Question about Hoover U5227-930 Elite Upright Vacuum
Hoover Dimension Vacuum - No suction - Any suggestions?
I was not in house when this happened but person said their was an extremely loud noice and then no suction. Belt appears to be OK and no blockages as far as I can tell. What can be wrong?
  • Linda Cope Dec 02, 2008
    First I tried to buy the part and was told that I had to bring in the vacuum. I did that and was told that it would cost $190.00 to fix it. I took back my vacuum and purchased the fan from another store. I took it home and, with help, fixed it completely within 20 minutes. (The part cost $5.95.) Thank you, thank you...I will pass around evidence of your expertise!
    Scholar:
  • 55 Answers
Your fan broke. This is a direct air motor, which means what you pick up goes directly through the fan and they break if you pick up something too big. It's an older design and fortunately one that is made to be repaired. The Fan Part # is 38755030. Its a pretty easy repair to do yourself. The entire hood snaps on the the nozzle and can be taken off by releasing 4 catches on the bottom of the unit. That is the only real trick to it.
Good Luck- That was one of the better hoovers ever made.
Posted on Nov 21, 2008
Hoover Dimension has no suction and it smells of something burning
pets in house? check all hose passages for "hairball" clog...and check the drivebelt that spins the brush...(some have an electric motor to spin the brush, thus no belt)
Nov 02, 2012 | Hoover Bag Paper Microfilter Dimension...
Just bought this Hoover Fusion vaccum used, cleaned it up, checked belt and filter, turned it on and is extremely loud, almost like a scream. Any idea what could be causing this and how to fix?
Loud noises from this model are caused by dirt build up on the suction fan mounted directly to the motor. Under the dirt cup there is a filter screen that should have a foam filter insert, when not used or cleaned properly allows dirt to get into the motor. Cleaning is the best option. Although if you are inclined, you can take it apart or take it to your local deaLer.
May 01, 2010 | Hoover Fusion Plus Cyclonic Upright Vacuum...
Bag was not on good, resulted in dust,dirt, dog hair everywhere...have cleaned pretty thoroughly but vacuum does not have any suction. After taking apart did find that the larger wide belt is broke but I...
Greetings from GoVacuum,
There are two things that you should check on this vacuum after running it without a bag inside. The first thing you should check is the filter that is underneath of the vacuum bag. This filter is underneath of a bracket, and the bracket can be removed by pulling straight up on the bracket. The bracket and filter are directly below the vacuum bag inside the vacuum bag housing. If the machine was run without a bag (or the bag fell off) then this filter is most likely going to be extremely clogged. You can simly remove the filter, and run it under hot water until clean. Make sure the filter is 100% completely dry before putting it back in the vacuum and using it. Running the vacuum with a wet filter will destroy your motor.
Now in terms of the belts. Where as the belts don't directly control the suction of the vacuum cleaner, they certainly facilitate the pick up of dirt and debris on the floor. Many people assume that since the vacuum is not picking up from the floor, then the vacuum doesn't have suction. You can test this by pulling out the attachment hose and feeling for suction, is there suction at the end of the hose? If yes, then the reason the vacuum is not picking up on the floor is because of the belts. If you don't have suction at the end of the hose, then you have a clog, some where or a dirty filter.
The belts actually are what spin the brush, and the brush basically sweeps the carpet, and throws the dirt and debris into the suction port, and when the dirt and debris are near the suction port, the suction then takes over and takes it to the bag.
There are two belts on this model, it's best to replace both of these belts at the same time. If you replace just one, then the other belt will wear out quicker. It's always best to replace these two belts in conjunction.
The two belts that are used on this vacuum are:
Hoover Windtunnel V-Belt Part 38528034
Hoover Windtunnel Flat Belt, Hoover Part 38528035
Once you have the belts, and you're ready to replace them, here's a great video that we shot here at Govacuum.com that shows you exactly how to replace these belts, as well as some basic maintenance on your roller brush;
I really hope that my repair solution was helpful to you in fixing your vacuum cleaner. If you have any further questions about this repair, or any repair, feel free to contact me at chris.jones@govacuum.com, or request a clarification here on Fixya.
If you did find this repair solution helpful, please kindly rate this repair helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of this solution.
Thank you very much,
Chris Jones
GoVacuum.com
Mar 19, 2010 | Hoover U6437-900 / U6439-900 Windtunnel...
Low suction
I suspect the hoses are plugged with debris.
Apr 21, 2017 | Hoover L2310 GUV Central System Vacuum
No suction
I have found more vacuums on the way to the dump because they were full. Check. Is it full?
If not the air way is clogged.
May 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Bagless WindTunnel vacuum cleaner.
very easy. you have clog. take the brush off look where the hole is thats where the clog is. it might be in there you might have to take the housing off of the motor
May 08, 2009 | Hoover U5753-900 WindTunnel Bagless...
No suction on my vacuum. Hoover Tempo
try to clean between the roller and the tube to the hose
May 05, 2009 | Vacuums
No suction on Hoover Wind Tunnel.
Greetings from GoVacuum.com,
First this is a common problem on ALL bagless vacuum cleaners. Usually it takes longer then 1 day however.
Is there no suction in the suction hose, or is it not suctioning from the floor?
Most people buy a bagless vacuum once, then return to a bagged one after their bad experience, you are not alone!
Please give me the model number to your Hoover, (found on the bottom or the back of the vacuum on a foil label).
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
Aug 18, 2008 | Vacuums
NO SUCTION
took mine to repair shop for this problem. Dog and people hair caught up in housing you can't reach.
Oct 28, 2007 | Hoover U8143-900 Upright Vacuum
Filter sucks against top creating low suction
Beckyanneok,
See my post with the same problem (described in painful detail) at:
http://www.fixya.com/support/t329235-no_vacuum
I've no idea why this should happen all of a sudden. But it has. And so far nobody is suggesting anything.
Don.
Apr 30, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover U5227-930 Elite Upright Vacuum Logo
179 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
