Question about Dell OptiPlex GX280 PC Desktop
Pc does not always boot up
When I switch pc on the power light remains orange and the pc starts to make a noise like a plane getting ready for take off. It's sometimes difficult to switch off and I have to pull the cable out. When it does work it's fine otherwise
  • Dell Master
  • 998 Answers
A solid or blinking Amber power button indicates a voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 21, 2008
PC not quiet running anymore!
The bearings are shot. All fans with bearings will do this eventally. Mos fans have standard dimensions and connectors. Should be easy to find a repla
Mar 27, 2014 | Computers & Internet
Dell Dim C521 power button remains orange; doesn't boot
Take a look at this document from Dell. You should have some diag lights on the front of the computer, and this should help you find what is not passing post.
http://support.dell.com/support/edocs/systems/dimc521/en/SM_EN/tshoot.htm#wp1064555
Feb 15, 2012 | Dell Computers & Internet
Screen not displaying. and fun starts and stops, remains stand by when restarted the fun runs and stops stand by.
hello there,
I got the same problem but it came gradually...
In fact for a full month when I first boot the computer, the fans runs, no extra beeps, the light blinked correctly but no bios at the screeen. I remarked also that the fans run full speed doing a lot of noise. Then I stopped the computer and wait 2 minutes and then it always works correclty at the second boot with the bios screen appearing. Also, the fan calm down after 1 second with less noise. So when I start the computer and hear that the fan calm down with less noise after 1 second, I know that the computer will boot correctly. That happens always at the second try after waiting 2 minutes. But since yesterday, the fans never calm down and the noise still remains high with no Bios at the screen. I'm suspecting the Power Supply...
i hope my i dea can help you.
Sep 02, 2011 | Dell Inspiron 1545 Notebook
Laptop intermittent startup problems
if you need your laptop always in ready use change the time your computer is on in control panel then log off your device will be on always until you shut it down it constantly drains battery
There is a way to fix this try reinstalling windows
or just take it to software mechanic
Mar 21, 2017 | HP Compaq Presario v4000 Notebook
When put power cable in orange light comes on power button and wont boot up
Sir,
Orange light usually comes only if your system stays in low power mode or sleeps, So u get orange light immediately when u switch on the system, try pressing the ESC Key on the top left corner of the Keyboard, and if not try pressing the power button again...
If not working,tell me Whether do u get any sounds in system?
Your system Operationg System?
And What u get on the screen, when u switch on?
Thanks, Regards
Vinod
Jun 29, 2009 | Dell GX270 P4-2.8 512/40/24X/XPP/NONE...
When i switch on the my thinkpad it starts to boot up then the screen goes blank the battery light goes orange and and flashes and it makes a cranking noise.
Is the Battery making the cranking noise? If so the battery is telling you the battery is dying. I have a IBM ThinkPad 380Z and when on the charger it makes a beeeeep noise and goes off and on for almost the entire day and then stops and keeps a solid orange battery light on.
Try booting without battery
Feb 23, 2009 | IBM ThinkPad T40 2373 Notebook
Is this a Software/Config/Hardware Problem ?
hmmm..sounds like a sleep or screen saver conflict...try booting up on Safe mode(F8) on turn on, and then see how that works. Set your screen saver for Never, and see what happens.
You may be hitting a thermal issue with your video circuitry.
Feb 18, 2008 | Dell Dimension 4600 PC Desktop
Loud whirring noise when mains switched on but PC still off
Most likely worn bearings in the fans.
If that's the case, replace the fan/s.
Jan 23, 2008 | Dell (S423) for Dimension 8100 (3F546)...
New Computer Wont Boot!
when you say "the fan makes a noise like its getting ready to spin", which fan...power supply's or cpu? if you answer power supply, then the POWER OK signal is not returning to power supply and it then quickly shuts down to prevent further damage. double check a firm connection to mother board. If you answer CPU, then it becomes far more complicated. Try re-seating the memory chips.
Jun 05, 2007 | Systemax Venture PC Desktop
Dell OptiPlex GX280 PC Desktop Logo
376 people viewed this question
Alun Cox
