Question about Casio G7301V8V Tough Solar G-Shock Gray Mens Watch g7301v8v
Sleeping and charging
Hi there, A few times a day my watch is goes into charge mode and stays that way for a few hours at a time. Nothing else will display other than the flashing word "charging" Is there something seriously wrong with this thing? Thanks Pack
4 Suggested Answers
  • 2071 Answers
SOURCE: Casio baby G watch model 3786 (can't change digital time)
Im a watch technician,and when im make adjustment to a new watch for me i dont need any manual,the thing ive done is keep pushing and pressing the button and observed what happen and the result i write what im discover new to me.When setting a baby g watch find the set and press it for 10 seconds.then your watch will flashing then go to mode button and choose what you are going to set.The hour ,the date ,the alarm whatever is there to set desame you going to do , only the set button need along press.Message me whatever you discover .
Posted on Jun 18, 2008
  • 79 Answers
SOURCE: need to fix time on Casio G-Shock
The hands are set independent from the digital display
Setting CASIO G-Shock Watch
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C __ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached (high beep).
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Posted on May 11, 2009
SOURCE: Casio Pathfinder PAG-50 battery replacement
ensure all three of the springs are present
the 2 at the top confirm that the case is closed the on at the bottom sends the sound signal.
ensure the metal casing on the back of the movement is not touching the back. and check the movement is correctly seated
Posted on Nov 08, 2010
  • 6771 Answers
SOURCE: my casio 2638 will not
Chances are the rechargeable battery will need to be replaced, the average life span is 1 to 3 years.
Posted on Mar 11, 2011
0 characters
1 Points
Why isn't battery recharging in sunlight?
Failure to recharge completely could be a sign of a failing battery.
Dec 03, 2015 | Casio Mens PAG240-1CR Pathfinder Triple...
Casio pathfinder battery operated watch keeps blanking out display?
Your watch is solar powered, so I think it isn't charged lately. At a low charge, the watch goes into saving mode by switching off the display (while keeping the time, date, etc.). To charge the watch leave it in a brightly lit spot for a day or two. That should be enough to make the watch function as normal again.
For more information, you can download the manual of your watch here (direct download link):
Timepieces Watches Manuals CASIO
Jun 11, 2014 | Casio Pathfinder PAG60-1AV Watch
My Casio protrek prg 60 1aver is stuck in time mode. When I press any of the buttons they do not activate the required function. The charge indicator has been been stuck on 'M' for days. I have...
probably one of the buttons of your watch is stuck that's why you cannot use the other buttons of your watch. it has to be opened and check for it, mostly of the button that are stucked with this kind of watch is the illuminator or the light located at the lower middle of your watch. i hope i had helped you.
Jul 25, 2011 | Casio Triple Sensor Pathfinder PRG60-1AV...
My casio 2638 will not stay on, always in sleep mode, how long do i have to charge it?\
Mar 11, 2011 | Casio G-Shock GW500A-1V Wrist Watch
On my sports 50 it stops if it is off of my wrist for 14 hours . Also I dont know how to change the day sign to english
This is obviously unsatisfactory and I can understand your problem. Even spring driven automatic watches will run for 2 - 3 days when not worn.
Your watch can either be charged by use (i.e. wearing it) or by winding the crown wheel, although there seem to be a variety on kinetic watches and it is not clear if all of them can be wound by hand (mine can't but it goes to sleep after two days and can stay in this mode for 3 months and re-starts when it is worn!)
For a fully description of the kinetic operation go to and there you will will see a choice of kinetic watches.
You can also access the instruction manual list to check out how your watch is intended to operate. Some watches indicate days in two languages (as yours appears to do) and you can select the correct day by pulling the crown wheel to the middle position where you generally change the date by rotating it forward and the day by turning it backward. When turning it backward, you should see and alternative day and you should stop at this position. The watch will continue with the same language after this.
If this does not work, then you should be able to find out the day sign after reading the instructions.
If your watch is new and after reading all the literature you still cannot sort out how to make your watch run for a longer period, then contact the maker who should be able to help.
Jan 02, 2011 | Seiko Kinetic watch
Can't get new eco drive watch to start!
The Citizen Eco Drive watches use special recharchable batteries.
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types.
Okay, if you say your battery goes bad, or the watch does not run? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
The seconds hand should run in single second steps, if it takes steps regularly, but every 3 seconds or so, it tries to tell you that its power level is going down. It will be able to continue for one or two days, but you should get it into the sun more often.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life.
If you need to know more about the Eco Drive, look for detail tech manuals for all types here:
Those are great watches as long as you remember it needs light to charge.
Dec 06, 2008 | Citizen Eco-Drive Silhouette EW869452D...
After full battery drain, no function
Hello FixYa,
How I solved the problem ???
Read my former post again.
I thought this could help you with your troubleshoot database.
Ragards, Marc
Dec 01, 2008 | Citizen Promaster Cyber Aqualand Nx Dive...
Dakota atomic wrist watch sold by National geographic
s1 is the top button and s2 is the bottem button
Feb 20, 2008 | Dakota 2786-6 Wristwatch
Acqua Indiglo Digital Watch
My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers.
Dec 04, 2007 | Watches
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Casio G7301V8V Tough Solar G-Shock Gray Mens Watch g7301v8v Logo
46 people viewed this question
Top Casio Watches Experts
Arturs Kalnins
Arturs Kalnins
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
