Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Dx3850 epsonprinter problem jam
Hi i cannot open my dx3850 epson printer to remove the paper jam- i have no manual and i just cannot find how to open it - stupid i know but i need to print a doc and cannot fix the problem- can anyone tell me where how it opens out to get the paper jam out
thanks
  • 1 more comment
  • Anonymous Nov 28, 2008
    Help! can't figure out how to open the printer to get the paper out, agree, it sound stupid but there doesn't seem to be any opening mechanisms
  • Anonymous Dec 02, 2008
    We had a paperjam problem. We removed the paper but now it keeps giving the alarm that we still have a paperjam. What else can we try to solve this problem? It is a Epson DX3850
  • n_paddon Mar 01, 2009
    I have the same problem but with an epson dx 7450
It was not easy, but we found a solution.
There are two key points: how to remove the panel with all the LED and buttons, and how to dismount the scanner.
The first is easy: back to the panel there is a small ****. Raise it up, and push the panel to the back of the printer. The panel will slide backwards, and can be easily removed. Carefully disconnect the flat cable and remove it.
The second point is *much* more tricky. The chassis part near the USB plug is only cosmetic, and can be easily removed once the button panel was removed. There is a clip that may be operated in the most back part of the button panel. After opening the clip raisin it a little bit, the small part may be easily removed (forcing a little bit).
Under it there is a screw fixing the left side of the scanner. To remove it you must disconnect all the cables going to the scanner.
The screw on the right side is easily accessible from the scanner top.
The rest is easy
R. Rossi
Posted on Mar 01, 2009
  • 31 Answers
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
a22
Posted on May 24, 2009
Epson xp430 paper jam, but I can't find any jam!
They don't tell lies :>) Even the smallest piece of paper over the sensor will record a jam. This often happens when you have a jam and you pull the paper and it tears a piece off. Open all the doors, remove the paper tray, remove all the toner or cartridges and look with a flashlight. Always pull paper jam paper in the direction it was going, undo tensioner clips if present and pull paper evenly and slowly as not to tear the paper. If you do, keep the paper and find the piece that fits the piece that is missing.
Having said that, see the link
Paper Jam Problems - Epson XP-430 User Manual [Page 234]
https://www.manualslib.com > ... > Epson Manuals > Printer > XP-430 > User manual
Epson XP-430 Manual Online: Paper Jam Problems. If you have problems with paper jams, try these solutions: 1. Cancel the print job from your computer, if...
SOLVED: Error says paper jam, but there is not. What could cause this ...
https://www.ifixit.com/.../Error+says+paper+jam%2C+but+there+is+not.+What+could... Dec 18, 2013 - I have an Epson Artisan 837 all in one. It was working perfectly fine yesterday. Today it is telling me I have a paper jam. I went through the steps ...
How to solve paper jam or paper feed error DO IT YOURSELF ...
? 3:43
https://www.youtube.com/watch?v=kHHpVcSJvvA
Aug 16, 2016 - Uploaded by Easyprint-DZ Support
... of commons problem of printer . paper feed error or paper jam error. ... we gonna work on epson ...
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/pho22_rf/trble_4.htm Paper does not feed. Multiple pages feed. The paper jams. Paper is not ejected fully or is wrinkled. Paper does not feed correctly when using the double-sided ...
Epson XP-430 ' XP Series ' All-In-Ones ' Printers ' Support ' Epson US
https://epson.com/faq/SPT_C11CE59201~faq-293729 Mar 24, 2016 - If paper jams when you load only one or two sheets, try loading more sheets at a time. Do not load more than the recommended number of ...
Epson xp430 paper jam Google Search
Oct 23, 2017 | Epson Office Equipment & Supplies
Epson stylus dx3850 ink saying empy when full and wont print
Hi
Try turning the printer off and disconnecting it from power completely.
Check for paper jams on the machine.
Clear any print queues.
Mar 02, 2012 | Epson Office Equipment & Supplies
Jamed paperc86 paper is jamed
Epson Stylus InkJet Clear a paper jam in printer
Jan 05, 2012 | Epson Stylus C86 InkJet Printer
Ink light and paper light flash alternatively, printer does not work
Hi - According to the Epson manual that error indicates that paper may be blocking movement of the print head.
Turn off the printer, then open the cover and remove any jammed paper or foreign objects. Turn the printer on. If the lights continue to flash you're most likely going to need a dealer service.
Hope it's the paper.
Good Luck, Mikeywaf
Feb 28, 2011 | Epson Stylus C66 Inkjet Printer
Epson Stylus 1200 lights indicate carriage jam
This means that your Epson printer has come to its end of life. In short, Epson wants you to retire your printer and buy a new one. Your Epson printer may be in good shape which is often the case. But Epson has this build-in "feature" which they want you to buy a new one.
Jun 15, 2010 | Epson Stylus Photo 1200 InkJet Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Aculaser C900 - Paper Jam Notice, but no Jam?
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Jan 14, 2008 | Epson AcuLaser C900 Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
766 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
