Question about Gateway MX3215 Notebook
Is there a way to replace the DC jack?
The DC jack and corresponding board without replacing the whole system board
  • Gateway Master
  • 4,806 Answers
Yes there is, most DC jacks you can now buy online through ebay and the likes, search by make and model number, if no joy there you will need the motherboard model number which requires taking the laptop apart
regards
Posted on Nov 21, 2008
"k55A" dc jack replacement
Hello Kenneth,
The dc jack replacement cable connects from the white connector to system board and the connector where you connect the adapter lay on the edge of board usuallyc6c10d03-2117-4a84-8cc2-a16171601653.jpg
I like to use a litte bit of super glue to keep it held in place on the board.
Gotta remove some components to access it .
Mar 12, 2014 | ASUS Notebook K55A-DB51 15.6inch Core...
My HP dv7 laptop wont turn on I purchased a new battery and a new cord it worked for an hour then shut off again!!!!!!!!!!
Your DC connector is loose from the system board:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it's still under warranty, it would be fixed at no charge to you.
http://www.insidemylaptop.com/disassemble-hp-pavilion-dv7-notebook/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Dec 01, 2010 | HP Pavilion dv6000z Notebook
How to replace dc power jack for toshiba p15
Take apart laptop and see what type of jack is on your system. There are two types. one is soldered on and the other is a module that connects to the motherboard with a wire connector.
If you have a soldered on type the you will need to de-solder it from the board then solder a new one onto the board. most ac jack issue just need to resolder it unless the jack itself is broken.
May 19, 2010 | Toshiba Satellite P15-S420 Notebook
Acer ms2220 notebook is dead.want to know which component in the mother board is faulty
If the motherboard will not power up and will not charge it is either the AC adapter or the DC power jack on the motherboard. The DC power jack failing is quite common and it can seem like the whole motherboard is dead when only that is causing the issue. Search on google for DC power jack replacement and they can usually get you going without trouble.
Apr 03, 2010 | Computers & Internet
HP Pavilion dv6000 plugged in not charging, I have a new battery.....PLZ Help.
Its the DC charging jack that you plug the charger into on one of the sides of the laptop. Do a google search, go and search for "HP dv6000 DC jack problem charging" (leave out the quotes) and you will see this is a common issue with the dv6000 and laptops in general. Many will just replace the whole laptop motherboard as the DC jack is attached to the board. If you know what you're doing, you change out the jack, quick repair job and keep your own board, but fixed. I would fix it if it were mine. You may be able to find someone local online but if you need someone to do the repair, I'm in the repair directory, as are many others qualified.
Note: It may come to a point, or the situation may just fit better to replace the entire board instead of the port alone. This is usually when the jack is not seated and easily replaceable, or if you are under warranty, HP will replace the whole board.
Mar 08, 2010 | HP Pavilion dv6000 Motherboard
The DC Jack seems to be loose, I've tried two different AC Adapters and discovered that they are in fact not the issue. The screen will show constant switching between power mode and battery mode at times,...
More likely than not the DC jack will need to be desoldered from the mainboard and replaced or the whole mainboard replaced.
Without warranty coverage you're looking at around $75 for a qualified tech to solder a new DC jack in or the full cost of the computer (replacing the whole system) as parts for the Eee PC's are prohibitively expensive and motherboard/mainboard replacement not really an option.
Jan 22, 2010 | ASUS Eee PC 1000HA Notebook
Hp Pavillion ze2000 will not power on at all
it is most likely the dc jack. the issue with this is that the jack is directly soldered to the motherboard, so basically you need to purchase a new dc jack, you will find them on eBay for around $5, then take your computer to a qualified technician to have it opened up and the jack replaced. you can also find mail in service center on eBay, if you are not up to the hassle. if this does not solve the problem, them most likely you will need to have the whole board replaced.
Sep 27, 2009 | HP Pavilion ze2000 Notebook
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Dc Jack replacement
you have to remove the screen from the laptop (in most cases) open the lower plastic case ,lift out the otherboard,carefully de-solder the dc-jack and then solder in a new dc-jack,and the re-assemble the whole thing.
Dec 19, 2007 | Computers & Internet
Gateway MX3215 Notebook Logo
161 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
