Question about GE 25830GE3 5.8 GHz Cordless Phone with Caller ID (2090239889)
Keypad Volume Is there a way to either lower or mute the keypad volume when making a call? Thank you.
2 Suggested Answers
The helper
SOURCE: keypad
Press the "talk" button on the keypad 2 times then it will turn off the volume of thekey pad. If you dont get the thing please inform me this afterwards.
Posted on Sep 24, 2007
  • 3 Answers
SOURCE: How is ringer volume adjusted?
While talking, press the VOLUME buttons (left and right
arrows) to control the volume of the handset's earpiece.
There are four volume levels. Press the right arrow (+)
button to increase the volume level, and press the left
arrow (-) button to decrease. VOL 1 is the lowest level and
VOL 4 is the loudest.
Posted on May 16, 2008
0 characters
1 Points
Can't turn the ringer on to notify when a call is coming in.
Without the model, I can't be sure of the method you need to enable the ringer.
Some Uniden phones toggle on a Silent Mode if you press and hold the # key (below 9 on the keypad) for 3+ seconds on one handset. When turned on, the phone will ask how long (1-9 hours) you want the ringer to be disabled for the handset. If no key is pressed within 5 seconds, the handset will not ring until the # key is pressed and held again.
Other Uniden phones have a Do Not Disturb mode. This disables the ringer on all handsets.To disable this, press and hold the DND button on the base. The answering system will be turned on if it isn't already on when DND is in use.
The other options to mute the ringer include the volume down on the handset when the phone is in standby. Some phones will also adjust the ring tone volume in the menu.
I hope this helps. Please add a comment with the model of your phone for additional information.
Apr 29, 2016 | Uniden Cordless Phone
How to get my unidendect60 off silent mode
Uniden offers a variety of electronics products including corded and cordless telephones. Each of these phones features the ability to mute the phone whenever you desire. Muting the phone can be done as often as you like and canceled as you desire. The steps to muting your phone will vary depending on the type of phone you are using.
b> Locate the "Mute" button on the phone. The button will be on the keypad near the number keys. Press the "Mute" button to mute the phone. Look for the "Mute" indicator on the phone's display to ensure that the phone is muted. Speakerphone Volume Use the VOL (+ or -) buttons to adjust the speakerphone listening volume while it is in use. users guide
Jan 20, 2013 | Phones
Uniden dect1480-3 how do I turn handset volume up?
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 10 of the manual for detailed instructions on how to adjust the volume on the handset and base set.
Basically to adjust the volume of the handset earpiece, just push the UP ARROW on the big round button in the middle of the handset keypad. Make sure the handset is already on when you do this and that you can hear sound coming from the handset earpiece.
See page 5 of the manual for a labelled diagram of the handset buttons. The UP key is the activated by pushing the top part of the big round center button which is located immediately below the main display screen on the handset keypad.
I truly hope that was helpful to you.
Good luck and take care.
Nov 13, 2011 | Uniden Phones
Volume on G E model 21028GE3-4
To adjust the speaker volume, press up/down on the base unit.
To change the ringer volume:
Make sure your phone is OFF (not in talk mode).
Press the MUTE/PROG button to go to the main menu.
Press CID/VOL (up or down) button to scroll to "HANDSET SETUP".
Press MUTE/PROG button to confirm.
Press CID/VOL (up or down) button to scroll to "RINGER VOLUME".
Press MUTE/PROG button to enter the menu. "SET RINGER 1HI 2LOW 3OFF" shows in the display.
Use the touch tone pad on the handset to select 1, 2 or 3, or use the CID/VOL (up or down) button to scroll to your selection. HI is the default setting.
Press the MUTE/PROG button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
To change the receiver volume: When the handset is ON (in talk mode) you may adjust the receiver volume by pressing the CID/VOL (up or down) button.
If you need a manual, you can download one here.
Oct 06, 2011 | GE 21028GE3 Cordless Phone
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Phones
Euroset 2005 phone does not have high low volume switch
ya you are write the volume switch is not given in Euroset 2005. volume can be adjusted by this code while u pick up the receiver "Set/mute # 4 #"
Jul 18, 2011 | Siemens Euroset 2005 Corded Phone
How do I turn the ringer volume down on my Samsung DCS 24? I have tried hitting the volume down button while the phone is ringing but that didn't work.
Hi, to change the ringer volume on your Samsung DCS - with the handset down, press TRANSFER 114, then hit 1 to 8 on your keypad - (1 being the quietest setting) please look at the video I've posted for you, If you find this useful checkout YouTube search 'abbeytel' where you will find over 60 more 'how to videos' relating to the Samsung DCS
Apr 20, 2010 | Samsung DCS 12 Corded Phone
How do I change the name on my Samsung Prostar DCS 24B phone?
To Program an extension name:
1 Press the TRSF key and dial 104
2 Enter the name using the dial keypad like you are texting
When the next character you want appears on the same key press the volume UP key to move the cursor on space to the right.
To make any changes press the volume DOWN key to move the cursor to the left .
If you want lower case letters press the A key brfore entering letters.
3 Press the TRSF key to store the name
Dec 02, 2008 | Samsung Prostar DCS-24B-LCD Corded Phone
Sep 24, 2007 | GE 25932 Cordless Phone
Ringer volume
on the back of the base there is a volumr high low switch.
Aug 09, 2007 | Innovage 1502084 Corded Phone
Phones Logo
19 people viewed this question
Top GE Phones Experts
Are you a GE Phone Expert? Answer questions, earn points and help others
