Question about E-Machines eMachines Desktop PC
I push power button on but computer will not power up
The fan works but it just won't come on. Some I know that there is some power but the computer will not come on when I push the power button
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Replace the power supply.
Posted on Nov 22, 2008
  • 93 Answers
Open the Computer Case..
Remove the RAM and Battery..
Re insert it after 5 to ten minutes
then try..
Option 2:
Try by Changing SMPS.
Posted on Nov 21, 2008
  • 45 Answers
First make sure that everyhting is pluged in nice and tight. And then leave it unplugged for a few minutes after taking out the little battery on the motherboard, and if that still doesn't solve your problem either your powersupply or your motherboard look like they are failing. If it is new and still under warrenty bring it back to where ever you got it.
Simply won't turn on. All the power at the plug has current but nothing when you push the on button.
Gary, Could be power supply failure. Links below for trouble shooting your problem.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Fix Laptop That Won Turn On
Laptop not powering up won turn on Fix Solutions
My laptop won turn on when push the power button
Here What to Do When Your Computer Doesn Turn On
Feb 26, 2016 | Computers & Internet
My computer was downloading windows updates overnight and froze. Tried turning it off from the power button, but did not work so I unplugged the computer. Few hours later I plugged the computer back in and...
You will have to get your power button unstuck. I do not know what type of button you have but if you would like to at least get your PC on without it instantly turning off, you can remove the power switch connector from the motherboard. You will eventually need to have the switch unstuck, or replaced though.
Oct 13, 2013 | Dell Dimension C521 PC Desktop
Lights won't work on Harbor Breeze ceiling fan
Ceiling fans operated with remote controls, pull chains, and/or wall switches tend to get confused and just fail. You can try disconnecting power at the source and, while pausing briefly, remove batteries from the remote and push all buttons to eliminate the "stuck button" cause. Then, reconnect power and try various combinations of controls until something works or you give up in frustration.
May 03, 2017 | Dryers
Pc won't power up
Not much to work with. Can you give more detail? What happens when you push the on/off button? Fans spin? LED's Blink? Anything on the monitor?
Jan 18, 2013 | Dell Inspiron 531s Desktop Computer
My computer won't start up
Sounds like you need to have a local PC repair shop test your Power Supply.
Tallon41
Sep 18, 2012 | HP Computers & Internet
Device could not start
what device? is *********** board won't start? Or a hardware doesn't start like ram or your printer
If the problem is your motherboard check all your hardwares and connectors like this:
  1. If the motherboard won't start if you click the power button check the LED(the small light bulb on your motherboard) if its glowing. If not, check the connector of your power supply or check the power supply if its working by looking its fan if revolving.
  2. If you push the button and there's a sign of power but didn't start up that will appear on your screen check the connection of your monitor screen to your desktop computer. If it's connected, remove your RAM from the motherboard and insert it to another memory slot to check if it's broken.
  3. Last, if you push the power button and here 1 short beep but the boot screen didn't appeared from your screen check your graphic card. Remove the graphic card and re-insert it again to its graphic card slot and plug in your monitor connector to it. If it still remain that way, buy a new graphic card.
Aug 01, 2011 | Computers & Internet
My friend karen press the power button, thre is no power... there blinking lights on the back of the computer near the fan power ...
Do you hear the harddrive start up? When you push the power button (or switch on the back) do the lights go out? If you hear fan running and hard drive start up then the computer itself might be on but the monitor isn't. Check the power to the monitor, the connection between monitor and computer to make sure they are all on and connected.
If you don' t hear the fan running then you have other problems. Any blinking lights would indicate something is getting power. I'm assuming the computer was working before the power button was pushed... If the monitor is actually working, you could hook up another monitor to check too then you have other problems but need more info to know what that could be.
would need to know the answer to the above questions as well as if it was working before, what was done, what changed between it working and this problem. Also what age the machine etc.
Jul 06, 2011 | Computers & Internet
E-Machines eMachines Desktop PC Logo
107 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
