Question about Dell Optiplex GX280 (99301) Motherboard
My system hangs after about 5mins after booting
The system hangs after booting, about 5 mins after booting
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    what operating system are you using and how much memory is installed?
  • 159 Answers
If it happens at 'random' times, and won't restart immediately, most likley it's overheating due to dust blocked heat sink / fan (or a bad fan)
If it always happens at the some point in the boot up before you get the password prompt .. most likley it's s/w
Hit F8 during power up.. select 'last known good'
If that fails, F8 and select 'Safe Mode'
If you get into Safe Mode, uninstall whatever you last installed that is causing the lock up (most likley some hardware driver or some virus/root kit you got via email)
Posted on Nov 29, 2008
My cf-w7 hang after abt 15 mins
If this just started roll it back by with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode).
In Win 7 - Start > Start > Search type System Restore.
In XP - Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
There is the option of uninstalling last program(s) that was installed, again in safe mode.
You also try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Oct 13, 2012 | Panasonic Toughbook W7 Notebook
the unit just only hang.. what you have to do is to unplug the unit within 5 mins.then after 5mins.try to plug it again..and your lynksys would be good again and ready fo your calls.. :)
Jan 28, 2011 | Linksys PAP2T
Boots up windows runs for 5 mins then system shuts
You may have a cooling problem (with older computers), if you hear your fan running excessively and then it shuts down on you. Otherwise it is more likely a hard drive issue.
Jan 25, 2010 | Toshiba Satellite P25-S5263 Notebook
Master heater only runs for 5mins
Check the photo eye to make sure it is clean,clean it with soap,and water,and add a additive to the fuel for gelling.
Jan 14, 2010 | Master Heaters B155DST
Pc hanging
Scan your PC with a good antivirus like avast which support boot scan;it will solve your problem if it is caused virus,worm or malware.
Sometimes system hangs when a porgram start to load during bootup too.
for troubleshooting this,boot your system in sfae mode during startup by pressing F8.Click "start" then "Run" type "msconfig" select "startup" tab untick all the program and restart your system.
PC hangs or reboots due to overheating of the CPU.It is caused by dust and dirt contamination the system and blow it with a small air blower.
Dec 18, 2009 | Acer Aspire One PC Notebook
Dell inspiron 9300 getting hang or restart after every 15 min
Sounds like your hardrive is starting to fail-backup all files!!!
Apr 12, 2009 | Dell Inspiron 9300 PC Notebook
Getting hanged
try to boot into safe mode by pressing F8 while restarting..then in safe mode goto>start>Run>type msconfig>and in start up tab disable the un necessary programs...then restart
Apr 11, 2009 | Acer Aspire 4720 Notebook
My hpdv6000 recovery got stuck at 98% and showed 5 mins remaining then after 15-30 mins it moved to 99% and still showing 5mins! its been 30 mins no action seems its stuck. I started the process by going...
Hello Humanold,
Please check the following recovery steps:
Full recovery by using recovery partition:
1. Reboot the notebook PC.
2. Keep tapping F11 when the Compaq logo displays.
3. When the Recovery Manager appears, click Next.
4. When prompted to use the Microsoft System Restore program, select No and click Next.
5. When prompted to use the System Recovery, select Yes and click Next.
6. Select the option to perform the recovery without backing up files and click Next.
7. Upon completion of the process, recovery will display "The PC Recovery was successfully completed".
The recovery process will return your PC to the factory image.
Full recovery by using recovery disks:
1. Open the disc drive door and turn off the PC.
2. Insert the first Recovery disc in the disc drive and close the door.
3. Press the power button to turn on the PC.
4. The HP Recovery Manager window appears during the boot process.
If the HP Recovery Manager can access the hard drive, a prompt is displayed to backup the user files before continuing the recovery.
If the HP Recovery Manager cannot access the hard drive to fix the system errors, the HP Recovery Manager will overwrite all the data and reconfigure the entire hard drive to its original condition.
5. Follow the prompts to insert any additional recovery discs in the disc drive.
Sep 10, 2008 | HP Pavilion dv6000z Notebook
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Sytem Hangs!
Looks like a bad Memory dimm, try replacing it.
Oct 03, 2007 | Computers & Internet
Computers & Internet Logo
113 people viewed this question
Alun Cox
