When turn" on" then it automatically turns off
Give me some solution plz. When i open to play game it shown directx error message d3derr not abailable line 2634. What can i do?
Posted on Sep 22, 2013
  • sai manoj
    sai manoj Mar 03, 2014
    please help me sir, i also have same problem
  • 392 Answers
Which oerating system do you use? write in details the problem faced by you
Posted on May 13, 2012
  • 1 more comment
  • sai manoj
    i use windows 7 ultimate software... i have recently installed igi 2 game but when i tried to open it, it shows an error message like,"Fatal error: Could not locate device caps
  • sai manoj
    directx error message : D3DERR_NOTAVAILABLE FILE/project/igi2/B/2/PC/pc_direct3d.c line:2634
  • sai manoj
    please help me sir, how to fix this error.......
SOURCE:
Key turns to "start" position. Nothing happens, key doesn't spring back to "run".
Sounds like the link between the lock cylinder and the switch is broke.
Jun 13, 2013 | 1993 Dodge Shadow
Tip
How to Sync Phone Contacts between a Motorola Droid and Gmail
<p>If an Android phone, the Motorola Droid has a feature that automatically synchronizes the information from phone applications associated with Google Account. This function includes an automatic synchronization between Gmail contacts to phone contacts. The process is immediately at any time a change is made. All the user has to do is the username and password in the right time. <br /> <p><br /> <p>Initial Setup <br /> <p>1. Turn your Droid, the first time. <br /> <p><br /> <p>2. Choose or create a new account or login into an existing Gmail account. Click "Next." <br /> <p><br /> <p>3. Enter your username and email password when prompted. Click "Sign In" or "Create". <br /> <p><br /> <p>After the initial setup <br /> <p>1. Press the "Menu" button on your Droid. <br /> <p><br /> <p>2. Click Settings. Click on "Account & sync." <br /> <p><br /> <p>3. Click "Add Account". Click on "Google." <br /> <p><br /> <p>4. Choose or create a new account or login into an existing Gmail account. Click "Next." <br /> <p><br /> <p>5. Enter your username and email password when prompted. Click "Sign In" or "Create". <br />
on Aug 18, 2011 | Google Android
Tip
How can I charge the battery of my iPod Touch?
<p>Apple goes out of his way for most of its products easier to use. The iPod Touch is no exception. Load it requires only the USB cable and comes with access to a computer. The battery is not user, if your iPod does not charge you or a defective battery, which requires the device to an Apple reseller. <br /> <p><br /> <p>1. Turn on the computer. Let it boot completely before proceeding. If a laptop, connect it <br /> <p><br /> <p>2. Turn your computer into sleep or hibernation. On a Windows machine, you can do this by going to the Start menu, click "Control Panel" and select "System and Maintenance". Click the "Power Options" and click "Change Power Settings". Click the "Advanced Settings", select "Never" in the options for the "sleep after" setting. On a Mac, go to "System Preferences" and click on "Energy Saving" option. Check the box next to "Put the hard drive (s) to sleep when possible". <br /> <p><br /> <p>3. Connect the iPod to the USB cable. Connect the other end of the cable to your computer. Your iPod will automatically begin charging. <br /> <p><br /> <p>4. Turn off the iPod when it reports that it has completed loading. <br />
on Aug 05, 2011 | Apple iPod touch
Tip
How do I automatically start Bluetooth?
<p>Bluetooth is a wireless connection method used for two different devices together, like a computer, cell phone, headset or sync. You are required to enter code synchronization when connecting two devices, but most likely you do not want to enter this information each time you want to sync the hardware. Instead, you can automatically start the Bluetooth devices in sync with each other. <br /> <p><br /> <p>1. Turn on the Bluetooth device (such as a headset) and the hardware you want to synchronize with the equipment (such as your computer or mobile phone). <br /> <p><br /> <p>2. Click the "Start" button when using a computer, select "Control Panel" and finally "Hardware and Sound". Select "Bluetooth Devices" and click "Add" and wait for the computer to search for Bluetooth devices. Press "Setup" when using a mobile phone, select "Bluetooth" and activate the configuration. This allows the phone to search for the Bluetooth device. <br /> <p><br /> <p>3. Select the Bluetooth device, once it is detected (both computers and mobile phones) and enter your pair of four-digit code (listed in the user manual of Bluetooth device). <br /> <p><br /> <p>4. Press "OK" on your computer or mobile phone connects to Bluetooth. Now each time the devices are enabled on the phone and the computer automatically detect and connect to Bluetooth devices. <br />
on Jun 26, 2011 | Computers & Internet
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
When I turn on my receiver, it automatically turns off and the power button flashes red. Prior to shut down, the receiver display notes "Tuner Ext. In" What's the problem? It has worked p
Protection circuit turns off the unit because of critical conditions- wrong power supply voltages or one of the power amplifier channels is bad. First, visual inspect the power amp board near the heat sink for burned resistors, test outputs for a short. If there are no problem you may try to turn the unit on and you have several second before it shuts down to check power supply voltages and power amp output voltages and bias, then ... Long story you'd better take it to a repair shop or repair at ebcelectronics.com
May 09, 2009 | Denon AVR 2808Ci Receiver
Open Questions:
Computers & Internet Logo
152 people viewed this question
Alun Cox
