Question about Canon imageRUNNER C3200 Copier
Canon ImageRunner 3200 Problem
Hey my copier just keep saying "Printer is warming up..." and continues to say the same thing. I changed the Fuser, Toners and Drums... Still the problem continues. Any ideas?
  • 5 more comments
  • omansur Nov 23, 2008
    I checked that... Actually had it on an industry size UPS and took it off, plugged straight into the wall and still nothing.
  • omansur Nov 24, 2008
    I tried exactly what you recommended. Tried a completely different outlet circuit and tried the reset button. Still not working. "Printer is warming up..." and I even left it on over night and still the same message in the morning so it doesn't time out.
    Yes I changed the Fuser because that's what I was told was the problem. Then I was told the drums and toners. So I changed everything. Still nothing. I've been the in service mode and really am not sure what I'm looking at in there. All the parts I put in were Canon OEM.
  • omansur Nov 25, 2008
    Totallyall, I removed the back panel and and side panel covering the power supply. Looks pretty clean. Cleaned it out with some air and checked all the connections. Now remember I said I changed all the drums? One drum I didn't change was the Magenta because I changed it only a two weeks before the error. So basically we have new drums, toners and fuser. Do I have to resent something when changing the fuser or drums like a reset in the service mode? Now I'm completely stuck.
  • omansur Nov 26, 2008
    Never had electrical problems with that machine or any others. Bought the machine on Ebay used for about 2k. It has about 700k prints on it. We've had it for about 8 months. About a month ago we had an error (Magenta Drum). Changed it and worked great until now.
  • omansur Dec 12, 2008
    The problem all along was a bad NEW oem drum.
  • Mike S
    Mike S May 11, 2010
    Sorry I dont work on Canon's... I hate those things..
    but if it says Warming up.. never gets past that?
    leave it on for a long time, see what happens? If you changed the Fuser Unit, it might not be connected properly, when a Laser Machine says it is warmng up. That is what is warming up in the Machine. I dont know if there is a service code to reset when you replace the fuser?
    In my experience if a machine does not warm up, it will throw an Error code. if it freezes up, something in the system is corrupt. some ESD might havve damaged a borad..
    But agian I dont do these machines. sorry...
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
Was this happening before you changed the Fuser, Toners and Drum, is this the reason you changed these parts?
Your fusing unit could be bad, not connected correctly, lamps or sensors, thermostats, thermsistors could also be bad.
Most machines will give a code when there is a problem, if your machine is stuck at Warming up, it sounds as if there is a problem with the system. Either a bad board, or corrupted sys info (ROMs, sys board etc). I am sure there is a code to clear trouble, reset the machine.
On most modern machines, you can test each section through service. I would start with that. I do not have any manual related to your machine... There are places around the internet where you can purchase a service manual. And you will want a service manual not operator.
This site has many different manuals available
http://www.intravia.com/
Posted on Nov 24, 2008
  • 67 Answers
Check your wall outlet rthe voltage is less than 110
Posted on Nov 23, 2008
  • 1 more comment
  • khamral BAKSH Nov 24, 2008
    you have to check the wall outlet physically with a meter if you cannot do that then plug the copier into another outlet that youy know is working also check all your connections pl;us thers is a reset switch on the bottom left hand side towards the bach of the machine make sure 5that is in the right position if nothing works wee will have to go
    ok your power supply is not working check the connecting chord remove your power supply clean it then replace it. i have all the manuals for this machine only experience will help i will contact canon with this problem
  • khamral BAKSH Nov 25, 2008
    first---drums gives copy quality and e020 when they are bad second fuser gives error codes , copy quality , jamming and noise . now we look at your power supply , but before tell me how old is the machine in terms of meter readings did you buy it refurbished or second hand how long did it work for you . did you ever have any electrical problems with other machine or copier .
Cannon 3200 when machine has warmed up error code 000732-001
This is a reader communications error. It's been a long time since I worked an IR-C3200 copier but all cables must be plugged in. They will only go where they were intended to go. Reseat all those cables and good luck, other wise you have a professional help problem. Make sure all the cable checks are done with power off. Then power up agai n and see what happens.
May 07, 2017 | Canon imageRUNNER C3200 Color Printer
I change fixing film still problem e000000-0001 what can I do? canon Ir 4570
you may have forgotten to tight connector screw of heating element.check it if it is ok then check the continuity of heater element with multimeter, if it is not showing continuity replace it.
Mar 02, 2011 | Canon imageRUNNER 4570 Copier
When machine is cold and run first copies of anything the black and red ink looks to be running. What is the problem? It does not do it when the machine is warmed up.
Printers that use "toner" (dry ink) rely on heat from the "fuser" unit to melt the ink into the paper. If the "fuser" is becoming slow to "warm-up", then the toner is not getting properly melted into the paper.
Call your local CANON store, and place a service-call.
Jul 21, 2010 | Canon imageRUNNER C3200 Color Printer
Kode erorr e0000-000
This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
May 15, 2010 | Canon imageRUNNER 5000 Copier
there are several steps before reaching the laser i-- clear dc con then take machine off remove plug from outlet then power up machine 2--clean the itb assembly thoroughly 3---change the transfer belt 4 --- change the itb assy. if nothing works then we will go to the laser
Jan 06, 2009 | Canon imageRUNNER C3200 Copier
Error code Canon IRC3200
change the black drum reached end of its life
Canon Tech
Jul 22, 2008 | Canon imageRUNNER C3200 Copier
Canon ir c 3200
It is a fuser heat error. Try to reset the machine from the error code. If problem persists you have the check the fuser for damage. Could be a thermister, thermoswitch, or faulty heaters. To clear error, service more function/clear/error/ok/ exit service mode and cycle power.
Jul 13, 2008 | Canon imageRUNNER C3200 Copier
Paper Jams
How many copies has the copier done ?
When was the last fuser fitted ?(heated rollers)
the fuser rollers have a life of about 100,000 copies
and you change the whole unit at 200,000 copies
Feb 15, 2008 | Canon imageRUNNER C3200 Copier
Canon Imagerunner C3200 User Manual
what driver do I need for a imagerunner 3200 with fiery and where can I get them
Jan 12, 2008 | Canon imageRUNNER C3200 Color Printer
Canon imageRUNNER C3200 Copier Logo
475 people viewed this question
old marine
old marine
