replace a part, don't remember the name, and said it would cost $475 to fix and he would need to take the set to his shop. From your response it sounds like an in-home fix is appropropriate. What do you think?
  • 7 Answers
Possible bad solder connections in convergence circuit or vertical deflection circuit. This happens in alot of equipment. After warm up, expansion of joint pulls connections loose. Recommend not running like this, could cause component failure.
Posted on Dec 22, 2006
The problem is a shaky picture with a static line that's vertical when watching regular TV. This problem does not happen when not watching in HD through our Myth TV (DVR). Closed captioning does not...
Regular TV, you mean by the aerial and internal tuner, if it is like that, then it is a problem with the TV tuner board.
If by regular TV you mean an external TV box, then the TV box is faulty or you have a cable or ferquency problem.
Sep 13, 2008 | Televison & Video
I have a Toshiba 43 inch projection TV. Six months ago the convergance function was repaired by a TV repairman. Now the TV is periodically turning on and off by itself while we are watching it. What...
More than likely, as the tuning is governed by a remote control function, it is a dodgy remote control.
Try putting the remote control out of the room.
Hope this helps.
Oct 31, 2010 | Toshiba 43HX71 43" Rear Projection...
Toshiba projection tv
Sounds like it blew an "Internal Fuse"
if you want to fix it..simply open rear of TV and look for the fuse.
here is link for a manual if you do not have one.
Mastersage
http://www.devicemanuals.com/guide/Television/Toshiba/Toshiba-43H70-User's-Guide-TVRNME9EUT.html
Feb 05, 2009 | Toshiba 43H70 43" Rear Projection...
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
Dec 24, 2007 | Toshiba 46H83 46" Rear Projection...
Aging 43H7143
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
Hi toshiba 43 rp
You have a confusing mixture of data......Please provide
Make,model,age and chassis off sticker on back of set.....T.
Nov 26, 2007 | Toshiba 53H71 53 in. Rear Projection...
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
43 inch rear projection
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Nov 22, 2006 | Toshiba 53H71 53 in. Rear Projection...
Toshiba 57H83 57" Rear Projection HDTV Logo
115 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
