How to reset sharp photo copier mx-m450n error code (u2-11)
My photo copier is mx-m450n i can not copy with this it show this error code (u2-11) how can i reset it pleas help me some one thank you so mach
SOURCE: Help
Sorry bubbabear 64, you are wrong you need to reset the copier with sim 14, once you have cleared the jam, there is no sensor in the fuser so often if the paper gets crumpled in there is doesnt trigger and sensors so the customer trys to copy again and again, seen it many times.
John Sharp Tech
Posted on Jul 22, 2008
SOURCE: Get an user manual for a sharp copier model #AR-M450N
sharp.com should have the manual to down load
Posted on Dec 16, 2008
  • 7 Answers
SOURCE: Sharp MX-M450N copier getting Error code F2-04 Improper cartridge
change the cartrage
Posted on Mar 23, 2009
hamzaskilltd
  • 316 Answers
SOURCE: our sharp mx-m450N gives us error code u2-11. what
EEPROM read/write error (serial communication error)
Posted on Jun 06, 2010
rezazadeh
  • 328 Answers
SOURCE: Sharp copier AR-M450N "Close finisher and finisher covers"
check finisher lock switch.
Posted on Jun 23, 2010
What does error code h3-00 indicate?
Sharp ARM 550/620/700 Reset Machine with Error Code ...
? 1:26
www.youtube.com/watch?v=BXs8PmMXFtk
May 5, 2011 - Uploaded by Thomas Trumpler hi thmas please tell me how to clear sharp mx-m620n copiermemory chip to use it ... How do I clear error code h3-00 on mysharp mx--453.
Sep 30, 2015 | Sharp DX-C401 Color Copier, Printer,...
Controls / CONTROLLER FAN MOTOR
Yes its the developer motor. mite need to be replaced I would check the developer unit first, also mite replace the developer
Aug 28, 2014 | Sharp Mx-m450n Mfp Multifunction Booklet...
Sharp mx 350n code e7 90
You need to make sure the machine is in Copy Mode then hit
Pound, Star, C, Star
enter 14, then touch start
execute on the screen
the machine will reboot and the code should go away.
If it persists you may need some maintenance. If you're in Houston give us a shout. Our labor rates are low compared to the other Sharp dealers in Houston.
Skelton Business Equipment Houston Copiers
http://www.youtube.com/equipmybiz
Jun 29, 2014 | Sharp AR-M450N Black & White Copier
Error code U6-02
You have a large capacity double tray, the code is for the lift up motor in the right hand tray (that lifts the paper stack to the rollers) pull out the tray and see if there is paper wadded between the tray and the back wall of the machine blocking the motor boss from meshing with the tray.
Clear the motor error code with SIM 15 in the service area of the machine (from copy mode, # * C * to access)
If the code comes back your lift motor is worn out and needs to be replaced
Apr 20, 2014 | Sharp Mx-m450n Mfp Multifunction Booklet...
SC L6-10 ON 5631
i have problem in my photo copier sharp ar203e the problem is op what mean?
Mar 22, 2013 | Sharp AR-M450N Copier
Sharp ar -m351 Error codes L4-30
sharp printer mx-m450n error code l4-02
Nov 24, 2009 | Sharp AR-M450N Copier
Hello i have copier machine sharp mx-450u,with mx-nbx3.some times when i print document.suddenley stop printing,so i turn it off then it start printing,allways same ****.so i dont know the proplem cause of...
As a general rule, U machines are not designed to be turned into network printers, that's what the MX-M450N is for. You can put an MX-NBX3 on it, it might work properly and it might not.
The NBX3 can only function properly with a hard drive in the copier, otherwise you're outta luck!!
Your driver type may be wrong. If you are currently using PCL6, try PCL5e.
Other than that, try getting a new driver from the Business Copiers section of sharpusa.com. You may have to see which model will work for you. Look for the PCL driver for MX-NBX3, then look for MX-M450U, then MX-M450N.
Jun 17, 2009 | Sharp Office Equipment & Supplies
397 people viewed this question
k24674
jasbo
jasbo
